Old 11-01-2011, 07:12 PM   #407
Kostamojen
Originally Posted by Spaceywilly View Post
Just to expand a little more...
Previous Subaru's have all been AWD. That is a huge knock on fuel economy to start out with.
The new FB engine which the FA engine is supposedly based on was designed for fuel economy. I don't see why this car with the FB based NA engine, DI, and RWD shouldn't get 30+ easily.
Subaru sells FWD overseas still, but they didn't go all AWD until '96, and the FWD versions with the EJ motors didn't get very good mileage either.
ANd yes, the FB was designed for fuel economy, but they modified it significantly for higher output. There is ZERO chance this motor will exceed the FB20's fuel economy. And none of the reviews/interviews so far have indicated this car with have such high MPG figures.
Old 11-01-2011, 08:03 PM   #408
fbloume
fbloume's Avatar
Drives: HONDA CIVIC FN2
I think I will choose hight spec model
I'm waiting for the real price
I also wait to see the car in real life and testing on dealership
I hope we'll have a choice of wheel designs
I also hope there will be some steering wheel controls, minimal behave and the quality of the sound system (nothing, only usb, cd, etc...)
also I would try the gearbox withe shift paddle to get an idea
fbloume is offline   Reply With Quote
Old 11-01-2011, 08:52 PM   #409
dalli
dalli's Avatar
Drives: Toyota
when you downshift with paddles, it automatically rev matches?
dalli is offline   Reply With Quote
Old 11-01-2011, 09:14 PM   #410
quik1987
quik1987's Avatar
Drives: Bugatti Veyron
quik1987 is offline   Reply With Quote
Old 11-01-2011, 10:10 PM   #411
bootlegapparel
bootlegapparel's Avatar
Drives: Mazda RX-7 FD
All car wiki
I compiled the spec data on the FT-86 into all car wiki to make it easy to read:
http://www.allcarwiki.com/wiki/Toyot...Specifications
If you guys know any more info or the info is wrong please change it, cheers.
bootlegapparel is offline   Reply With Quote
Old 11-01-2011, 10:27 PM   #412
MTD
Drives: Hyundai
Looks good. What about the interior dimensions?
MTD is offline   Reply With Quote
Old 11-02-2011, 12:59 AM   #413
MrQuick
Drives: Subaru
So I got bored and I accidentally made this.
Comparison to the various cars in the segment that the FT-86 will probably be aimed at, the specs are very similar to the Clio RS. If it drives anything like a Clio but in RWD format, I'll buy it straight away.
MrQuick is offline   Reply With Quote
Old 11-02-2011, 01:06 AM   #414
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Accidentally huh?
Old 11-02-2011, 11:02 AM   #415
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
Just read the newest translation of the spec sheet. Premium fuel? Crap. I hope that's optional and only required for maximum performance.
no_name is offline   Reply With Quote
Old 11-02-2011, 11:22 AM   #416
serialk11r
Drives: '06 AM V8V Coupe
You don't want the engine to knock and switch timing, which will worsen your fuel economy. Theoretically you could run lower octane fuel, as long as you never exceed a certain throttle position, since that would lower the maximum temperature that the air/fuel mix sees. In fact if a car has variable intake duration instead of a throttle plate to control air mass flow, then the temperature of the air/fuel mix goes down very fast as you reduce the "throttle position", so low octane fuel is definitely not going to do anything.
Old 11-02-2011, 11:27 AM   #417
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You will be able to run less. The ECU will retard timing. You will lose performance AND fuel economy so it's completely pointless to do so though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-02-2011, 11:56 AM   #418
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
Wow that is interesting... better hp/lb than Civic Type R and Mini Cooper S, both of which are incredibly fun to drive... that is good news
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 11-02-2011, 12:38 PM   #419
VenomRush
Thee O-ri-gi-na-tor
VenomRush's Avatar
lol, i accidently the whole chart
VenomRush is offline   Reply With Quote
Old 11-02-2011, 12:42 PM   #420
Matador
hashiryu
Drives: Mk4 Supra
Re; the "accidental" list, I think the automatic hi spec 86 should be capable of a sub 7 sec 0-60 sprint on a bad day.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
brz forum, brz forums, brz specs, brz sti forum, fr-s review, fr-s specs, frs review, frs reviews, ft-86 review, ft-86 specs, ft86 forum, ft86 forums, ft86 specs, scion fr-s, scion fr-s forum, scion fr-s horsepower, scion fr-s hp, scion fr-s review, scion fr-s reviews, scion fr-s specs, scion fr-s weigh, scion fr-s weight, scion frs, scion frs forum, scion frs review, scion frs specs, subaru brz, subaru brz forum, subaru brz forums, subaru brz horsepower, subaru brz hp, subaru brz specs, subaru brz sti, subaru brz sti forum, toyota ft-86, toyota ft-86 forum, toyota ft-86 horsepower, toyota ft-86 hp, toyota ft-86 review, toyota ft-86 specs
AutoBild gives specs of the Subaru BRZ Ice_Man BRZ First-Gen (2012+) — General Topics 43 10-30-2011 07:43 PM
Guessing Scion FR-S specs?? dClutch Scion FR-S / Toyota 86 GT86 General Forum 58 04-29-2011 12:07 AM
If there is no Toyota will you go with Scion or Subaru tranzformer Scion FR-S / Toyota 86 GT86 General Forum 91 04-26-2011 12:53 AM
200hp / 2700lbs - Really? Rickster Scion FR-S / Toyota 86 GT86 General Forum 385 04-18-2011 03:47 PM
TRD options and Badging? BanningFT Scion FR-S / Toyota 86 GT86 General Forum 43 11-08-2009 04:53 AM
