Southern California SoCal
Old 02-08-2013, 11:33 PM   #15
marky
marky's Avatar
Drives: 2020 BRZ tS #54
i get 280.. ill try and get a better accurate when i fill up again... darn gas is 4.29 a gallon time to coast and shift 2/3k
how much you guys paying for a gallon of gas in your area ?
Old 02-08-2013, 11:41 PM   #16
crank
crank's Avatar
Drives: WRB 2013 Subaru BRZ Limited
@marky about the same I am in Diego too
Full Perrin Intake/ Perrin Cat-Back /PST Carbon Fiber Drive Shaft/ 5% Tint All around
Build Link:http://www.ft86club.com/forums/showthread.php?t=44038
crank is offline   Reply With Quote
Old 02-09-2013, 01:40 AM   #17
SilentAngel
Guest
Posts: n/a
Most of my commute is city, but i never go under a quarter tank, usually get about 170 miles, most i've gotten would be about 280 from a mostly highway trip. i an avg of about 8 gallons every time i fill up. Granted i don't usually try saving gas when i drive lol.
Old 02-09-2013, 02:43 PM   #18
Originally Posted by crank View Post
...cruising at 75 on the highway I am getting about 250 miles from full tank (no top off, clicks and done) to gas light does this sound normal or should I be getting more?
There are a couple of other threads on this if you want more info on it.
On the highway, straight cruise, I have no problem getting over 400+ Miles out of a tank, usually refilling right before or right after the fuel light comes on at speeds between 65 and 79MPH (depending on the highway). When cruising, I typically always drive 9MPH over the speed limit, and never over 80 (Georgia and surrounding states have super speeder laws that kick in at 80MPH).
In general I have averaged 321 Miles between fill-ups, including a few partial fill-ups based on traveling.
Full history of my fuel usage is in the top post of my Owner's Journal.
Oh, and I DO NOT have a light foot or hypermile the car.
Old 02-09-2013, 02:50 PM   #19
Mickeyt86
Mickeyt86's Avatar
Drives: FR-S Asphalt M/T
I drove from Albuquerque to Seattle and averaged around 100 miles per quarter. One fill-up I tried to see how far I would go on the light and made it 146 miles after the light came on! Made it right to the gas station and didn't want to chance it any further.
This was a very economical driving mode on about 98% HWY
Asphalt FR-S M/T Airaid intake/5Axis wing
Mickeyt86 is offline   Reply With Quote
Old 02-09-2013, 06:13 PM   #20
littlefoot
littlefoot's Avatar
Drives: BMW 5 series (e28), Yaris S hatch
I get 285-317 miles per tank. The lower range is on the wknds and the higher is mon-fri commuting to work but i consistently get 300 per tank using top tier gas. I always fillup when my light comes on.
littlefoot is offline   Reply With Quote
Old 02-09-2013, 09:38 PM   #21
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
I also get 290-310 miles per tank with the ECM recall. I also stopped using fuel with E10.
illmatic is offline   Reply With Quote
Old 02-09-2013, 10:49 PM   #22
marky
marky's Avatar
nice.. where in SD? never seen a blue BRZ yet on dark gray one and couple colors of FRS
Old 02-09-2013, 11:46 PM   #23
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
When my car was fully stock - I was getting about 320 miles per tank and filling up when the low fuel light would pop on. (~11-11.5 gallons) I was driving pretty conservatively - 3000-3500rpm shifts, coasting when I could, maintaining roughly 75mph on freeway.
After I switched to Dunlop Star Spec tires on the stock rims I dropped about 40 miles per tank (~3mpg). Before the tire switch I never really paid much attention to the term "low rolling resistance" with my tires but grip comes at a cost and seeing my mpg drop this much from a simple tire swap was eye opening.
If you've swapped tires, this may be something to consider if you're worried about fuel economy.
ImperiousRex is offline   Reply With Quote
The Following User Says Thank You to ImperiousRex For This Useful Post:
Dadhawk (02-10-2013)
Old 02-09-2013, 11:59 PM   #24
jrodz09
Drives: Subaru BRZ Lmtd
Originally Posted by Tylub View Post
i get 340-380 on avg.
most I ever got was like 420 something
Really? Whats the technique.. I've ran it till the low fuel light comes up, but not sure now in days how much is left till I go dry. Is it still 1 gallon left when low fuel light comes on?
Anyways well, I've been pulling the 3k shift points slow braking and I got 333 on my last. I also cruise control at 70mph.. Is there a sweet spot mph on this vic yet?
jrodz09 is offline   Reply With Quote
Old 02-10-2013, 12:02 AM   #25
crank
crank's Avatar
I am not worried about fuel eco honestly I am just worried something might be wrong with my car if I am getting what seems to be such a low tank range...
again stock tires, 6MT, 75 on the freeways 50/50 split
Old 02-10-2013, 01:34 AM   #26
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
I drove 68mph and avoid down shifting and just power through the 6th gear when I'm grannying the car
it's extremely boring and I don't recommend it unless you want every last MPG
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 02-10-2013, 02:22 AM   #27
zoomzoomers
zoomzoomers's Avatar
I think it has a lot to do with the fact that EPA numbers are estimates and are derived by testers who baby the car. Hence, maximizing their fuel economy.
My experience with my BRZ has been all over the place. When I drive mostly city (heavy stop n go) I've seen averages at 23 to 24 mpg. When I went on a long hwy trip I've seen averages at 37 to 38. Those are all when I'm really trying to maximize fuel economy. Now what I've learned is that our cars drink substantially more gas when you get a little bit heavy footed with the go pedal. When I drive aggressive, I've seen averages as low as 20 to 21 mpg. Of course, there is a big difference between driving with fuel economy in mind and driving aggressively, but I've noticed that if you drive these cars like it was designed to be driven you will nowhere near see EPA estimates. Not even close! The positive side to this is that if you do drive with fuel economy in mind you can, at least, get near the stated EPA estimates.
Old 02-10-2013, 11:23 AM   #28
Interesting, because I guess it depends on what you mean by "driving aggressively". I'm always the first one away from the light, and rarely take an exit ramp where I'm not having to brake because of traffic ahead. I usually downshift into the power band anytime I'm changing lanes or passing, and am usually running 5 to 9MPH over the speed limit.
I am still running the OEM tires which may account for some of it, and while I do commute in traffic my average speed is probably in the 45-50MPH range even though there is a quite a bit of stop and go.
Just shows how much it can vary from one situation to the next.
gas tank lid htdonato Issues | Warranty | Recalls / TSB 1 11-30-2012 03:43 AM
ENKEI Wheels **** In Stock List **** $1200 ~ $1900 Price Range RavSpec Wheels and Tires 0 10-24-2012 05:03 PM
Cruising Range? skoodge Scion FR-S / Toyota 86 GT86 General Forum 4 05-25-2012 03:31 AM
UK Price range £25-£32k!? ZeeSpeed Scion FR-S / Toyota 86 GT86 General Forum 56 11-27-2011 03:11 PM
Has anyone compared the rumored price range to.... demby123 Scion FR-S / Toyota 86 GT86 General Forum 22 10-09-2011 04:18 PM
