I Love custom Turbo kits
Drives: Limited BRZ
Gauge install, dash cluster light cable, Tach RPM cable help...
Fellow electricity enthusiast, I need help. I have looked at the wiring manual and while I have a general idea about it, I really don't understand everything on it.
I will be installing gauges soon and need to tap my gauges to the cluster lights cable in order to have the gauges dim accordingly. Could some help me figure out which cable I should be tapping into? What about the RPM Tach cable? While we are here, can I can I crimp the power cables for both gauges together and add them to a single "add a fuse"? Each gauge requires 5A Fuse, so I figured I can use a 10 Amp fuse. Those that make sense or I need to add a separate "add a fuse" for each? Thanks in advance!
#2 |
Ever think about using the radio dimmer signal wire?
| The Following 2 Users Say Thank You to 2forme For This Useful Post: | SirBrass (02-05-2014), whataboutbob (02-12-2013) |
#3 |
Drives: Limited BRZ
Well, it might work but I'm not sure. I don't know how the circuit within the gauge works. Does it take the signal to turn the cluster lights on to dim the gauge display? And also, how does the radio dimmer work, does it send a signal to dim it or is it actually grading the amount of current down to dim it? I honestly don't know the answer to either but maybe you know more than me and can answer them.
Or maybe you just know using the radio dimmer just works for gauges? Thanks for the help! Let me know what you think. Sent from my HTC One X using Tapatalk 2
#4 |
Well, the gauges that I have in my other car just run full brightness, until the dimmer wire gets juice. I have it piped into my radio harness to handle that....
I guess it depends on the gauge, what do the installation instructions say? |
| The Following User Says Thank You to 2forme For This Useful Post: | Sportsguy83 (02-12-2013) |
#5 |
Drives: 2013 Ultramarine FRS
Not sure if its exactly what youre looking for, but i wired in some LED's into my air vents using the radio dimmer and they work like a charm. They are off until i turn the lights on.
| The Following User Says Thank You to Trashed675 For This Useful Post: | Sportsguy83 (02-12-2013) |
#6 | |
Site Moderator
Drives: Stuff
I pull my feed off the foglight fuse so I can turn off the annoying gauge illumination at night The warning light is enough in case there's an issue.For the fuse, run whatever the load should be. I doubt the gauge really pulls that much. Since mine is control unit based I just needed one feed. In the race car I have them all fed off one power wire with a 5A fuse for 3 autometer gauges. Illumination is pulled off the radio illumination wire.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | Sportsguy83 (02-12-2013) |
#7 | ||
Drives: Limited BRZ
I guess it does work like you say, they run full brightness until the instrument panel cable gets juice. So then, what is the cable for radio dimmer? Thanks for the help! Quote:
I honestly don't know exactly if they Dimm or not, I guess I'll figure it out when I install them. Waiting for the Prime Motoring Cluster. Thanks for the help.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Iceblazer (08-16-2013) |
#8 |
Drives: Limited BRZ
Have any idea on what is the RPM cable in the cluster harness?
#9 |
Drives: Attitude
Subarus usually have reversed illumination circuits. Personally hate wiring, so I haven't explored this further, but it's on every major Subaru forum for your digestion. Big ole scar from the soldering iron was enough.
| The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Sportsguy83 (02-12-2013) |
#10 |
NASA SpecE30 Racer
I have the dimmer wire hooked up properly to my AEM gauge which allows the dimmer circuit to be either 0 to 12v or 12 to 0v. Unfortunetly, the difference in V between dim and not dim is not enough to change the gauge. I would recommend just leaving that wire unhooked. As for RPM, there are a couple wires that you can use:
Pin 17 on connector D48 Gray Wire Pin 15 on connector A35 Gray/Red Wire I haven't gotten around to trying either of these yet though.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Sportsguy83 (02-13-2013) |
#11 | |
Drives: Limited BRZ
#12 |
NASA SpecE30 Racer
Well my gauge just has the not very bright LED screen in the middle since it only shows black and the white number of my boost or vacuum and the lights on the outside for the air fuel ratio, no backlight, so I think it is fine in full bright mode. I can move the dimmer switch and get the gauge to temporarily change to a dimmer mode, but then it comes right back to full brightness shortly afterwards which is weird. I checked the voltage and it definitely changes on that wire when you move the dimmer switch from full bright to no bright.
- King Tut
#13 | |
Drives: Limited BRZ
#14 | |
Drives: 13 CSB BRZ Ltd
Can you first provide a link or make and model of the exact gauge(s) you purchased? -Acree
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
| Tags |
| dash, gauge, gaugle cluster, pod |
| What is that blinking dash light when the car is off? | JayNutter | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 02-03-2014 11:59 AM |
| WTB: FRS instrument cluster | jabbajaw99 | Interior Parts (Incl. Lighting) | 3 | 02-14-2013 02:31 PM |
| surprised at how much MORE i like the frs dash cluster | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 12-07-2012 10:09 PM |
| Flashing Security Light in Dash? | ravenMTgirl | Electronics | Audio | NAV | Infotainment | 8 | 11-21-2012 04:25 PM |
| Scratches on my Cluster. | Superhatch | BRZ First-Gen (2012+) — General Topics | 5 | 08-21-2012 08:50 AM |
