Old 02-11-2013, 04:57 PM   #71
red_comet
Severed Member
red_comet's Avatar
Drives: Argento 2013 Scion FR-S Manual
C'est une belle voiture, sans doute. Combien coûtent ces roues?
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN!
06 Xfire Bite me I liked it
13 FRS doriftoooo!
DON'T PANIC
red_comet is offline   Reply With Quote
Old 02-11-2013, 07:27 PM   #72
jedichimp
OG <FR-S'less> Member
jedichimp's Avatar
Drives: yes
You should get the plain Varrstoen caps, they look pretty sweet.
Flickr // SarapBuhay
merrill.joes@gmail.com
panda cheez
Old 02-12-2013, 03:18 PM   #73
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
You can get those wheels thru ebay for very cheap. About 1 000$...
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 12-19-2013, 07:21 PM   #74
dkx64
Drives: 2014 Frs
Need tire selection assistance
Looking for some advice on what tires to run with my varrstoen es221 18x8.5 +45 wheels. I'm not currently lowered but I plan to skip springs and get coils in the next 3-6 months with any recommendations on that. I'm worried about rubbing issues on the stock suspension so I'll get coils at the same time if I really need to. They are all quite expensive though. I will only be driving on the street but I want it to look nice. Can't lower tooooooo much cause the roads I. California are garbage, even the freeways nowadays. Wondering if I have to get 35 series tires for no rubbing. And how wide can I go on the 8.5 wheel and not have any fitment issues down the road?
Thanks in advance!
dkx64 is offline   Reply With Quote
Old 12-19-2013, 07:46 PM   #75
86 Dreams
86 Dreams's Avatar
Drives: Scion Frs
My summer setup is 225/40ZR18 on 18x8.5 +47 front and 245/35ZR18 on 18x9.5 +38 on the rear. I'm dropped on kw v3 pretty low not slammed and I have no rubbing issues at all. I think you'll be ok with 225/40 all around. It was recommended that I run a 35 in the back.
Mods: Work Emotion Kiwami, KW V3 coilovers, Invidia N1 Catback and Front Pipe, Cusco Front Strut bar, GT spec rear strut bar, Ecutek tune by JR Tuned, HKS Racing Suction, Password engine dress-up, Agency Power LCA, Perrin crank pulley, Phasetek 4th brake light, Raceseng 86er shift knob, Continental Extreme Contact DW, Grimspeed plate relocation kit, Tom's hood strut kit, Spyder tailights
86 Dreams is offline   Reply With Quote
Old 12-19-2013, 07:50 PM   #76
dkx64
Drives: 2014 Frs
I read somewhere that 245/35/18 would work with the 8.5, front and back without rubbing fender or suspension or anything else. Just can't find where I saw that. I know I've seen people running 9.5 in the front without issues with 245/35/18. I can't imagine it fitting easier than an 8.5. I could be mistaken though. I don't think I can justify dropping 2500+ on suspension just for looks. The kws look damn nice though. Hoping I can find a cheaper alternative because I imagine RCAs will also in the bill. Not really sure though
Old 12-19-2013, 07:56 PM   #77
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I have 18x8.5 e44. My tire sizing is 235/40/18. Check my wheel thread in my sig.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 12-19-2013, 08:02 PM   #78
dkx64
Drives: 2014 Frs
Do you have images? On the phone it's hard to navigate through previous threads of yours. Think 245/35/18 is too wide? It's technically the same height as stock so I'm just worried about rubbing.
Old 12-19-2013, 08:06 PM   #79
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I'm not sure if a 18x8.5" + 45 will clear the struits/inside fender on stock suspension, so I'd go for either of the below:
- Get coilovers with your Wheels
- Get a 18x8.5" with +35, those will clear the struits on stock suspension
You can run 245/35/18 in front with no rubbing (I have this setup) however you need the wheels to have a offset that matches, like a 18x8.5 +35
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Wolfking (12-20-2013)
Old 12-19-2013, 08:08 PM   #80
dkx64
Drives: 2014 Frs
Ok. I'll throw one on the car when I get home tonight and see. I'll get some spacers if I need to until I can get the coils. Sure wish coils were cheaper.
Old 12-19-2013, 08:10 PM   #81
dkx64
Drives: 2014 Frs
The only reason I didn't get +38 is because I thought it would poke out too much. I absolutely can't stand wheels that poke out.
Old 12-20-2013, 12:23 AM   #82
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Originally Posted by dkx64 View Post
Do you have images?
Yes, and anything 18 x 8.5 will fit with no issues on stock suspension. The photos below are stock suspension, 18x8.5 with Ventus V12 235/40/18 Tire sizing. Call a tire store with regards to the dimensions that you mentioned and they can give you a recommendation. There is also a huge "does this fit" tire thread here:
http://www.ft86club.com/forums/showthread.php?t=7535
φφκα
Old 12-20-2013, 03:47 AM   #83
Killerbee
Killerbee's Avatar
This is just plain wrong, as the offset of the wheel is important at that size. Take your car on the lift, and see how far the Rim is away from the stock struits, you will be surprised (I'm running 18x8.75 and I have seen it for myself how close they are to the struits)
Old 12-20-2013, 01:25 PM   #84
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Originally Posted by Killerbee View Post
...the offset of the wheel is important at that size. Take your car on the lift, and see how far the Rim is away from the stock struits...
Yes OP, it is always important to perform due diligence on any modifications you're making to your own car. You can either calculate your own offsets, or ask a local vendor to help you out, but in my experience so far, most wheels in the 18x8.5 sizing that are marked as BRZ fitted are generally so.
φφκα
Wheel Directory: XXR 521 18x8.5 +35 Iddoit2er Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-06-2016 12:53 AM
Wheel Directory: Varrstoen ES1 18 x 9.5 +34 MenoSkyz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 07-07-2015 05:47 PM
Wheel Directory: BBS CH 18x8.5 +30 Spaceywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-02-2015 02:05 PM
Wheel Directory: BBS LM 18x8.0 +50 stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-08-2013 08:55 PM
Wheel Directory: BBS RE 18x8.0 +50 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-25-2013 09:49 PM
