Old 03-03-2013, 11:30 PM   #1
bbaik
bbaik's Avatar
Knocking sounds from lowering springs?
I recently installed Mach V lowering springs on my Fr-s. Ever since, I've been getting some relatively loud knocking noises whenever I go over uneven ground or bumps. The car seems to drive fine but the noises definitely raise suspicion since the car has only been dropped an inch. Most of the noises seem to be coming from the front, right strut but its hard to be certain.
I haven't trimmed my bumpstop yet. Mach V recommends that users trim the OEM bumpstop by 1 inch. Could this be the problem? I don't want to trim the bumpstop since I may have to return to the stock springs.
This is how front spring sits with the wheel on the ground. Should the fact that the top coils touch raise any concerns?
bbaik is offline   Reply With Quote
The Following User Says Thank You to bbaik For This Useful Post:
Jeong (03-05-2013)
Old 03-03-2013, 11:59 PM   #2
wholeeoh
Drives: 2012 subaru brz
i have the same issue now with my sportlines lol...only think i can imagine is that i didnt completely tighten my front endlinks?
wholeeoh is offline   Reply With Quote
Old 03-04-2013, 12:23 PM   #3
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
The most common problem we've seen is that you haven't got the top nut on the shock fully tightened. If it's loose, the top of the stock will rattle around relative to the top mount.
No. If you don't trim it, you're just going to run into the stop sooner, effectively limiting travel. But there won't be any clunking in either case.
At that point you could just buy new ones from the dealer, or from us. They only cost a few bucks.
No. They are designed that way, so the spring remains in tension under suspension droop.
Get the car up in the air and wiggle around the strut, sway bars, and other moving parts of the suspension. My guess is that something is loose that should be snug and tight.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following 2 Users Say Thank You to Mach V Dan For This Useful Post:
LeeMaster (03-04-2013), Sportsguy83 (03-06-2013)
Old 03-04-2013, 12:29 PM   #4
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
what dan said. if the top nut isn't tight, it will make all kinds of noises. the bump stop shouldn't be the problem at all.
Jive Turkey is offline   Reply With Quote
Old 03-04-2013, 12:53 PM   #5
bakerr6
Drives: 2013 raven black fr-s
I plan on installing mine when it gets a little warmer out (and I'm not working 6 days a week haha). You could always also buy the bumpstops from eibach and install those
bakerr6 is offline   Reply With Quote
Old 03-05-2013, 10:15 PM   #6
bbaik
bbaik's Avatar
This was actually it. Was about to take out the entire strut and realized the endlink was a bit loose.
--Dan
Mach V
Thank you for the help! The springs are running fine now.
Old 03-07-2013, 11:26 PM   #7
wholeeoh
that was also the problem in my case lmfao
Old 03-08-2013, 12:50 AM   #8
636
636's Avatar
Drives: '23 CWP BRZ
My BC Racing coilovers are making a knocking sound from the rear, y'all think it's the top nut?
636 is offline   Reply With Quote
lowering springs - if you did it tell me more.. rikdrt1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 79 09-23-2013 12:50 PM
Mach V BRZ/FR-S Lowering Springs xanderc Brakes, Suspension, Chassis 4 02-20-2013 09:54 PM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 03:39 PM
Lowering springs HELP FRS_13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-27-2012 11:03 PM
Lowering springs? Jeff Lange Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 06-11-2012 12:36 AM
