Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > Marketplace > Commercial Classifieds > Exterior Parts - Lighting
Old 02-24-2013, 11:35 AM   #43
Xdragonxb0i
Drives: ex500r
We would have to take a part the Headlight housing Correct? to install theses.
Xdragonxb0i is offline   Reply With Quote
Old 02-24-2013, 12:37 PM   #44
Diode Dynamics
Diode Dynamics's Avatar
That is correct. The headlight has to be baked open to install the angel eyes. 250 degrees for 20 minutes does the trick. Then to seal them back together. Get some permatex black silicone (not the gasket maker) run a thin line around the lens and then bake them again for 10 minutes and squeeze them back together.
-Garrick
Old 02-24-2013, 07:39 PM   #45
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
-Garrick
does diode dynamics offer a mail in service? and if so what is the turn around time??
sofrsnsokleen is offline   Reply With Quote
Old 03-03-2013, 12:19 PM   #46
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
You have my order.
Ryan86 is offline   Reply With Quote
Old 03-03-2013, 12:27 PM   #47
Diode Dynamics
Originally Posted by Ryan86 View Post
You have my order.
Good choice on the CCFL rings sir! Its gonna come out awesome!
-Garrick
Old 03-03-2013, 05:26 PM   #48
Diode Dynamics
No, Diode Dynamics no longer offers any kind of installation services.
-Garrick
Old 03-14-2013, 04:41 PM   #49
NorseLegend
A Very Annoying Person
Drives: Subaru Impreza :( Hopefully BRZ
I have a question about the application of these towards the BRZ.
On the headlight, they have that U shaped strip for the DRLs. Would there be a way to replace that strip with something you, or someone else offers?
I'm just not sure how it would look with a RGB halo and the white DRL. And since I'm planning on a black BRZ, I want to run red or another color besides white.
NorseLegend is offline   Reply With Quote
Old 03-16-2013, 11:33 AM   #50
Diode Dynamics
Unfortunately, we haven't done any testing on the BRZ but I do believe that DRL in the BRZ is built in I'm not entirely sure if its possible to change the color of that. As soon as I can get a BRZ in here to test on, I'll let you know. Do you know any BRZ owners in the Saint Louis Area??
-Garrick
The Following User Says Thank You to Diode Dynamics For This Useful Post:
NorseLegend (03-17-2013)
Old 03-17-2013, 09:32 PM   #51
NorseLegend
-Garrick
Sadly I don't, hopefully you run into some! Good luck if you get your hands on them!
Old 03-20-2013, 05:09 PM   #52
Verge
Verge's Avatar
Drives: 2013 Scion FRS
do you have an example of the ccfl kit? and do you also have any ambien lighting that can be controlled with the same controller for the angel eyes so for example the ambien light will be the same color inside as the angel eye unit on the headlights of the car. same controller
Verge is offline   Reply With Quote
Old 03-21-2013, 12:27 PM   #53
Diode Dynamics
Here are some CCFLs on a different car (only pictures we have, currently):
As for other lighting we have a footwell kit made up of LED strips: http://www.diodedynamics.com/store/i...well-kits.html
They can be wired to be powered with the same controller by using spliters and extension wire.
Please let me know if you need anything else,
Michelle
The Following 2 Users Say Thank You to Diode Dynamics For This Useful Post:
myd_lyf_crysys (03-25-2013), Verge (03-21-2013)
Old 03-28-2013, 02:05 PM   #54
Lverasky
RedBunny w/ Wing
Lverasky's Avatar
it seems hard to install..do you have mmore detail explanation on the angel eyes kits?
Old 03-28-2013, 02:21 PM   #55
Ryan86
Road Warrior
Ryan86's Avatar
Hi Nick,
Suggest you indicate two colors of the CCFL globes.
Old 03-28-2013, 05:04 PM   #56
Diode Dynamics
PMed you with installation details. If you need anymore help don't hesitate to call (314)205-3033
-Michelle
Angel Eyes installed on and off with ignition!! Roborat Cosmetic Modification (Interior/Exterior/Lighting) 87 09-06-2013 01:04 AM
Controlled Information Leaks groupb Scion FR-S / Toyota 86 GT86 General Forum 27 02-12-2013 08:20 PM
DIY wired angel eyes to on/off with ignition Roborat DIY (Do-It-Yourself) Guides 10 01-30-2013 04:46 PM
