Old 01-07-2013, 02:10 PM   #85
2forme
Originally Posted by cruzinbill View Post
Pretty normal pricing. the alpine is like 990, then 100 for the adapter cable that coverts to standard toslink. Optical cables do fine as long as they are installed properly.
Not to be a **** but have you dealt with any hi end audio stuff? If not then you would be suprised some of the crazy shit out there.
Yea, I have. I'm actually very particular about the quality of my sound.... to a point. I'm not the type to go out and buy Martin Logan surround sound because similar quality can be had for much much less. But I digress.
Old 01-07-2013, 02:21 PM   #86
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
I ordered my knock off ca fi the other day and [ame="http://www.amazon.com/gp/product/B00029X1KA/ref=oh_details_o00_s00_i00"]this [/ame] harness. Hopefully it all works right. My car should be here next week, i'll update when its all in my possession.
Trashed675 is offline   Reply With Quote
Old 01-07-2013, 02:39 PM   #87
2forme
Originally Posted by Trashed675 View Post
I ordered my knock off ca fi the other day and this harness. Hopefully it all works right. My car should be here next week, i'll update when its all in my possession.
That harness is to replace the stock harness, not an adapter to use an aftermarket radio.
You'll be impressed with the performance of the knockoff. Download and customize a launcher to suit your liking and it's not a bad little unit. For 400$ can't go wrong!
Old 01-07-2013, 03:36 PM   #88
Trashed675
Trashed675's Avatar
Damn, i was afraid of that. What harness do i need?
Old 01-07-2013, 04:38 PM   #89
2forme
I think, this...
[ame="http://www.amazon.com/Beat-Sonic-BH1-Stereo-Installation-Kit/dp/B0086IM5S8/ref=sr_1_2?s=automotive&ie=UTF8&qid=1357591072&sr= 1-2&keywords=brz+wiring+harness"]Beat-Sonic BH1 Stereo Installation Kit : Amazon.com : Automotive[/ame]
The Following User Says Thank You to 2forme For This Useful Post:
Trashed675 (01-07-2013)
Old 01-07-2013, 11:04 PM   #90
Kyubi
86 Rolla
Drives: BMW X5
Im thinking of installing the Adayo in my car however have a couple of questions,
Does it work exactly like what is stock in the car, Like will the bluetooth, music and radio all work without a problem?
Will it be compatible with the Iphone 5?
And how do you add more things to it and update it? do you need to bring your laptop in the car?
Thanks
-Kyubi (Unrivaled 86 Perth Australia)
My Mods to my red 86, Sprintex Supercharger Inter cooled, 5Axis Body kit, KW V3 Coilovers, Invidia N1 Exhaust. BRZ Rear diffuser and custom "UNRIVALED" plates.
Kyubi is offline   Reply With Quote
Old 01-08-2013, 12:39 AM   #91
xjohnx
Grip>Slip
xjohnx's Avatar
Anyone tried the Parrot Asteroid Smart?
http://www.parrot.com/usa/products/a...asteroid-smart
After looking at some youtube reviews, it looks like it actually uses the same navi program the stock head unit uses (named iGo). I read an article saying that some manufacturers headunits (although they refused to name which ones) are actually based off of a stripped down and highly customized android kernel. wouldn't surprise me if the Fujitsu Ten is one of those units, after seeing the Navi similarities.
Old 01-08-2013, 01:34 AM   #92
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
I like that... not bad at all. Have to view some more about it. I'm in no rush though.
Raven FR-S, Magnaflow Axel Back Exhaust, Airaid Intake.... Pending Dynojet for performance gains... Big wish list... just need money to do it!
ravenblackfrs is offline   Reply With Quote
Old 01-08-2013, 08:27 AM   #93
2forme
The Parrot is pretty unimpressive. I did a bit of research into it and found out that it's under powered and not very easy to use in the car. On top of that, it's expensive.
The best "value" android HU is the ca-fi knockoff. It does everything the Adayo does, but better. And it's cheaper (400$ on ebay).
As far as iPhone 5 compatibility. AFAIK, the lightning connector isn't compatible with the older style of connector (which EVERYTHING uses). I think there is an adapter, but it doesn't allow video/audio out? Someone correct me if I'm wrong.
You don't need a laptop in the car to put stuff on the head unit. I used a thumb drive formatted using FAT32 to transfer stuff between. And yes head unit stuff works fine. Bluetooth, music and radio all work fine. The Adayo won't let you listen to FM radio and do something else (like Nav) at the same time, though. It's a problem they know about.
Old 01-08-2013, 09:10 AM   #94
Kyubi
86 Rolla
Drives: BMW X5
Do you think they will fix the problem with the radio and nav?
Also do you need to connect it with a cable? Would the bluetooth not pick up and u can connect your songs and such that way? I had a carolla that used to do that but this system is a lil more advanced.
Sorry if I am been a pain but I defs want a unit just dont want the wrong one!
The Following User Says Thank You to Kyubi For This Useful Post:
ravenblackfrs (01-08-2013)
Old 01-08-2013, 09:23 AM   #95
2forme
Oh I thought you wanted to connect it with the cable. Yea you should be able to sync with bluetooth. I know it works fine on Android phones.
Unless you like the design of the Adayo that much more than the ca-fi, I would pick up this one.
http://www.ebay.com/itm/Android-2-3-...3a332b&vxp=mtr
Old 01-08-2013, 09:59 AM   #96
ravenblackfrs
Thats why I'm thinking of doing a tablet install... none of these radio's do everything a tablet would do. I hadn't done any research on it yet. I bookmarked it so I could, but you just saved me some time... back to the drawing board I guess. I'm going to take my time though, I don't want to buy something thats not going to do JUST what I need it to do. Music not working while nav is on is unacceptable.
Old 01-08-2013, 10:22 AM   #97
2forme
The adayo is the only one that has that issue. All the other units I tested can play FM while doing anything.
I'm not sure what you're looking from a tablet that you can't get on one of these units. You will find a lot of problems with using a tablet install. Power on/off? Volume changing without having to fuddle through apps and home screens? quickly switching apps? Sound quality? GPS reception? FM?
I'm with you, I did a lot of research with installing a Nexus 7 in my dash before I went the dedicated head unit route. It's just too much of a hassle to actually use in the car for a head unit. Unless you're just gonna mount it on the windshield and use it in addition to the head unit, but I hate having crap all over my dash and wires dangling everywhere.
Old 01-08-2013, 11:04 AM   #98
Kyubi
86 Rolla
Drives: BMW X5
Last thing! (Maybe)
Are there any major advantages with the Ca-Fi over the Adayo or is it just the radio? Like I have read your initial post over and over maybe you have found something else out over time? Because I like the look of the Adayo but want the best option for my car
Who's interested in a full Android head unit? 2forme Electronics | Audio | NAV | Infotainment 307 10-05-2013 11:56 AM
How do Android phones work with the stock head unit? FastLap Electronics | Audio | NAV | Infotainment 14 10-10-2012 12:34 AM
looking for a head unit for Fr-s like the Brz. enjoi23 Electronics | Audio | NAV | Infotainment 5 08-08-2012 03:51 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 03:42 AM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 08:42 PM
