Old 01-24-2013, 12:58 PM   #15
CaptainSlow
CaptainSlow's Avatar
Originally Posted by mhigham View Post
How do they miss this? Or the trunk pop? Or the idle issue? Or the chirping?
These are all issues they knew about but rushed into production. I am sure they will all be fixed for 2014, but we suffer in the meantime. Price we pay for being first.
Mike
Even the simplest car is an extremely complicated machine...you also have to remember the difference between a development vehicle and production. There is a lot of stuff that changes between the development and production stage, and sometimes those changes translate into minor little issues that can be fixed later through warranty work, TSBs, etc. The truth is that when you are in development your sample size is relatively small...when you get out into production, the sample size increases exponentially, and sometimes things happen that you can't see or predict on a small sample size.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 01-24-2013, 02:26 PM   #16
Mac1235
Mac1235's Avatar
I don't know why we keep talking about TSB for this kind of thing, this is a 5 minute fix TOPS. I fixed it in 5 minutes and there is no noise at all now. It was a place to cut corners in terms of cost and weight. Put in 5 minutes of effort guys and lets move on to problems that really need a TSB, this is not one of them.
Mac1235 is offline   Reply With Quote
Old 01-24-2013, 02:51 PM   #17
CaptainSlow
Originally Posted by Mac1235 View Post
Here is the fix boys or at least so far for me. If you take the bottom panel off there and look under the dead pedal it is basically a piece of like styrofoam underneath to provide a base. This piece will rub against the metal and make the noise. You can use silicone sealant and just bead that baby up and it wont pop or squeek anymore. It has been working for me for about 2 months now.
Thank you for this - could you take a picture of the "Bottom Panel" you mentioned? Or at least explain that part a little better? I plan to do this when I get the car, as it seems like a common issue...thanks for the solution! You should post in the DIY section, for sure!
Old 01-24-2013, 03:58 PM   #18
Mac1235
Mac1235's Avatar
When I get a chance to take it off I will post some pictures. Kind of waiting on this insane cold spell to pass before I mess with the car any.
The Following User Says Thank You to Mac1235 For This Useful Post:
cmspooner (01-30-2013)
Old 01-24-2013, 05:15 PM   #19
mhigham
I understand that and appreciate it. I work in automotive R&D for a large automaker. Development ceases at a set point and no other changes are allowed, and test vehicles are built using production parts and assembly techniques. My point is all the issues would have been seen during this testing, and it was decided to forego making anymore changes and start productions with known "defects" - idle, deck pop, GPS, dead pedal, etc. It just seems like a car with so much riding on it, they would allow so many little things, and a few big ones like the ECU, to follow into production.
The testing is so rigorousness on cars, there is NO WAY every one of these issues wasn't seen, duly noted, and then ignored to rush production. Trust me, much smaller issues that the customer would probably never be aware of are usually caught during testing every day where I work.
mhigham is offline   Reply With Quote
Old 02-03-2013, 03:39 AM   #20
mikeg7827
mikeg7827's Avatar
Drives: 1995 Ford Probe
YESSSS IM HAVING THE SAME ISSUEE!!! ITS SO ANNOYING LOL
sorry for the caps.. i thought i was the only one..
so this is my 3rd problem with the car after the TL condensation, fuel pump chirp now the foot rest lol
mikeg7827 is offline   Reply With Quote
Old 02-07-2013, 01:33 PM   #21
Stav
Stav's Avatar
Drives: 13' FR-S Argento,74' Alfa GTV
Same here, must be a small design flaw. The pics would be really great for a dumb ass like me.
Thank you
Stav is offline   Reply With Quote
Old 03-07-2013, 12:14 PM   #22
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
so i didn't hear it much recently up until yesterday when the slightest touch would make all kinds of popping/grinding/clicking noises. I just looked at it and i noticed some of the clips going down the middle didn't seem secure. I just yanked at it and all the clips came out. I then held it down tight and put the clips back in, tapping them with the handle of my screw driver to make sure they were all the way in. Seems to have stopped it for now. Might just be the clips don't stay in properly all the time
abutterman is offline   Reply With Quote
Old 03-07-2013, 05:02 PM   #23
tripjammer
tripjammer's Avatar
Drives: WRB BRZ limited 6MT
Here is how you fix this problem. Take out the two Clips that hold in the foot rest, and put some kind of lube on them and then reinsert them and your popping noise problem will be solved. Get you a set of panel popping tools to remove those two clips. These clips are metal. They are kinda hard to get out. I would also try to look for some new ones from the dealer. They might have made them better over the last year.
Mine is not making any noises now. All I did was spray some electric contact cleaner on the end of each clip and then inserted them back in and I was good. If anybody knows of any better lube let me know.
tripjammer is offline   Reply With Quote
Old 03-07-2013, 05:08 PM   #24
RYU
RYU's Avatar
Drives: really slow...
I have this. C'mon... it's fun. I play with it everyday in traffic. Press up > Pop. Press down > Pop. Rinse and repeat.
RYU is offline   Reply With Quote
The Following User Says Thank You to RYU For This Useful Post:
foxhu (03-08-2013)
Old 03-08-2013, 01:52 AM   #25
foxhu
tell me about it haha
foxhu is offline   Reply With Quote
Old 03-18-2013, 01:04 PM   #26
kingping
Drives: 2013 Subaru BRZ Premium, manual
Same issue here...
Maybe when I'm feeling energetic I'll fix it. Minor...
kingping is offline   Reply With Quote
Old 03-18-2013, 02:21 PM   #27
abutterman
abutterman's Avatar
in my case the problem was that even after lubing it up, it would move around so much with the clips all the way in that it would start acting up again. anyways, subaru gave me an awesome deal on a trade in for a brz limited so i took it. the dead pedal feels much more solid in this one and i haven't had any weird sounds coming from anywhere yet. time will tell though...
Old 03-19-2013, 12:38 AM   #28
fistpoint
Drives: Supercharged Golf Cart
What direction do you move your foot to make the noise? As far as I can tell, mine is fine. Serial is 20000+, January 2013 production.
fistpoint is offline   Reply With Quote
Rear Deck "popping/clicking/tapping/ticking" noise. Sigh-on-Rice Issues | Warranty | Recalls / TSB 637 04-28-2020 05:55 AM
Foot Well Mood Lighting BigJyoungblood Cosmetic Modification (Interior/Exterior/Lighting) 189 06-01-2017 12:21 PM
Factory rust protection in foot well Ben_G CANADA 0 01-20-2013 12:32 PM
The number 86 popping up everywhere.. CSSM Off-Topic Lounge [WARNING: NO POLITICS] 19 06-19-2012 12:15 PM
