Old 02-19-2013, 05:43 PM   #85
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by swift996 View Post
Yeah I know. I want to wait until I get the R2s in and installed. I plan to then get the tires mounted and get an alignment and make any camber adjustments. It will probably be 3-6 weeks before I get that done.
I hear ya, that makes sense. Have you decided on tires yet?
Old 02-19-2013, 05:47 PM   #86
swift996
swift996's Avatar
I'm going with the Dunlop Direzza ZIIs.
- 235/40/18
- 255/35/18
http://www.tirerack.com/tires/tires....omCompare1=yes
I was exploring a 245/35/18 up front but they don't offer the Z2s in that fitment and I want to give them a try.
It would put my front wheel weight at ~47lbs and the rear at ~50lbs with tires. (OEM is about 41-42lbs)
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-20-2013, 05:59 PM   #87
swift996
swift996's Avatar
Update:
I was going to wait until I hit 3500 miles to do the first oil change but sitting at 3198, I thought what the heck? I picked up the Oil Change Kit from Mach V which isn't too far away from me. It included a 5L jug (5.2qts), a single quart, a Subaru oil filter, and crush washer. I picked up an extra quart just to have.
The car is running great, one of the simpler oil changes I've ever had to do (I use to work at a shop as a teen too). The 911s are really simple but this is just about as equally simple. I ran about a .25 quart through with the plug out just to get any residue from the old oil. It's probably not necessary but I like to do that. I have an oil analysis kit coming in the mail. I thought for $25 I'll send it to the lab and see how things look.
The Following User Says Thank You to swift996 For This Useful Post:
chanomatik (02-20-2013)
Old 02-22-2013, 07:40 PM   #88
swift996
swift996's Avatar
I got my USB OBDII adapter. I played with it for like 3 hours. For some reason I can't get the driver to work properly on Windows 8. I'm not an IT slouch either...oh well $15 down the drain unless I can figure out more. Done with it for the evening.
Old 02-24-2013, 12:41 PM   #89
swift996
swift996's Avatar
It was a nice day out so I decided to test fit my wheels:
Front:
Rear:
I'm not crazy about the offset/fitment but we will see when I get some tires on and mount them. It's hard to tell with the spring uncompressed. For more pics of the fitment, see the post below:
http://www.ft86club.com/forums/showp...6&postcount=16
Sending my oil in to the lab for an analysis:
Old 02-26-2013, 06:45 PM   #90
wWaldo
Drives: Asphalt Frs
Those wheels are going to look really nice!
wWaldo is offline   Reply With Quote
Old 03-06-2013, 03:03 AM   #91
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Awesome build! Any progress with the wheels and coils?
TRD_07 is offline   Reply With Quote
Old 03-06-2013, 11:40 AM   #92
swift996
swift996's Avatar
I'm still waiting on the coilovers. I've heard they should ship in mid-march from the Eibach contact on here. So I'm guessing around the beginning of April. I plan to put those on first and then order my direzza 2 tires. Ill probably run a little rubber off the OEM tires so maybe by the begging of May I'll get the tires on and mount the wheels. We will see if I can hold out that long!
Old 03-14-2013, 09:49 PM   #93
swift996
swift996's Avatar
Update:
I got a good deal on a brake kit for the fronts from a forum member who wasn't able to use them because of his class requirements. They are actually for the WRX 03+ with the caliper brackets for the 08+ which fit on the BRZ. They are only the 4-pot calipers and the rotor diameter is only 12" (compared to the stock 11.5"). However, they shave 16lbs per corner. There was one exception to this kit, the bolts supplied don't work with the bracket, you'd have to order the 08+ specific bolts (the kit came with the rotors, etc). The Part# is 230-10425 (I will update after I get them on to confirm, also ordered #230-10646) for those interested. I will review after I get the new bolts in and get them put on, but here are a few pics:
Kit part #140-9193
The kit:
Install turned test-fit:
The Following 4 Users Say Thank You to swift996 For This Useful Post:
ATL BRZ (03-14-2013), chanomatik (03-15-2013), Scooby South (03-24-2013), TRD_07 (04-01-2013)
Old 03-15-2013, 04:25 PM   #94
Turbowned
Turbowned's Avatar
Niice. What kinda calipers? I'm running 4-pot Dynapro DB's with 2pc 11.5" rotors on my MR2. Love 'em!
Old 03-24-2013, 04:56 PM   #95
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Gonna be sweet... sorry about the bolts.. didn't even get that far. Gotta go with the 6 pots now.. I 'know' they are legal. . car looks awesome
Bill
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
swift996 (03-25-2013)
Old 03-27-2013, 05:39 PM   #96
swift996
swift996's Avatar
Update:
I'm still waiting on the bolts I ordered from Wilwood..should be any day now. I'm also waiting on my Eibach R2s.
I also ordered the FA20CLUB Equal Length Exhaust Manifold/Header!
I received my BBS center caps. Despite ordering 70mm face caps, I received ones that measure about 74-75mm. The backs click right in but since the face doesn't sit flush into the hub bore, I'm not sure what to do. It doesn't look feasible to grind them down to fit. They also sit a little taller. I think I'll just dab some adhesive on the edge and let them sit flush with the overhang on the wheel. It doesn't look that bad.
Caps:
Fronts:
Rears:
See, a little oversized but they click in and they don't look bad (have to be up close to notice):
Compared to the ESMs:
Old 03-27-2013, 05:42 PM   #97
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Soon for the coilovers i hope, i certainly have no control over build times at Eibach but there will be no delay from the time they come in to the time i ship them out.
Old 03-28-2013, 08:52 PM   #98
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
Can I ask why you went with the Hotchkis sway bars Vs. what is in the market now?
2013 BRZ Limited (black) Epictetus Cars for Sale/Trade 2 11-14-2012 11:38 AM
My crystal black brz limited chadz Member's Car Journals 37 09-12-2012 06:26 PM
BRZ, Black, 6MT, Limited...DELIVERED! boarder1995 BRZ First-Gen (2012+) — General Topics 3 06-14-2012 04:03 PM
Need a black AT Limited trim BRZ! jaytaurus Northwest 4 05-18-2012 05:29 PM
