| AUSTRALIA Australia and New Zealand |
Drives: 86
Some observations
fitted the scangauge on the 86 over the weekend and observed a few things after a few days driving.
- the stock intake is quite good. on the move it's around 4-5 degree above ambient temperature (reading off the external temp figure of the factory dash). which is pretty much similar to what my old Type R with a CAI installed. - the water temp gets up quite quickly. it shows about 80 degrees after around 5 minutes of normal driving. once it's warmed up it's around 90 degrees and stays there. |
#2 |
Mad Sciontist
Drives: gt86
Water temp rises quick due to the d-4s system for start-up benefits, port injector is used on the down stroke of the piston to create lean mixture then direct injector is used on the upstroke to correct the lean mixture and allows it to retard ign more than usual, increasing EGT and warming engine up quicker
#3 | |
Drives: 86
#4 |
Mad Sciontist
Drives: gt86
lol, i have to do my homework if im going to be boosting and tuning lol.
#5 |
Drives: GT86
clever cookie indeed
#6 |
Mad Sciontist
Drives: gt86
Also im loving the fact that it only uses the direct port injector at high rpm, meaning there it more than enough fuel delivery between the 8 injectors for FI. Running only direct injector would mean the intake temps would be really REALLY low
#7 |
Drives: 86
which means the engine is pretty efficient already!!
#8 |
Mad Sciontist
Drives: gt86
probably should of studied it before i bought a ls7 crate motor lol.
#9 |
Drives: Sonic Blue 86GT Manual
#10 |
Drives: 86 GTS
dug this out of the grave to see if anyone here has played more with the scangauge, Ill have a mess when i have time, want to see if i can get oil temp up... the ecu does provide and you can program the scangauge to accept new gauges...
#11 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Not using scan gauge though, usng HKS OB-Link. All of the above are in Celsius. Water temp for me is like above - hits and stays at around 90 Celsius. .
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
#12 |
Drives: 86 GTS
cheers. I wonder if someone has the code for 86 oil temp for the scangauge... ill see what i can see..
#13 | |
@andreyiv found the oil temp PID and posted it here http://www.ft86club.com/forums/showp...&postcount=123 If you can add this into the scan gauge then you may be in luck. .
#14 |
Drives: 86 GTS
cheers, i might have some time tonight, see how i go
| 1st Oil Change Experience, Observations & a Surprise | Black Tire | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 100 | 09-14-2015 09:23 PM |
| First Payment sent, Observations after 6 weeks. | Scooby South | BRZ First-Gen (2012+) — General Topics | 27 | 08-01-2012 02:02 PM |
