Old 02-01-2013, 01:21 AM   #2465
jrodz09
Drives: Subaru BRZ Lmtd
Originally Posted by BRZnut View Post
The problems should have been fixed for you at the factory...keep us posted on the rough idle.
Will do.. Is there a page for vins like mine that still have reoccurring problems? I don't now much about this tranny, but i get that weird feel with the clutch, and rough shifts.. they don't happen to in very smoothly. Makes me kinda sad, especially when my 1992 Honda Civic VX (DD) shifts more smoothly than this 2013 model car. We'll see..
jrodz09 is offline   Reply With Quote
Old 02-01-2013, 02:24 PM   #2466
JSUB
JSUB's Avatar
Drives: 2026 BRZ tS coming
Originally Posted by JSUB View Post
JSUB, BRZ, 1246 km, Canada, waiting for ECU software upgrade (ordered by dealer).
While waiting, dealer told me ok to drive it even if CEL on.
Dealer re-flashed the ECU (had P0019 code I believe). Engine running just fine for now. Have close to 3k KM now.
JSUB is offline   Reply With Quote
The Following User Says Thank You to JSUB For This Useful Post:
eurospeed (02-08-2013)
Old 02-01-2013, 03:24 PM   #2467
ftc~brz
Done
Drives: WRB BRZ
Originally Posted by Marrk View Post
"swapped the valves" ? I'm not sure what this means, nor do I recall seeing anything about swapping valves in this thread. Maybe I missed something (?).
Could you explain?
Thanks.
what they did to mine. cam shafts and lsv valves for 1st fix. Lorton is about 2 hours from me would have been worth a drive to the dealer that fixed mine. Oh well, ECU flash is his next step. GL to him
ftc~brz is offline   Reply With Quote
The Following User Says Thank You to ftc~brz For This Useful Post:
MVJ1975 (02-01-2013)
Old 02-01-2013, 06:06 PM   #2468
Marrk
Drives: Honda Fit
Never heard of lsv valves. Have to look that up. Thanks.
Marrk is offline   Reply With Quote
Old 02-02-2013, 06:29 AM   #2469
ladios
Drives: toyota 86
I found a place to make water and soil into the car inside,
right side
left side
here is the route,
right side
left side
Normal there is a cover,but that cover can not block all of water and soil ,When Factory technician remove the cover,this two holes is exposed in my eyes,this two holes did not Sealed is Normal?
ladios is offline   Reply With Quote
Old 02-02-2013, 06:26 PM   #2470
jrodz09
Well guess what guys! To my luck I finally got that CEL! Right after I left the Evasive Motorsports location. Guess none of this cars are safe to the CEL code fever yet. VIN#6055xx. Anyways ran it to the nearest Subaru dealer in Puente Hills. The services dude started as a douche bag, but once I told him that I was from Pendleton his attitude changed. LOL. Anyways, told me it was a "hard code" a "stability control code". They couldnt have it done by end of day. So I told him I was just going to take it to Bob Baker Subaru in Carlsbad. Don't want to name drop, but their customer service is terrible. They said they were closing and couldnt get me a loaner or a rental and that I could drop it off as a "night drop" but I need to find my own way home. Basically saying that I was SOL (shit outta luck) I asked. Can anyone just drop me off on base? She said NO!. So just in case if you find yourself stranded and have to make it to that dealer you already know what to expect. Will be taking it there Monday after work. No choice.. nearest dealer.
BRZ/860miles/CODE-Stability Control?/dealer on monday
The Following User Says Thank You to jrodz09 For This Useful Post:
Old 02-02-2013, 10:03 PM   #2471
BRZnut
Drives: BRZ DGM Limited
Keep us updated...sounds like something new compared to the other idle issues?? See if you can get the actual code number.
The Following User Says Thank You to BRZnut For This Useful Post:
ftc~brz (02-07-2013)
Old 02-04-2013, 06:20 PM   #2472
jesperswe
Drives: GT86
Anyone noticed excessive engine vibration when stationary and idleing when the engine is cold? Goes away as soon as the engine is hot.
jesperswe is offline   Reply With Quote
Old 02-04-2013, 07:54 PM   #2473
MVJ1975
Automatic Hooligan
MVJ1975's Avatar
Error code was P0018. Fixed by replacing a cam sprocket. We'll see how long the fix lasts but it's stable for the moment.
MVJ1975 is offline   Reply With Quote
Old 02-04-2013, 08:21 PM   #2474
zoomzoomers
zoomzoomers's Avatar
I've always said that this motor doesn't seem to warm up very quickly or well. When cold a lot of weird things seem to happen as opposed to when warm.
Old 02-04-2013, 09:07 PM   #2475
BRZnut
Yes...engine is very rough when first started, esp when its cold out. Much rougher than other cars I've owned. Are all boxer engines like this??
Old 02-04-2013, 11:42 PM   #2476
zoomzoomers
I'm convinced that or cars have a terrible alternator. Hence the idle dip.
Old 02-05-2013, 03:12 AM   #2477
kroarke
kroarke's Avatar
#219 UPDATE.
Dealer replaced cam sprocket. Car was in the shop for 3 days. Everything seems ok. The rear headlight filled up with water just before I took it in to have the work done. They replaced that too. They must love me. lol. Ill let you know if anything happens.
kroarke is offline   Reply With Quote
Old 02-05-2013, 12:46 PM   #2478
jesperswe
Drives: GT86
I've always thought that the boxer engine was very quiet and "low vibrating" because of the design with opposed pistons.
I've never had a car with such rough engine condition when its cold.
NW Owner List & Event Archive DarrenDriven Northwest 1643 08-05-2016 07:48 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 11:42 AM
Idle issue scioneric CANADA 23 08-24-2012 02:40 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 01:00 PM
An unofficial message from TMCA Courtz1074 AUSTRALIA 25 05-17-2012 11:00 AM
