AVOturboworld
Old 03-02-2013, 03:06 AM   #2269
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@vubaru @BRZranger, although very limited, THIS THREAD provides small data on how the car behaves with and w/o an oil cooler.
IMHO, as long as your Oil temps don't go over 250 F for extended periods of time, and don't go over 220 F cruising, (assuming you are not a track junkie), I don't see why would you need an oil cooler. I will do more tests once my kit is installed.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
BRZranger (03-02-2013)
Old 03-02-2013, 06:58 AM   #2270
Visconti
Drives: 05 STi
Originally Posted by vubaru View Post
Fair enough. I don't have an Oil Temp. gauge, was just going based off of coolant temp rising more than normal during dyno runs and while idled for prolonged periods of time. I just think one will be worth the benefit of added safety and longevity.
Will check out AVO's but I already have a Crawford AOS I've been meaning to throw on. :happy0180:
You can datalog engine oil temp via ProECU
Visconti is offline   Reply With Quote
The Following User Says Thank You to Visconti For This Useful Post:
vubaru (03-02-2013)
Old 03-02-2013, 08:12 PM   #2271
cmss2000
Drives: 2013 BRZ Premium 2012 Acura TSX
Still wondering what's causing that big torque spike at 4700-4800 rpm. Doesn't appear to be boost related.
cmss2000 is offline   Reply With Quote
Old 03-02-2013, 08:39 PM   #2272
Sonolin
Any luck on a CARB legal version?
Tried searching this thread, but didn't find any response from the manufacturer...
Sonolin is offline   Reply With Quote
Old 03-02-2013, 08:43 PM   #2273
Sportsguy83
Drives: Limited BRZ
No luck, Cat removed.
Old 03-02-2013, 08:49 PM   #2274
cmss2000
Smile
Originally Posted by nix View Post
We are going to use Visconti's SPD pump and his ~500cc short barrel injectors as well as an omni sensor to make around 10-14 psi on e85. Should have results in the next fortnight for you guys.
Is it the fortnight yet?
The Following User Says Thank You to cmss2000 For This Useful Post:
dabocx (03-02-2013)
Old 03-02-2013, 11:18 PM   #2275
Sonolin
Aww darn well thank you anyway.
Old 03-03-2013, 03:20 AM   #2276
AVOturboworld
[ame="http://www.youtube.com/watch?v=IvQ9zuDaods"]AVO Stage 2 Turbo Kit at Drift Practice - YouTube[/ame]
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
diss7 (03-03-2013), Sportsguy83 (03-05-2013)
Old 03-03-2013, 05:47 AM   #2277
diss7
Drives: AE86, 2x GT86, TE27
312 hp? Crank I'm guessing. Those tyres have far too much grip for that drivers ability. Put the stock tyres on it an pump the rears upto 50 psi. It will step out much easier and help get a feel for sliding the car
diss7 is offline   Reply With Quote
Old 03-03-2013, 08:32 AM   #2278
RWD-boxer
RWD-boxer's Avatar
Drives: Black
^ wish someone would have given me that rear tire psi info before I took my stock frs out drifting ...... I have no skill
Thenittis.com
RWD-boxer is offline   Reply With Quote
Old 03-03-2013, 10:34 AM   #2279
Sportsguy83
Drives: Limited BRZ
Correct guess.
Old 03-03-2013, 05:54 PM   #2280
nix
nix's Avatar
Drives: AVO BRZ
Waiting on parts sorry.
nix is offline   Reply With Quote
Old 03-07-2013, 04:07 PM   #2281
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Any word on when the second round of shipments are going to start going out for those that preordered?
gdrider77 is offline   Reply With Quote
Old 03-07-2013, 07:58 PM   #2282
AVOturboworld
They will start shipping within this month, I just don't have an exact date.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
