Old 02-25-2013, 10:55 PM   #57
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by nix View Post
130c
260+ *F... yeah, I'm doing an oil cooler before F.I.
Old 02-25-2013, 11:02 PM   #58
mad_sb
Superchargers on pumpgas will be fine without most upgrades.
The closer you get to 300whp the faster you'll need a clutch - I suggest CLUTCH MASTER.
If you need fueling I have drop-in injectors (No cutting of any wires)
If you need a fuel pump I offer the highest output fuel pump on the market.
Anyone going with forced induction needs a upgraded map sesnor.. if you go forced induction and dont have a map sensor your setting yourself for failure.
-John
What maps take advantage of the additional rage of the upgraded map sensor? I see calculated engine load and Port Injection Manifold pressure comp.. anything else? Are the maf sensors getting maxed out with the FI setups you have tuned?
Old 02-26-2013, 12:52 AM   #59
Visconti
Drives: 05 STi
overboost maps, boost controller maps need higher range map sensors to work.
Not all forced induction setups ive done have maxed out the MAFs, but a bunch have and require speed density tuning.
-John
Visconti is offline   Reply With Quote
Old 02-26-2013, 01:42 AM   #60
Visconti
Drives: 05 STi
^ yup
300whp you'll need a clutch unless your auto
The Following User Says Thank You to Visconti For This Useful Post:
vubaru (02-26-2013)
Safely Jacking and Supporting Your BRZ/FR-S GrimmSpeed DIY (Do-It-Yourself) Guides 152 06-11-2021 07:44 AM
What mods have you done so far? Rossi AFRICA 148 11-16-2015 01:41 AM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. Mitch Other Vehicles & General Automotive Discussions 43 01-09-2012 08:07 AM
