Old 01-31-2013, 11:54 AM   #785
mbh1101
Drives: Raven 6mt FR-S
Ive got roughly 4,300 miles on my fr-s. Ive had the idle issue for a while and have had dip enough to almost shut the car off. Also has anyone else had any trouble with starting up? I got into my car last week on a colder day and it took about 2 seconds or so to fire up. That scares me !
mbh1101 is offline   Reply With Quote
Old 01-31-2013, 12:19 PM   #786
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Mine has the same issue and only with the compressor on. Hopefully there is a fix because it drops down to about 500rpm and the car starts to shake a bit like it's going to stall. Very annoying.
rapidcars is offline   Reply With Quote
Old 01-31-2013, 02:06 PM   #787
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
What you describe sounds just like mine. But what catches me is that mine only happens about once a month when I use A/C almost everyday. And when it happens, it keeps doing that until I turn the engine off. When I turn the engine back on, it doesn't do it anymore...
Does it happen every time you have the compressor on?
Old 01-31-2013, 03:08 PM   #788
rapidcars
rapidcars's Avatar
It seems like every time. I'm not even using the AC, it just turns on automatically for defrosting purposes. If I press the AC button it goes right away (but then my windows fog up ). I've also noticed that once it happens, it pretty much happens at every stoplight.
The Following User Says Thank You to rapidcars For This Useful Post:
Sigh-on-Rice (01-31-2013)
Old 01-31-2013, 04:31 PM   #789
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
My idle in A/C compressor modes has improved. Just turned over 3300 miles. It doesn't act like it wants to stall and then kick up to 1000 rpm. Just minor rpm fluctuations. Maybe a 200 rpm.
FRSFirestorm is offline   Reply With Quote
Old 02-03-2013, 01:25 PM   #790
tdog227
tdog227's Avatar
Drives: BRZ Limited, Scion FR-S
I have a manual and have around 4,000 miles and it has done that dipping from the start. Took it to the dealer and they can't do anything unless it throws a code....I ride ALL the time with the auto climate OFF and run my seat heater...very annoying,...thinking about getting another vehicle...and not a Subaru or Toyota..
tdog227 is offline   Reply With Quote
Old 02-11-2013, 02:40 AM   #791
supragoods
Drives: Ravenfire
MY OTHER TOYOTA DOES SAME THING AND I HAVE YET TO FIGURE IT OUT. SO FINDING OUT THAT THIS CAR HAS THE SAME PROBLEM NOT COOL. AT LEAST THE PROBLEM IS SHOWING UP EARLY.
supragoods is offline   Reply With Quote
Old 02-11-2013, 10:59 AM   #792
Marrk
Drives: Honda Fit
Which other Toyota do you own? Does it have DI? PI?
Marrk is offline   Reply With Quote
Old 02-14-2013, 02:55 PM   #793
Sigh-on-Rice
I've read in a Japanese message board that Toyota admits the idling RPM going up and down when the compressor goes on and off is abnormal. They fix it by updating/replacing ECU. I really wish there is better communication between Japan and U.S., so that we don't get response like "We can't do anything unless the CEL comes on".
Note: This is not abour RPM going between 630-680. That's normal. It's about RPM going 500-800 and when it drops to 500, I can feel a little bit of shake.
The Following 2 Users Say Thank You to Sigh-on-Rice For This Useful Post:
Marrk (02-14-2013), tdog227 (04-11-2013)
Old 02-14-2013, 03:02 PM   #794
wu_dot_com
Drives: accord
yap my BRZ have 12K miles. mine was one of the first BRZ that arrive here in socal. two days ago, the car mysteriously stall while rolling one. yesterday it stalled twice. today it have stalled more than 15 times while i was commuiting from home to work. no CEL light. my ECU have the new reflash.
wu_dot_com is offline   Reply With Quote
The Following 2 Users Say Thank You to wu_dot_com For This Useful Post:
Deadspool (04-05-2013), Marrk (02-14-2013)
Old 02-14-2013, 03:11 PM   #795
jesperswe
Drives: GT86
Mine does the 500-800 thing even when the AC is off.
jesperswe is offline   Reply With Quote
Old 02-14-2013, 03:14 PM   #796
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
Your car stalled 15 times on the way to work?? As in engine shut off and you had to restart it? I would have had Subaru on the phone, bring me a free rental and tow my car back to the dealer after 3 times. Please tell me you don't actually mean that it stalled but rather that the idle dropped?
enigmaaron is offline   Reply With Quote
Old 02-14-2013, 07:03 PM   #797
wu_dot_com
Drives: accord
well it stall. basically, as soon as i let my foot off the throttle, the rpm drop to below idle and the engine die. this happen as i coast to a stop regardless if my transmission is in gear or in neutral.
so i was able to limp it to the dealership. they said their feild engineer drove the car and attribute the problem to my aftermarket parts.
my car have Perrin crank pulley, ACT clutch kit, and AEM intake. they specificlly said unless i switch back to stock parts they are not going to warranty the parts.
as a result, I have made an arrangement with AEM to take a look at the intake before i put the stock intake back on.
here is a little mod history.
at 2.5K i have ACT clutch kit installed.
at approx 6 K i had perrin crank pulley installed.
at approx 10K i had AEM intake installed.
PS. after the AEM intake was installed, the engine response to a specific RPM range was shifted upward, for example, i usually pull 6th gear at 75 miles at approx 3200 rpm in stock form. while with the AEM intake, i am pulling the same speed in 6th gear at 3500 RPM. my corresponding MPG per tank does decrese by 1-2 MPG after the intake was installed. however that after the first unexpected stall happended 2 days ago, the RPM which corrosponds to the specific RPM seems to droped back to stock setting. last night i opened the intake cover to check for anything unusual, and nothing was found.
Old 02-14-2013, 08:03 PM   #798
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I have a hard time believing that an intake would change the engine speed/vehicle speed correlation. The gearing would have had to change for that to happen.
With that said, the majority of those running an aftermarket intake reported bogging issues (myself included). However after a tune, those issues were no longer present.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
The Following 3 Users Say Thank You to civicdrivr For This Useful Post:
strat61caster (02-15-2013), Subie (02-15-2013), wu_dot_com (02-15-2013)
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-29-2012 12:38 AM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 02:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 01:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 01:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 01:58 AM
