Old 11-02-2011, 11:02 PM   #253
Nambo
Nambo's Avatar
Drives: '12 BRZ [CBS]
Wow! Awesome info, just in time for lunch time reading.
Thanks Hachi and Aki for releasing and translating!
Nambo is offline   Reply With Quote
Old 11-02-2011, 11:06 PM   #254
Dragonitti
Hope those internals are thick. 12:5.1 isn't exactly a friendly ratio for throwing F/I on it. Then again, it's running 4 injectors, which is a lot of fuel if you are upgrading them. A few psi will crank out some power at that compression, but it's sketchy.
Old 11-02-2011, 11:29 PM   #255
Matador
hashiryu
Drives: Mk4 Supra
Originally Posted by Leeky View Post
Its never going to be worth turbocharging this engine if you ask me. The Direct injection and compression just get in the way too much. It'll take a lot less time and money to swap in the Impreza STI 2.0 or 2.5 lump and be done with it.
This is a genuine fear of mine. I do believe this engine has tuning potential. Enormous in fact, and with that, the potential and incentive to unlock the secrets of Toyota's ECU and the D4-S system on their V6 and V8 motors.... However, theoretically it might be so easy to drop in a turbo EJ motor, most ppl just won't bother. Until some bold person steps up and makes some beastly gains while boosting this motor, swapping might just be the ticket, and that would be such a shame.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 11-02-2011, 11:29 PM   #256
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by Kostamojen View Post
I wanted to note this for the people new to Subaru motors here, but Subaru's ALWAYS have a funky dip in the torque curve, supposedly its due to the intake manifolds but I'm not 100% on this.
...stuff
Direct injection is not for high rpm, it is for high torque requirement aka throttle position.
Funky dip in torque curve hmmm...actually you may be right, AVCS is continuous so it can't be that, perhaps it is the intake manifold resonance properties.
Actually I went back and looked, I think it may be that AVCS was not continuous until recently. That would explain it.
The FT curve as I said, is copied from an old Toyota article. For all I'm concerned, it is a 100% match.
Old 11-02-2011, 11:30 PM   #257
Allch Chcar
Drives: N/A
Originally Posted by iggyhop9 View Post
27.5 inches of rear legroom. For comparisons sake, 1st gen IS300 had 30 inches and the last gen Celica had 27
27-33" is the average range for this segment.
Don't worry Dragonitt, I'll get E85 figured out and you'll be running 20lbs on stock internals before the year ends.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 11-02-2011, 11:36 PM   #258
Giccin
Giccin's Avatar
Your link posted in your sig is considered an "attack" page.. or a page that contains a Virus. lol
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 11-02-2011, 11:37 PM   #259
themali
Drives: Ninja 650R
Originally Posted by Liftcontrol View Post
100hp/liter, normally aspirated; Not bad
seems average. I was hoping for 110 hp/l, especially with that compression ratio. compared to the Honda K20A which was over ten years ago.
Engine type K20A
Cylinders/valves Watercooled IL-4
Bore and Stroke (mm) 86.0 x 86.0
Piston displacement (cc) 1998
Compression ratio 11.5
Max power (NET) kW(PS)/rpm 162(220)/8000
Max torque (NET) N.m(kg.m)/rpm 206(21.0)/7000
themali is offline   Reply With Quote
Old 11-02-2011, 11:38 PM   #260
skinsfn36
skinsfn36's Avatar
Drives: 2006 Honda Civic Si
I think this motor must be held back somehow(possibly the cat(s) for emissions), I think with a good tuning solution and full NA bolt ons, one can hopefully expect 220whp
skinsfn36 is offline   Reply With Quote
Old 11-02-2011, 11:39 PM   #261
serialk11r
Engine type K20A
Exactly, this is why there's reason to believe there is untapped potential and possible future improvements. Remember, single cam profile! If they throw Valvematic on this it can easily gain another few hundred rpms.
Old 11-02-2011, 11:44 PM   #262
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
That's exactly what I am aiming for, if FI is too much $ and unreliable.
KaliKev is offline   Reply With Quote
Old 11-02-2011, 11:46 PM   #263
serialk11r
220 not at the wheels, at the flywheel I think so. 220 at the wheels is like 250 brake, which is not happening at this rev limit.
Old 11-02-2011, 11:48 PM   #264
Allch Chcar
Drives: N/A
Huh, I wonder when that happened. It was fine for years, I even checked it before I linked it. They must have been attacked recently. I'll remove it for now.
Thanks Giccin!
-Allch Chcar
Old 11-02-2011, 11:53 PM   #265
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Yeah what's up with the Center of gravity? Not that it isn't bad, but, wasn't it supposed to be the lowest?
Snoopyalien24 is offline   Reply With Quote
Old 11-02-2011, 11:56 PM   #266
Snoopyalien24
Mr. Sarcasm
What type of bolt ons do you mean?
Official FT-86 Specs / Info Thread Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 203 09-09-2019 11:43 PM
FT-86 / FR-S size dimensions compared to Genesis, Civic, Sction tC, etc JDMinc FR-S / BRZ vs.... 559 05-15-2014 08:50 PM
Engine technology thread. Dimman Engine, Exhaust, Transmission 762 04-12-2012 03:18 PM
Ducati 1199 Superquadro engine specs RRnold Other Vehicles & General Automotive Discussions 9 11-21-2011 02:36 AM
86 Drag car?!?! MtnDrvr86 Other Vehicles & General Automotive Discussions 5 01-14-2010 07:35 PM
