Old 02-14-2013, 11:28 PM   #1
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
5x114 conversion, what's involved?
I was curious what's involved if you wanted to convert from 5x100 to 5x114, parts needed, is it safe for track use, and general pros and cons of making the swap?
Always thankful for useful input,
Me.
Adeets is offline   Reply With Quote
Old 02-14-2013, 11:38 PM   #2
eikond
Wish Nissan made one
eikond's Avatar
Drives: '13 WRB BRZ Premium
I've been reposting this topic every couple months since last summer. I'd love to see 5x114 hubs come out.
Here's the typical answer to why I shouldn't ask..
1.) There are plenty of nice wheels coming out in 5x100
2.) It's too expensive.. might as well spend the money on nice 5x100 wheels
Here's what I know.. You should be able to use late model STI hubs for the rear wheels. However, the front wheels hubs don't seem to be swappable with any other Subaru model.. at least not that I've heard.
Some people suggest that you could go to a machine shop and have them re-drill the rotors to 5x114.3.. but I've seen reports that there isn't enough meat on the hubs to allow that to be done safely.
You can get 10mm conversion spacers.. Ichiba maybe? They are only a couple hundred bucks per half.. that would a decent solution. But most people will warn you that spacers aren't safe for track use.
So... hopefully i've offered some help..
eikond is offline   Reply With Quote
Old 02-14-2013, 11:41 PM   #3
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
I've seen a couple track guys running spacers... @robispec is one.. I'm not sure about @CSG Mike or @CSG David.. They run the stock 5x100 but have extended studs and spacers.. For sure robispec does
Gixxersixxerman is offline   Reply With Quote
Old 02-14-2013, 11:59 PM   #4
drew935
Auto Salon Works
drew935's Avatar
Drives: wrb
Stick with 5x100. It will keep the hub lighter.
drew935 is offline   Reply With Quote
Old 02-15-2013, 12:16 AM   #5
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
why don't you just swap the hubs from a sti?
jdzumwalt is offline   Reply With Quote
Old 02-15-2013, 12:39 AM   #6
eikond
eikond's Avatar
word on the street is that the rear hubs work but the fronts do not.
The Following User Says Thank You to eikond For This Useful Post:
Pooponwindows (08-28-2019)
Old 02-15-2013, 02:01 AM   #7
CSG David
CSG David's Avatar
We run the stock 5x100 with no extended studs or spacers. Our aim is to run the proper wheel sizes to utilize as much stock equipment as possible. However, we would have liked Subaru/Toyota to actually use 5x114.3 straight from the factory instead of this bolt pattern.
The Following User Says Thank You to CSG David For This Useful Post:
Gixxersixxerman (02-15-2013)
Old 02-15-2013, 02:08 AM   #8
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
First thing you need is this $$$$, then more of it.
chulooz is offline   Reply With Quote
Old 02-15-2013, 02:10 AM   #9
Gixxersixxerman
Seems everyone says that.. The 5x114.3 must be way more popular for rims huh... I didn't remember seeing if you guys had spacers.. I know robi does... Either way I knew all still was using the stock bolt pattern .. Can't wait for my next track day, also completely off topic, my friend @Pin Flare got his exhaust today.. He loves it.. Just giving you guys a thumbs up
Old 02-15-2013, 02:19 AM   #10
CSG David
CSG David's Avatar
Thanks for the props! Glad he's enjoying his new exhaust
The 5x100, according to the WRX guys, say that the wheel bearing goes out a little quicker than the 5x114.3. Who knows...just why did Subaru/Toyota do this to a sports car just blows my mind.
Old 02-15-2013, 02:39 AM   #11
HATED1
HATED1's Avatar
Drives: 86
there are already conversion kits to change it out to 5x114.3
http://minkara.carview.co.jp/en/user...blog/26679827/
HATED1 is offline   Reply With Quote
Old 02-15-2013, 02:49 AM   #12
eikond
eikond's Avatar
Yes, I mentioned this in the second post.
Why get them from Japan when you can get them here on this site..
http://www.ft86club.com/forums/showthread.php?t=26375
Old 02-15-2013, 04:30 AM   #13
CSG Mike
CSG Mike's Avatar
we *have* spacers, but haven't run em beyond really test fitting... since we can get what we need in 5x100.
Old 02-15-2013, 11:49 AM   #14
wparsons
wparsons's Avatar
That sounds like a bearing issue, nothing to do with the bolt pattern other than the stock 5x114.3 hub uses a better bearing maybe.
I would think it would be MUCH easier to get a better bearing than swapping everything over to a new bolt pattern?
flickr
Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) Evasive Motorsports Wheels and Tires 31 06-13-2015 09:09 PM
FR-S involved in another Fatal Crash? FSUnoles Scion FR-S / Toyota 86 GT86 General Forum 22 10-22-2012 04:08 PM
URGENT: Missing Subaru Outback Idaho Plates involved in Homicide - Hercules, CA Flipside909 Southern California 11 10-11-2012 03:36 AM
5x114.3 hub conversion mclevin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-03-2012 10:53 AM
5x114.3 jdmboss86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 06-30-2012 04:12 AM
