Old 12-28-2012, 06:06 PM   #29
Dispect
Newbie Car Enthusiast
Dispect's Avatar
Drives: Asphalt 6MT FR-S
Originally Posted by Flat Black VW View Post
Thank you so so much sir. I think the holidays are making us all a lil cheerful
Dispect is offline   Reply With Quote
Old 12-28-2012, 06:30 PM   #30
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Originally Posted by Dispect View Post
Ill try that later thanks. But look at the pics again. I'm afraid that the rivet might have fallen into those holes.
Ah! I see now. Looks like you might have things under control now. Good luck! Let us know how it goes.
Freeman is offline   Reply With Quote
Old 12-28-2012, 06:33 PM   #31
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
Ya bro, unbolt your back seats and you'll be able to get your missing pieces. Problem solved
Plxdjake89 is offline   Reply With Quote
Old 12-28-2012, 06:40 PM   #32
Dispect
Dispect's Avatar
Hope so :/ thanks..
Still not quite sure how tho. I'm a dumbass at diys..
Old 12-28-2012, 10:03 PM   #33
Dispect
Dispect's Avatar
Just looked at that. How does it help me with finding the rivets?
Old 12-28-2012, 10:10 PM   #34
jmaryt
Drives: 2012 honda civic ex
Originally Posted by wrxgoose View Post
lol.
kewl! now that's a "grabber!" thing looks nasty with those hooks,and all!
jmaryt is offline   Reply With Quote
Old 12-28-2012, 10:29 PM   #35
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
You need to remove the piece his hand is on here:
I thought that thread showed how to remove that, didn't look through it before posting the link.
Once you do what he shows in that thread through step 2, you'll want to remove some of the door molding around the large panel and the piece of plastic on the bottom of your door frame, then that big panel will come out by just popping out a bunch of clips.
There is probably another thread with more details, search around in the audio forum for instructions on how to replace the rear speakers. You should find some help.
Good luck and hope you find the rivets.
Flat Black VW is offline   Reply With Quote
Old 12-28-2012, 10:32 PM   #36
Dispect
Dispect's Avatar
got it. thank you sir
Old 12-28-2012, 10:36 PM   #37
Flat Black VW
No problem, iv'e done it a couple of times, it may seem intimidating because your removing a big portion of the interior, but it is very easy.
Old 12-28-2012, 10:38 PM   #38
ipothas
ipothas's Avatar
Drives: Whiteout FR-S
In my opinion, quit poking around before you do more damage. You lost a rivet? Live with it. Unless it makes an obtuse amount of noise or causes some sort of lack of functionality, quit while you're ahead.
Also, look at my member journal and check out my tail lights. Took about 30 minutes and required no tools at all besides a bit of masking tape and plastic lining
2013 Whiteout 6MT
ipothas is offline   Reply With Quote
Old 12-28-2012, 10:39 PM   #39
SteveH
Drives: 2013 FR-S Whiteout 6MT
Try a big shop vac and see if you can vacuum it out of the nook or cranny that its hiding in. If you haven't moved the car around, it probably just out of sight and the vac may pull it out.
Happy hunting...
SteveH is offline   Reply With Quote
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 04:27 PM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 10:36 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Exterior Parts (Aero, Lighting, Etc.) 1 12-30-2012 04:14 PM
WTT: SoCal SWP BRZ BRZ Limited Trunk with Spoiler for Trunk without Wing wollview Southern California 0 12-16-2012 03:46 AM
WTT: DGM BRZ Limited trunk w/ spoiler for wingless DGM trunk No Limit Motorsport Exterior Parts (Aero, Lighting, Etc.) 5 10-03-2012 10:03 PM
