#43 |
Drives: Toyota 86 - Silver High Spec
Thanks for the posts, guys.
Faults on mine are the same as yours: * Window rubber wearing thin. * Knocking/Popping noise coming from rear deck. Also have a lose screw somewhere under the center console which i thought I had fixed but the darn thing is back. |
#44 | |
Drives: Toyota 86 Red
#45 |
Drives: Toyota 86, Pearl White, Manual
Going to spray everything I can with silicone spray. So if it is resolved I wont be able to tell you where the problem is... Its at a point of driving me bonkers. Its not a popping sound. Its a cracking squeeking sound...
Sent from my GT-I9100 using Tapatalk 2 |
#46 |
The voice of reason...
Drives: 2012 Toyota 86 6MT Standard
These cars feel super rigid so not sure it's body-flex. Creaking sounds could be related to that polystyrene stuff they have in the boot maybe to hold the tools? My car got knocked quite hard from behind and it's still quiet with the exception of what appears to be a rattle in the driver side mirror (or it could be wind noise?) and a rattle from the driver's door with music with a bit of bass.
#47 |
Else i must put a little kid in the back to listen and point out where the sound comes from. Still gonna spray will let u know of the outcome...
#48 | |
Put the windows up, hold the button 5-sec, then put the windows down and hold for 5-sec. Repeat if necessary. It resets the window. The lights "blink" when its been tripped (violated!) like frozen up or someone/something blocked it from going up. The window up/down when opening and closing the doors cant be good BUT my buddies VW CC does it too, hes had it 3 years with no problems but his car is garaged. |
#49 |
Useful info. Thanks Boead!
#50 |
Official anti-BS squad
Drives: Toyota 86 High 6MT
That's what I've done - haven't noticed it since but then I've not been paying any attention to it. Will try remember when I leave work today.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned |
#51 |
http://www.ft86club.com/forums/showt...886#post750886
Subaru version has it's own quirks it seems. @GavinAnt - getting her just in time for dry JNB winter... |
#52 |
Confirmed - no more clicks. WD40 did the trick.
95RON SAV Tuned |
#53 |
Mine still clicks will have to dig deeper...
#54 |
Eish. I pumped a little bit of WD40 into every nook and cranny I could find.
95RON SAV Tuned |
#55 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Dash swelling in sun
Hi Guys, a real concern and something to be very aware of.
I parked in an open parking for 2 hours, car stood under the sun at 36 degrees. When I got into the car my dash had bulged and lifted up over the air vents, when I touched it the entire part was all soft. I immediately started the car put aircon on full and held the dash back into place. The aircon cooled the dash, which went back into place and hard as it normally is. Got such a scare. Be very aware of this problem, don't leave your car in the sun without a windscreen sun protector. Going to report to Toyota Pic attached is after cooling down and back into place, however you can notice it is not entirely as it should be....
#56 | |
![]() - know what I'm buying at lunch time! The black gets sooo hot inside.
| GT factory amp? | derka-derka | AUSTRALIA | 11 | 11-06-2022 04:27 PM |
| Factory Turbo BRZ | ChocolateNick | AUSTRALIA | 34 | 10-31-2012 12:56 PM |
| factory Turbo BRZ? | subatoy | BRZ First-Gen (2012+) — General Topics | 30 | 09-26-2012 03:54 PM |
| electrical faults... | tibsy92 | AUSTRALIA | 22 | 08-19-2012 10:25 PM |
| Swap: factory 16s for factory 17s Sydney | MZ21 | Australia Classifieds | 10 | 07-29-2012 10:46 PM |
