Old 02-11-2013, 11:46 PM   #1
jflogerzi
jflogerzi's Avatar
Installed exhaust and Intake, pedal dead spot. How long does it last
How long does it take(in miles) for the ECU to relearn and adjust to the new airflow? I have also noticed at lower RPMS in 6th(2000ish) engine seems to be a bit more sluggish then normal. I only have about 50 total miles.
Old 02-12-2013, 12:02 AM   #2
Blue86
Drives: Sonic Blue 86GT Manual
what intake did you put on? if it's something more than a drop in filter you might wanna get some tuning done.
When I did my exhaust I reset the ECU and it drove like a dog for 50 or so miles till it worked out what was going on.
Blue86 is offline   Reply With Quote
Old 02-12-2013, 12:04 AM   #3
jflogerzi
jflogerzi's Avatar
aFe Intake and perrin catback. I plan to get the FA20Club Stage 2 ECU tune very very soon.
Old 02-12-2013, 12:25 AM   #4
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
around 50-100 miles on the dead pedal spot. but a tune will make you give you more gain out of those mods.
tintumz22 is offline   Reply With Quote
Old 02-12-2013, 09:43 AM   #5
FA20Club.com
Drives: 2013 White Out FR-S
FA20Club.com is offline   Reply With Quote
Old 02-12-2013, 09:52 AM   #6
brillo
Drives: 2013 Firestorm FR-S
Did you reset the ECU by pulling the battery cable?
brillo is offline   Reply With Quote
Old 02-12-2013, 04:58 PM   #7
jflogerzi
jflogerzi's Avatar
Yes. Pulled neg battery cable. Did my install. Reconnected cable. Let the car idle for 10 mins as suggested. Its getting better.
Old 02-14-2013, 09:05 PM   #8
jflogerzi
jflogerzi's Avatar
Is it normal for the car to feel sluggish after an intake and exhaust install?For some reason down low car does not feel the same I probably now have 150 ish miles on the car now since the install. I am guessing the AFR is out of whack. The car does not have the same punch it used to when it was stock.
Old 02-14-2013, 09:32 PM   #9
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Can't speak for everyone but I only noticed slight improvements (Injen though). Maybe check everyone is on correctly? Specficially the intake.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 02-14-2013, 09:38 PM   #10
jflogerzi
jflogerzi's Avatar
It looks correct. I will look at it again later. Also car is not throwing CELs.
Old 02-14-2013, 10:10 PM   #11
Frsexxxy
Drives: White Virgin frs
Will resetting the ecu void warrenty? And will installing ecutek void warrenty?
Frsexxxy is offline   Reply With Quote
Old 02-14-2013, 10:45 PM   #12
jflogerzi
jflogerzi's Avatar
Originally Posted by Frsexxxy View Post
Will resetting the ecu void warranty? And will installing ecutek void warranty?
To reset the ECU you just pull the neg battery connection. That does not void the warranty. ECU tunes technically yes, but from what people have said, the dealer can not detect the tune. General tunes are safe if you get it from a respectable tuner. Please be clear, I don't advocate defrauding Toyota or Subaru.
Old 02-15-2013, 12:25 AM   #13
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I had a dead spot on my Injen intake until I got it replaced with a better one. The first one I received had some seriously bad welds that somehow made their way inside the tube which to my own guess, disturbs the airflow. How does your tube look like from the inside, is it smooth or does it look like this?
LeeMaster is offline   Reply With Quote
Old 02-15-2013, 12:33 AM   #14
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
I have a Perrin exhaust as well and mine didn't feel sluggish, in fact it felt a little more responsive, so it's probably the intake since that seemed to be problems for some of the people installing them, car probably just needs to adapt or something.
Is anyone else's dead pedal loose/making noise? KevinR Issues | Warranty | Recalls / TSB 41 01-16-2017 01:33 PM
afe takeda intake installed and lovin it clayrush Engine, Exhaust, Transmission 38 05-06-2016 10:30 PM
Popping/Clicking Dead Pedal BRaZinDave BRZ First-Gen (2012+) — General Topics 6 12-08-2012 05:14 AM
Dead pedal height bqe-lie-fdr Scion FR-S / Toyota 86 GT86 General Forum 0 02-25-2012 09:21 AM
STEVE JOBS IS DEAD!!! LONG LIVE THE QUEEN! WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 6 10-06-2011 01:22 AM
