Old 02-02-2013, 01:11 AM   #729
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by sierra View Post
Is everyone taking off the original strut support?
imma leave mine for a bit jus in case. then off it comes
lbroskee is offline   Reply With Quote
Old 02-02-2013, 01:17 AM   #730
Brimford
Drives: Whiteout / MT FR-S
Were you guys closed today? I tried to call a few times to place my order and left a message
Brimford is offline   Reply With Quote
Old 02-02-2013, 01:51 AM   #731
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Think I saw a post on their FB page that they were having issues with a mail server. I wouldn't doubt their use phone use ramped up as a result.
CircuitJerk is offline   Reply With Quote
Old 02-02-2013, 07:45 AM   #732
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
As soon as I had both dampers installed, I detached that fiend and THREW IT ON THE GRROOOOOUUUNNNNND. Literally.
Also, because weight-savings.
The Following User Says Thank You to chanomatik For This Useful Post:
OrbitalEllipses (02-02-2013)
Old 02-02-2013, 08:31 AM   #733
lbroskee
lbroskee's Avatar
And because racecar
The Following User Says Thank You to lbroskee For This Useful Post:
chanomatik (02-02-2013)
Old 02-02-2013, 08:34 AM   #734
sierra
Drives: Skoda Yeti DSG diesel 4x4
Makes sense. We can't use it with the gas struts so best to tuck it away, just in case.
sierra is offline   Reply With Quote
The Following User Says Thank You to sierra For This Useful Post:
Old 02-02-2013, 09:00 AM   #735
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
Nope, we were open, but as was mentioned, our email server was down so both lines were ringing off the hook all day. Sorry we missed you! Everything should be back to normal on Monday, so if you don't get a reply to your message, give us a call and Matt or Mike will get you all taken care of!
Matt
Engineering
GrimmSpeed is offline   Reply With Quote
Old 02-02-2013, 09:28 AM   #736
Jacob G.
Jacob G.'s Avatar
Drives: '13 Scion FR-S Whiteout
Went to check the mail this morning before the mail person arrived for the day and what did I find? My grimmspeed hood struts! Wow was that fast shipping! Thanks a lot guys I'm going to hopefully install these today
Jacob G. is offline   Reply With Quote
Old 02-02-2013, 12:10 PM   #737
lbroskee
lbroskee's Avatar
love em! and makes open/close of the hood a 2 finger operation
Old 02-02-2013, 02:33 PM   #738
GrimmSpeed
GrimmSpeed's Avatar
Looks great! Glad you like them!
Old 02-02-2013, 02:35 PM   #739
lbroskee
lbroskee's Avatar
i do have 1 question tho.... i received 4 bolts. only 2 of them seem to b used (per your guide). are the other 2 just extra?
Old 02-02-2013, 02:39 PM   #740
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
You should've used all four size 13 bolts for the top of the dampers that attach to the hood. The bottom ones are what the bracket slide into (that's two), then the top ones you place after the brackets are slid in (the other two). The only ones reused are the size 10 bolts on the bottom that attach to the chassis.
Old 02-02-2013, 02:41 PM   #741
lbroskee
lbroskee's Avatar
o oops, i thought u just slide into the 10 mm bolts then retighten (fits fine and tight anyways)
Old 02-02-2013, 03:15 PM   #742
Foobar
SLO NO MO
Foobar's Avatar
That won't be a good fit since it'll be at an angle due to the top part resting against the top bolts. I can't imagine that would last for too long after vibration. Get that fixed asap.
The Following User Says Thank You to Foobar For This Useful Post:
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
Stock Springs/Struts FRS jadewbj Brakes, Suspension, Chassis 1 12-18-2012 10:00 AM
WANTED (GA) - Stock FR-S/BRZ struts xwd Brakes, Suspension, Chassis 8 11-07-2012 10:43 AM
performance/aftermarker struts karma003 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 09-07-2012 11:26 AM
JDM BRZ Struts different than USDM BRZ Struts? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-30-2012 10:21 AM
