#85 |
Drives: FRS
UPDATE:
It has been confirmed that the IS300 doesn't come with a final drive of 4.55. I just got off the line with the Lexus parts department in my area.... What I have learned: The IS300 and IS250 have different differentials as well as different axles. There is no way both of them will bolt on to the 86. It would have to be one or the other as they bolt up differently and have different axles. Also, even if one did fit, they never came with a 4.55 final drive, at least not in the USA. Seems that my dreams of an easy swap have been destroyed. Carry on.... |
| The Following User Says Thank You to wootwoot For This Useful Post: | duder (06-01-2013) |
#86 |
Drives: GT-86
The cusco 4.55 is a direct swap? no mods? just take out the old put in the new and boom?
#87 |
#ProjectBRZ
Drives: SWP BRZ
I will def. be looking for more info on this. Its funny, I have never heard or thought about doing it before and my friend actually suggested it a lunch today before even seeing this.
thanks RCE! |
#89 | |
Myles |
#90 |
#91 |
Drives: 2013 fr-s
wow, this is a refreshing post! I've been trolling this forum and haven't seen anything like this yet!
Good information. Keep on posting! |
#92 |
Drives: 2013 Scion FR-S MT Ultra Marine
If you switch to a 4.55 FD, won't that lower the shift points on your car? For example, let's say I am on a track with the stock FD and I come up to a corner that I can take with an entry speed of around 55 mph and an exit speed of about 50 mph after i pass the apex. With the stock setup I would take that corner in second gear because my shift point is 59 mph. With a 4.55 FD I would probably have a second gear shift point around 50 mph. With the stock FD I can accelerate faster out of the corner in second gear then I would if I had to exit that corner in 3rd gear with a 4.55 FD because my stock second gear is still more aggressive than a 4.55 FD 3rd gear. Granted, I'll have to up shift into third shortly after I pull out of that corner, at which point the 4.55 FD will have the advantage in acceleration because his 3rd gear is better than mine.
But the point is that wouldn't the optimal final drive have to depend on the track you are racing at?
2006 Corolla XRS 2ZZ-GE
2013 Scion FR-S 4U-GSE |
#93 | |
The other thing is and I see it in my students for the last 15 years, is the tendency to buzz around in the lower gears which makes the car MUCH more jerky when you lift a hair which causes weight transfer and loose handling. Its better to commit to the taller gear and put your foot down and save a shifter later when its possible. Myles |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | CxG (08-05-2015) |
#94 |
[ame="http://www.youtube.com/watch?v=iGFHgbe0Epw&feature=player_embedded#"]86 TRD Griffon Concept(タイãƒ*アタックãƒ*ービー) - YouTube[/ame]!
aside from how SICK this car sounds, I think this car runs the 4.81 final drive ! At 2200 lbs its sick ! Enjoy! |
| The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post: |
#95 | |
Drives: '06 AM V8V Coupe
80mph in my car is about 4400, my ears are bleeding by 3700 already. I DUN GET HOW PEOPLE CRUISE AT 5000 RPM |
| The Following User Says Thank You to serialk11r For This Useful Post: | muffinman (03-04-2013) |
#96 |
That Griffon vid is awesome.
#97 | |
#TrackAddicts
Drives: The Dipped Car
Racecomp Engineering / FT-86 Speedfactory / Essex / Counterspace Garage / Topspeed Motorsports / Forged Performance Chadbee Photography / Passion Moves Photography |
#98 |
Drives: Attitude
My WRX was at 3500-4000 by 65-70MPH...it was hellish. 3" turboback and straight through muffler. Sounded glorious, but the drone...never again!
| Tags |
| cusco final drive |
| PST Carbon Fiber Drive Shaft Installed | msile | Engine, Exhaust, Transmission | 155 | 08-28-2018 07:53 PM |
| Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 02:21 AM |
| FT86 Suspension- D2/BC/Cusco/Megan/Tanabe/Tein/KW/Cusco/Ksport/Eibach/Perrin | JM Auto Racing | Brakes, Suspension, Chassis | 271 | 03-22-2014 12:17 PM |
| Is my Cusco catch can correctly installed? | wbradley | Engine, Exhaust, Transmission | 9 | 02-24-2014 09:49 PM |
| Has anyone actually seen any of the Cusco roll bar / roll cages installed? | xenocharger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 06-03-2013 06:54 PM |
