Old 02-27-2013, 12:43 PM   #4719
Visconti
Drives: 05 STi
I still need to finish these notes , but I certainly wouldn't waste a day updating all my calibrations if there wasn't a good reason to !!
Visconti is offline
The Following User Says Thank You to Visconti For This Useful Post:
JPxM0Dz (02-27-2013)
Old 02-27-2013, 01:22 PM   #4720
Opposed
Drives: 2013 Asphalt FR-S
You got a point. I will put in a ticket then.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
Old 02-27-2013, 01:33 PM   #4721
Foobar
SLO NO MO
Foobar's Avatar
Grr. OK, going out to the car with my laptop...
Foobar is offline
Old 02-27-2013, 01:35 PM   #4722
Opposed
LOL, thanks for taking one for the team. Let me know how you like it
Opposed is offline
Old 02-27-2013, 03:21 PM   #4723
Jeong
Drives: pet dragon
This is not a issue but by design.
You also have a different intake and are running a calibration that is not 100% optimized for the intake just yet.
You are on your very first map revision so I'm just puzzled with why you would post in here.
Calibrating a new intake can take several datalogs.
But from the looks of it you'll only need one more revision to make perfect.
-John
Does that mean if we datalog the current tune and see how it worked with our bolt ons. Would you recal the tune to be more efficient?
Jeong is offline
Old 02-27-2013, 04:08 PM   #4724
Foobar
SLO NO MO
Foobar's Avatar
Flashed and put on about 35 miles. Still too early to tell at this point. Will provide an update once the throttle is back to normal. Could just be placebo effect, could be the ECU still re-learning, or could be some other environmental variable, but sound seems changed, not sure if exhaust or engine note. Like I said, could be something not even related to the latest flash. John, would there be anything in the latest flash that could be attributed to a change in engine/exhaust note?
Foobar is offline
Old 02-27-2013, 04:18 PM   #4725
mad_sb
Could be a cam timing change....
mad_sb is offline
Old 02-27-2013, 07:36 PM   #4726
Carwhisperer
Drives: A lot of supercars.
Im at 100+ miles on the e70 map. I can confirm from emailing John that there is a difference in the tone. It sounds more aggressive at 3.5k+ for me now. I love it.
Carwhisperer is offline
The Following User Says Thank You to Carwhisperer For This Useful Post:
cobrabyte (02-27-2013)
Old 02-27-2013, 07:56 PM   #4727
Foobar
SLO NO MO
Foobar's Avatar
Is it just me or is cold start sounding a bit tamer too?
Foobar is offline
Old 02-27-2013, 07:57 PM   #4728
Visconti
Drives: 05 STi
Mauahahahahahah
Visconti is offline
Old 02-27-2013, 10:10 PM   #4729
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Woooo finally running the latest version of the 93 tune. Also...a LOT seems to have happened since 1.07. This tune makes the engine and afe intake sound downright vicious. I only got to take a quick lap around the block but the drive to work tomorrow should be fun...and very punctual.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline
The Following User Says Thank You to Laika For This Useful Post:
JiB (02-27-2013)
Old 02-27-2013, 10:51 PM   #4730
JiB
JiB's Avatar
Drives: GT86
"Punctual" i like it!
JiB is offline
Old 02-28-2013, 12:11 AM   #4731
bakilman
bakilman's Avatar
Drives: White FR-S
I'm FINALLY getting around to tuning my new FRS and I can't remember how to change the different configurations of the tune using the cruise control and thought there was a video in this thread somewhere. I've searched and looked through this for a couple hours. Anyone care to point me in the proper direction. Thanks in advance!
bakilman is offline
Old 02-28-2013, 12:15 AM   #4732
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Pull the cruise control stalk toward you and hold it for a few seconds (you must have cruise control off), and then flip it up, or down to get to your map of choice.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
