Old 02-08-2013, 05:43 PM   #15
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
Originally Posted by Chewie4299 View Post
If you don't have an Android phone you, sir, are doing it wrong.
Hater. :P
Skippman is offline   Reply With Quote
Old 02-08-2013, 08:01 PM   #16
Skorov
Skorov's Avatar
Drives: 86 GTS White
Excuse my ignorance on the subject, but could you explain how the AppRadio actually works? It seems that it does not have Android inbuilt, rather it is just a controller for your portable Android device. Is this correct?
If that's the case, does it rely in the power of the portable device it's connected to? Does it have a sound card good enough to output high-end quality sound?
Thanks for the write up btw. I had ignored this unit before I read this, but will now do a bit more research and consider it.
Cheers
Skorov is offline   Reply With Quote
Old 02-08-2013, 08:09 PM   #17
2forme
Cheers
It forms 2 connections with the guest device. One is over bluetooth (to transfer the screen "clicks"), and the other over HDMI (to transfer the image). Using the Pioneer app, you're limited to whatever apps, it approves (believe me, not many). However, with the ARLiberator app, you have full access to the guest OS.
So, you would use the AppRadio itself to play the FM and iPod. And use the guest device for everything else. The guest device needs to be rooted an support HDMI and Bluetooth. Since it transfers sound over HDMI, the head unit does all the work at converting the quality.
Old 02-08-2013, 08:21 PM   #18
Skorov
Skorov's Avatar
For things like, say... map calculations, does it use the guest device's processor or AppRadio's? In general, is the speed limited by the guest device's CPU?
I'll try to find a local unit and have a play. =)
Thanks
Old 02-08-2013, 08:38 PM   #19
2forme
Thanks
All the processing is done on the guest device. Think of it like remote desktop. You are "remoting" into the phone/tablet from the radio.
Old 02-08-2013, 08:40 PM   #20
Trac Toy
Trac Toy's Avatar
I'm going to guess that this thing should be able to connect to my samsung tablet so I can use torque, but will still be able to do the whole bluetooth bit with my iPhone so I can make calls?
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 02-08-2013, 08:42 PM   #21
2forme
That is a good question. If your Samsung tablet supports MHL/HDMI output, then yes it should work. Not sure if the radio can connect to two devices at once over bluetooth, though.
Old 02-08-2013, 11:31 PM   #22
Otterbrawten
Drives: Firestorm FR-S
Originally Posted by Skippman View Post
Hater. :P
Agreed... Love my iPhone.
Otterbrawten is offline   Reply With Quote
Old 02-08-2013, 11:47 PM   #23
DBacon1052
DBacon1052's Avatar
Drives: Argento FR-S
If we have a jailbroken iPhone, I think were doing just fine
DBacon1052 is offline   Reply With Quote
Old 02-09-2013, 12:27 AM   #24
xjohnx
Grip>Slip
xjohnx's Avatar
works the same with a jailbroken ios device. i may bite the bullet and get one. thankfully since it's a pioneer device the guys at oem audio plus may be able ot make it work properly with the rest of their system.
Old 02-09-2013, 01:57 AM   #25
ft_sjo
Drives: GT86
Just bought one... £199... Just need to find an iso adapter now (gt86)..
Old 02-09-2013, 03:41 AM   #26
Xdragonxb0i
Drives: ex500r
what phone are you using? Will GS3 work with it?
Xdragonxb0i is offline   Reply With Quote
Old 02-09-2013, 07:20 AM   #27
2forme
I'm using an HTC One S. There are videos showing the GS3 working. There is no app for this on the iPhone, even if it is jailbroken.
Old 02-09-2013, 07:55 AM   #28
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
@2forme YOU NEVER FAIL SIR! THANKS!
If you get time, can you make a video showing full functionality. Ie. Navigation while music playing (if thats even possible) Email, text messaging, netflix, internet, movies already stored on device, you know, the full works.
Also, here's a biggie... What about quad core devices like the GN2 that can run a split screen. Do you think this HU can mirror that?
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Who's interested in a full Android head unit? 2forme Electronics | Audio | NAV | Infotainment 307 10-05-2013 10:56 AM
recommendations for head units? knaa Electronics | Audio | NAV | Infotainment 45 01-10-2013 05:44 PM
Any Toyota/Lexus head units work? GTB/ZR-1 Electronics | Audio | NAV | Infotainment 1 11-04-2012 04:44 PM
Good double DIN head units YW-Slayer Electronics | Audio | NAV | Infotainment 3 07-21-2012 10:57 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
