Old 02-25-2013, 02:20 PM   #15
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
AEM intake
/thread.
Jive Turkey is offline   Reply With Quote
Old 02-25-2013, 03:43 PM   #16
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Driving skill... & no, I'm not trolling here. It'll improves the car 2x faster
strat61caster (02-25-2013)
Old 02-25-2013, 03:57 PM   #17
Foobar
SLO NO MO
Foobar's Avatar
Intake is usually a safe bet but given the gains over the stock system, I really can't recommend it unless you want sound more than performance. For performance, a drop-in filter would be better bang for buck.
If you wanted to continue on your exhaust path, you could tackle the midpipe/overpipe next unless you'd rather stay factory stock on emissions.
A highly visible yet functional mod would be to change your wheels and/or suspension. Wheels should be no problem for you, suspension work probably best left for the pros at this time (or at least someone with more experience than you).
Some other easy mods: Shift Knob, Lightweight Pulley, Cosmetic things like Antenna, front splitters, side skirts, rear spats, LED bulb swaps.
If you're into electronics, then headunit/speakers, rearview camera, hardwired front camera and/or radar detector.
If you want the most performance without going FI, then consider an ECU Tune (I know you said you wanted to avoid that for now).
Finally, balls to the walls performance? You're looking at a Turbo/Supercharger Kit, and get some bigger brakes to stop all that power when need be (assuming you already got the tires to put the power down in the first place).
There are a lot of other options depending on what your priority is.
Old 02-25-2013, 04:43 PM   #18
a2cpc
Drives: WRX
Driving School!
a2cpc is offline   Reply With Quote
Old 02-25-2013, 05:49 PM   #19
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Perrin Inlet tube
Perrin Drop in Filter
Perrin Pulley
Ecutek Tune
Cusco Type OS front strut bar with built in brake master cylinder brace
Cusco rear strut bar
Better tires
Better rims
tripjammer is offline   Reply With Quote
Old 02-26-2013, 02:33 PM   #20
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Originally Posted by tripjammer View Post
Perrin Inlet tube
Perrin CAI
Perrin Pulley
Ecutek Tune
Better tires
Better wheels
Fixed
SubaSteve is offline   Reply With Quote
Old 02-26-2013, 03:25 PM   #21
stratodyne
stratodyne's Avatar
Drives: 2013 Subaru BRZ Lightning Red
Wow, so many responses! We even have one from an official Perrin rep!
Based on my research, as well as suggestions from everyone on here, I will be purchasing the Perrin inlet tube, as well as the Perrin drop-filter for my seconds modification.
For anybody that has experience with wet air filters, what is the best cleaner for the filter? Also, how oil / spray does one typically apply to the filter? I know too much oil could end up hurting the MAF if some cakes onto the sensor.
stratodyne is offline   Reply With Quote
Old 03-01-2013, 02:47 AM   #22
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
get an intake, then get a tune in the future. intake will only run u around 2-300 ish. and ull be ready for a tune after that.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 03-01-2013, 03:28 AM   #23
DSOmegaX
DSOmegaX's Avatar
Intake or grab the front pipe/overpipe
@dsomegax.cars
Old 03-01-2013, 07:11 AM   #24
a2cpc
Drives: WRX
I'm telling you, you will go faster if you invest in a good driving school.
Old 03-01-2013, 11:38 AM   #25
matchamochi
matchamochi's Avatar
Drives: swp brz
Originally Posted by stratodyne View Post
This made me lol. For the record, I only way 140lbs .
Well you're already halfway there. All you need to do is lose a leg or two.
matchamochi is offline   Reply With Quote
Old 03-01-2013, 01:33 PM   #26
stratodyne
stratodyne's Avatar
I was under the impression that all intakes installed on our cars would require a tune, with the exception of the new Perrin CAI they engineered specifically to not require a tune. If it wasn't for the filter location on their intake, I would have already bought one
Old 03-01-2013, 02:26 PM   #27
tjoy
What that guy said.
Here is what nobody wants to hear but a few cranky people will level and tell you:
Most of these mods you see, don't have a dyno run that shows gains appreciable over margin of error.
Outside of forced induction, you might be pissing your money away on tuning mods (other than maybe a chip tune). Cosmetic mods are nice though.
Over at the NASIOC forums, there is a nice gif people post sometimes showing the efficacy of tuning mods, and it's pretty much true.
If you are a racing team, spending 1k here and there for maybe 1-2HP gains over margin of error is a necessity since you know all those tiny gains add up and you need every edge. But a racing team will have the money for forced induction as well (or an engine swap).
Joe Driver would be better off taking a performance driving class.
tjoy is offline   Reply With Quote
Old 03-01-2013, 02:32 PM   #28
Ganthrithor
Ganthrithor's Avatar
Drives: '13 BRZ, '06 997, Other Things(TM)
Clear side markers :3
It's the first thing I'm doing to mine!
Ganthrithor is offline   Reply With Quote
The Following User Says Thank You to Ganthrithor For This Useful Post:
BlackNBlue (08-16-2017)
Wheel Directory: Konig Zero-In 17x7.0 +40mm mezdup Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 01-19-2014 08:17 PM
Halo Light Logic Modification? feedbag Cosmetic Modification (Interior/Exterior/Lighting) 9 01-28-2013 11:33 PM
DIY cosmetic modification. zooki Cosmetic Modification (Interior/Exterior/Lighting) 0 08-16-2012 03:24 PM
Seat bolster modification Roadstercycle Cosmetic Modification (Interior/Exterior/Lighting) 7 07-11-2012 06:47 PM
Cosmetic Key Modification ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 13 07-01-2012 06:30 PM
