Old 12-27-2012, 08:58 PM   #1
BRZnut
Drives: BRZ DGM Limited
Anyone notice vibration from headliner?
Small issue but wonder it it's just me.
Anyone noticed right above your head a vibration/buzzing coming from the headliner when on the highway going over 55 MPH, especially on concrete roads???
Old 12-28-2012, 12:51 AM   #2
whataboutbob
AutoX-10/10ths every run
Yes. Just started over the last few weeks. I've fidgeted with the window and seal on the driver's door a bit and it seems to be related. Haven't put much effort into trying to eliminate it, yet.
Build thread:Here
Old 12-29-2012, 12:08 AM   #3
BRZnut
I noticed that the headliner is not flush with the roof...there is some movement when you push on it. Need to figure a way to dampen the vibration.
Old 12-30-2012, 03:32 AM   #4
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
YES!! I have had my BRZ since Aug and no issue, until now....I think it has something to do with the cold weather(Canada). It gets really annoying I started pressing on the headliner to see if something was loose. For some reason it disappeared. I will check tomorrow.
ArKiTeCkT is offline   Reply With Quote
Old 12-30-2012, 03:35 AM   #5
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Could be your rear-view mirror against the windshield... That or it could also be the wire harness that is up in the headliner for your (optional) auto-dimming mirrors.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-31-2012, 02:01 AM   #6
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Yeah, I had this problem with mine when I first got it, about a week later (It's about 3 weeks old, has 1300 miles on the clock) the drivers side weather liner came completely off, something to do with cold weather, dealer thinks. It's going in next week to be fixed and I expect the issue to go away.
Xinshadow is offline   Reply With Quote
Old 12-31-2012, 07:42 PM   #7
BRZnut
Mine is right over my head..if I push up on the headliner above my head it stops.
Old 01-05-2013, 11:49 PM   #8
Otterbrawten
Drives: Firestorm FR-S
Rattles right behind my drivers seat.
Otterbrawten is offline   Reply With Quote
Old 01-06-2013, 09:29 PM   #9
sieeegel
Drives: rsx was stolen :(
mine rattles at random times on the back rear of my headliner. Near one of the attachment screws to the roof.
sieeegel is offline   Reply With Quote
Old 01-07-2013, 01:06 AM   #10
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
This seems possible, as I'd hit a pothole that jarred the auto-dim mirror loose. After getting it fixed at the dealership, the noise started happening within a week.
However, the timing of this noise also coincided with the first time the weather was under 60F outside on my drive home from work. If I ever get around to installing my sound deadener collecting dust in the garage, I'll definitely take a look.
As everyone else says, my noise stops when applying minimal upward pressure with a finger (though the constant buzz around 1900rpm tempts me to use far greater fist pressure..)
Smudgeous is offline   Reply With Quote
Old 06-08-2013, 02:52 PM   #11
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
mined started doing this as well. has anybody found an easy fix? i know the roof liner is removable, but i'm not sure how to get in the front by the visors.
mezdup is offline   Reply With Quote
Old 06-08-2013, 02:55 PM   #12
infinite012
Drives: 13 DGM BRZ Ltd
I don't have any rattles from the headliner. I have pulled the headliner off and laid RAAMmat all over the place.
infinite012 is offline   Reply With Quote
Old 06-08-2013, 02:57 PM   #13
mezdup
#1362
mezdup's Avatar
just looked into it. seems fairly easy to do.
Old 06-08-2013, 03:02 PM   #14
infinite012
Yes. 2 screws on each visor mount, pull down. Then you push a flat head into the front and rear of the clip that holds the visor towards the center of the car and pull that out. There is a single push clip that should be at centerline of the headliner. I think there's also a clip/poppit somewhere up front that clips the headliner into the roof/window frame.
The C pillars yank out easily enough, and there are 3 push clips that line the rear of the headliner. From here, it's fairly straight forward.
Mind the wires and connectors that are near the front for the map light and bluetooth mic (if you have it) and the radio wire that is taped to the headliner.
Speaker Vibration JayNutter Electronics | Audio | NAV | Infotainment 12 07-31-2013 12:24 AM
sunglass holder - headliner Alabang 86 Cosmetic Modification (Interior/Exterior/Lighting) 9 07-05-2013 09:26 AM
FS: FRS (oem) Headliner NRG x FRS Interior Parts (Incl. Lighting) 1 11-28-2012 12:27 AM
Power source in headliner? BoostedWrbBrz Electronics | Audio | NAV | Infotainment 2 11-10-2012 04:36 PM
Honda S2000 Mugen Hard Top Headliner S2KtoFT86 Other Vehicles & General Automotive Discussions 3 01-15-2010 01:43 PM
