Old 11-04-2011, 05:00 PM   #323
PAImportTuner
Turbo Mafia Presidente
PAImportTuner's Avatar
Drives: U Mad?
Originally Posted by Ryephile View Post
Um, no. Otherwise, Formula 1 would ditch their center-lock and go for an old-skool wide-5.
The bolt pattern's only job is to maintain a frictional interface between the wheel and the hub. The only reason to complain about the bolt pattern is because your favorite wheels aren't made in that pattern, which means you'll have to suck it up, deal with it, and either re-drill the pattern or find a new set of wheels that are in 5x100 with about a 48 offset, of which there are tons to choose from.
Yep, but if it's the 5x100 from Subaru's parts bin then you'd know that the bearings on their 5x100 majorly suck when combined with wider and stickier tires.
I've went thru a lot of them.
"the FR-S is going to have to give me a blowjob every time I touch the steering wheel if all it can make me smile with is the handling." - Maxim
PAImportTuner is offline
Old 11-04-2011, 05:18 PM   #324
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Stickier tires isn't the problem w subie 5x100. Wide offset cause fast wear down.
My friend have sedan ver Impreza (GC6) and had stock wheels (16x7) w sticky tires for 9 yrs... close to 10 yrs (of course tires been replace every 1~2 yrs due to tracks/autox) and not til this yr he had to replace the bearing. vs me w 17x7.5 lil bit crazy offset first yr into crazy wide wheels, bearing went out... and next yr prob need to replace the again (4yrs since replaced it).
ichitaka05 is offline
Old 11-04-2011, 09:24 PM   #325
Dragonitti
Originally Posted by madfast View Post
define out perform. and at what boost?
the problem is that there are very little SC kits out there that are properly designed
Do you know how a Centrifugal supercharger works? Properly designed? That don't make much sense to say that when the companies that produce S/C'ers have been doing it for decades.
. its really that simple. they either use old gen eaton roots blowers, or they dont have an integrated intercooler, or they use a vortech/non-rotrex style centrifugal kit with or without intercooler. ALL of those are NOT up to par with a turbo. i dont think anybody will disagree.
however im talking about the new age of supercharging. either a 6th gen eaton TVS or twin screw design. both offer adiabatic efficiency in the 70% range and some approaching 80%. they can run more boost, more efficiently. AND most modern kits have an integrated water-air intercooler.
Intercoolers add thermal efficiency but it's not a deciding factor between a S/C'ers efficiency compared to a turbo's efficiency.
so why doesnt anybody make they awesome kits for 4 cyl imports? CULTURE. the "import culture" has always embraced the turbo. maybe because the best imports (gtr, evo, sti, supra, rx7, etc) had factory turbos, maybe because the older gen SC's have a bad rep, etc. but the fact of the matter is, if you look at the domestics, they embrace the SC over the turbo. its part of their culture to slap a blower on. the result? AMAZING kits from lysholm, whipple, magnuson, vortech VTS, roush, edelbrock, kennebell, etc... again, not to say there are no turbo domestics, but if you want FI the common route is SC over turbo. for imports its turbo over SC.
Thanks for confirming what I already wrote. If it's a V8 then the difference is minor from S/C to turbo on the same applications. Everything you listed was American Muscle V8's. They are not Import Motors.
so the bottomline is to not compare a well engineered turbo kit with a crappy second thought SC kit. the FACT remains that a SC will give you a better boost curve given MODEST boost levels.
Still not true
minimal lag is still lag. you cannot change this fact, lest you run WRC-style ALS on a street car. for some it makes a difference. for others it doesnt. the tq curve of a turbo engine will not be as flat as a SC. again, for some it matters and for some it doesnt.
Bro, Minimal lag is basically nonexistant. I'm talking "Not noticeable" minimal lag. And lag in a turbo is still more efficient than the Centrifugal S/C design. And the Torque curve of a turbo depends on the turbo. You can change the curve simply by changing the turbine size. Not all S/C'ers produce a flat torque curve just like not all turbo sizes create a flat curve. You shouldn't generalize in that fashion because of a little thing called tuning.
it may not be more efficient, but the efficiency is coming increasingly closer to a turbo. some SC literature/advertising even claim better efficiency. but i digress. its not always about efficiency. sometimes the boost curve/torque curve and the driveability of it is more important to you than numbers...
Power is not included into subject of Efficiency.
Originally Posted by Kostamojen View Post
Says you!
I'd be perfectly happy with Subaru or Toyota take-offs. I could care less about spending obscene money on wheels.
My only concern is the offset, but I suspect they will be Subaru offsets (Between +48 and +55)
I'd take them too. But there is a reason why those wheels cost more money. Design is part of the equation. Albeit you do pay for a name as well.
Like I said, I'm going to be running a set of 18x10 XXR's on the tC and XXR's are cheap.
I would prefer a set of CCW's though. Eventually I will pick up some CCW's.
Dragonitti is offline
Old 11-04-2011, 09:31 PM   #326
Dragonitti
Originally Posted by Snoopyalien24 View Post
http://forums.nasioc.com/forums/show....php?t=2224971
For the millionth time I've posted this link here
There are lots of choices for 5 X 100
Think about this... Company xxxx sees that the fr-s suddenly becomes a popular car.. I think the company, being smart, will start releasing more variants in that size, because of the sudden interest. All major rim brands can have special order placed if you are really that desperate lol
One wheel? And that wheel was JUST released.
Originally Posted by cyde01 View Post
i like the look of deep offsets and concave faces as well. but to get a concave face you typically need at least 17x9, which would prob be a little overkill unless you really boosted this thing no?
300whp in this little car is plenty to need a 9 incher under the chassis
In your words, "minimal lag". That means they still have lag. For those of us that prefer, or insist upon n/a or SC "instantaneous" feeling, turbo's still can't cut the mustard.
Only a Roots Type S/C is instant boost. Not all of the S/C'ers are instant.
Old 11-04-2011, 09:38 PM   #327
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Actually it is still a rumor that it is using 5x100 bolt pattern. It's nowhere in the current specs...maybe we will find out for sure at the tokyo motor show...
tripjammer is offline
Old 11-04-2011, 09:46 PM   #328
Kostamojen
The 5x100 was by deducing what wheels have been used on the spy shots and display models/prototypes.
Kostamojen is offline
Old 11-04-2011, 09:56 PM   #329
Dragonitti
Both are tC's. My boy's tC is a 2008 and mine is a 2006. Both are running GT3076R turbo's except I'm running a Tial SS housing on mine so my turbine is actually a little lighter than his in weight. But tuning makes a difference as well as the variation in the head design when made slight changes to the internals of the 2007+ tC's.
His
Mine
Old 11-04-2011, 10:02 PM   #330
sfwg
Drives: 2007 saturn ion(dd)
his
2014 FRS
sfwg is offline
Old 11-04-2011, 10:11 PM   #331
coyote
coyote's Avatar
Drives: Slowly
Incorrect
The combination of sticky tyres, high cornering forces and high brake temps kills those old wheel bearings.
I had two sets of sets of hubs at one stage. One on the car and one getting new bearings.
Went through 7 sets of bearings - using standard wheels.
The move to 5x114.3 came with bigger hubs and bearings, but even the newer 5x100s are much better than the old ones.
coyote is offline
Old 11-04-2011, 10:51 PM   #332
tripjammer
tripjammer's Avatar
Prototypes yes...but not the display models. Somebody use CSI on the new high res pic and see if the rims are 5x100...
Prototypes are prototypes...there could be some out there with 5x100 and 5x114.
Old 11-05-2011, 12:07 AM   #333
Dragonitti
Originally Posted by sfwg View Post
his
You do not pass go, do not collect $200...lol. Anyhow, he wants my torque curve.
Old 11-05-2011, 02:20 AM   #334
madfast
Drives: 2010 Evo X MR-T
again, who's talking about centrifugal superchargers? the whole discussion was about a possible TRD Roots SC... and in that regard there are little to no companies making roots kits for import engines let alone small displacement 4 cylinders. that's what i mean by "properly designed". most of the roots kits use older eaton units and are most likely not intercooled.
i never said intercooling had anything to do with efficiency. when i talk about intercooling it is in regards to the fact that most import roots SC kits dont use them. as for efficiency, the newest TVS and twin screw designs have efficiency in the 70%, close to 80% range.
that's my point. all the hig quality roots SC kits are made for domestic large displacement engines. if someone cared enough to use them on a small displacement engine, i think you'd be surprised just how much you can get out of them.
again, what's with you and centrifugals? no one is talking about centrifugals. the whole discussion was about roots blowers. and roots blowers have NO lag, make boost linearly, and DO give you a flatter tq curve boost for boost.
this is a 2.0L ecotec (on 100 octane)
and this is a RSX with a custom lysholm kit (@16.4 psi)
find me a turbo 2.0L 4 cyl that makes that much power with a flatter tq curve.
who said anything about power?
madfast is offline
Old 11-05-2011, 02:52 AM   #335
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The race car used 5x100. It will be 5x100.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 11-05-2011, 04:53 AM   #336
ichitaka05
Site Moderator
ichitaka05's Avatar
Originally Posted by coyote View Post
Incorrect
which car did you try em on? Also 7 bearings? In how many yrs? Cuz if you gotta replace bearing that much, there's something wrong. Even w my 17x7.5 w crazy offset plus half dozen track time in summer, it lasting me for 4 yrs.
Friend's GC6 on track Hoosier R series, summer Potenza RE series and winter some kind of Pireilli. Track close to dozen time in summer plus auto-x half dozen times, 3~4 times in winter and hub lasted him 9yrs (close to 10 yrs)... & MMP track isn't slow corning and it require pretty hard braking.
fr-s trd, fr-s trd parts, frs trd, ft-86 trd, ft-86 trd parts, scion fr-s trd, scion frs trd, toyota ft-86 trd, trd fr-s, trd frs, trd ft-86, trd scion fr-s, trd scion frs, trd toyota ft-86
How much would custom parts be? LexusFman Other Vehicles & General Automotive Discussions 10 07-23-2012 12:59 AM
How do you buy aero kit / TRD parts? scwewywabbit Scion FR-S / Toyota 86 GT86 General Forum 25 03-17-2012 10:45 PM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
after market parts serchmarc Scion FR-S / Toyota 86 GT86 General Forum 90 05-31-2011 08:18 PM
