Old 12-24-2012, 01:44 PM   #15
OrbitalEllipses
Drives: Attitude
Originally Posted by arghx7 View Post
Basically, OP is looking for Subaru to offer the new turbo 2.0 liter engine in this car
With a standard transmission and higher redline...we'll likely see it in the next WRX.
Old 12-24-2012, 02:06 PM   #16
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
Ok I know this is was already vaguely posted above, but why not go with a supercharger for that wide torque window your looking for? Is the amount of HP your getting in the SC versus the FI the problem?
Exhaust is offline   Reply With Quote
Old 12-24-2012, 08:01 PM   #17
HighLife
Drives: Manual Red '13 86
Maybe one day a sequential twin turbo could be fitted.
HighLife is offline   Reply With Quote
Old 12-24-2012, 08:21 PM   #18
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
4 cylinders are better suited for 1 turbo not 2. I don't inderstand people's obsession with power under 3k. I want traction and decent mileage under 3k
Tansey86 is offline   Reply With Quote
Old 12-25-2012, 09:58 AM   #19
frsvr4
Drives: '13 FRS
Inline 4 cylinders, sure.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 12-25-2012, 01:01 PM   #20
Supermassive
Supermassive's Avatar
The problem you run into is that if you go with a twin setup you only have 2 cylinders spinning a turbo, in effect you have 1 liter of displacement per turbo. It's not ideal, but a turbo feeding a supercharger could be interesting...
Another thing to consider is where the hell would you cram a dual turbo setup in this car...dunno if you've looked under the car but theres not much room under there for getting too crazy with the turbo setups.
Supermassive is offline   Reply With Quote
Old 12-26-2012, 12:54 PM   #21
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
As always, @arghx7 hits a home run again. That engine would indeed fit this car very well.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 12-26-2012, 01:29 PM   #22
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by Ryephile View Post
If I were looking for a supercharger setup, I'd want a TVS as it has excellent adiabatic efficiency and doesn't lose fuel economy versus a twin-screw, but nobody's developed one yet for this car. Nevertheless, that doesn't address my question of a low/mid RPM turbo kit. I understand big peak HP numbers impress, but I'm not looking for that. If anyone has driven a current BMW 328i, Cadillac ATS 2.0T, or VW Golf R, those are reasonable examples of the torque curve I'm interested in.
TVS supercharger for the win! Seems only Lotus guys know about the TVS. Someone slap one in the FA20!
Old 12-26-2012, 02:38 PM   #23
Ryephile
Hot Dog
Ryephile's Avatar
It's rather surprising how ignorant most aftermarket tuners are of the TVS's unrivaled qualities. Not to totally derail the thread, but personally I feel this would be a fantastic solution for the FA20. TVS's overall efficiency is excellent and they're still an air pusher, so there's no inherent significant parasitic drag from internal compression like a twin-screw or centrifugal. They're really the best overall solution for a supercharged setup, but they're also the most expensive.
That said, a good small turbo setup would give a big flat torque shelf while offering the best fuel economy. You can't have everything; a small turbo setup would trade throttle response and a little bit of lag for better FE and more torque in a less-expensive package over a TVS setup. For most enthusiasts that can't swing a $8k TVS setup, a $4k small turbo solution that gets great fuel economy and is super fun on twisty back roads is hugely attractive.
So, to get back to the topic, any turbo kit companies out there willing to belly up to the table and offer a small turbo kit? The marketing prowess of "balanced power" seems like rather low hanging fruit for a car that's promoted so rigorously on being a balanced chassis.
Old 12-26-2012, 07:02 PM   #24
arghx7
Drives: car
Small turbo kits are vulnerable to the "look at how the power drops off" criticism, from a marketing perspective.
Old 12-26-2012, 07:06 PM   #25
OrbitalEllipses
Drives: Attitude
Transient response outweighs any criticism of too little top end.
Many people will end up with too large turbos and realize that while they make 400+ peak who their car sucks to drive anywhere except the track (or unsafe highway pulls). A large portion of the STI crowd is like that: GTX35 turbos and gobs of power...above 5K rpm.
Old 12-26-2012, 07:29 PM   #26
Ryephile
Hot Dog
Ryephile's Avatar
.... A large portion of the STI crowd is like that: GTX35 turbos and gobs of power...above 5K rpm.
This is exactly what I'm trying to avoid. My proposal is for the experienced enthusiast that is beyond "My First Turbo Kit" and require a total package that is responsive and a good companion for a twisty back road romp.
We both know that's not relevant for the demographic I'm talking about. You also know the only reasons the power can taper is because you're running the compressor off the map or the engines' VE isn't meant for high RPM operation. The FA20, seeing that ECU tweaking yields almost no power gains up top, implies the VE falls off sharply over 6500. The turbo should be sized according to this approximate VE fall-off. I see no reason to waste compressor bandwidth band-aiding the engine's VE curve. I know this is a bummer for those that cherish the wishful-thinking high-revving nature of this engine, but the data speaks for itself.
Old 12-26-2012, 07:46 PM   #27
OrbitalEllipses
Drives: Attitude
Subarus typically have poor VE...
Old 01-12-2013, 10:24 AM   #28
hooman
hooman's Avatar
Drives: GTS86
2 cylinder spinning turbo is correct
hooman is offline   Reply With Quote
All TURBO kits compilation thread subatoy Forced Induction 112 04-10-2015 10:14 PM
TSI offers HIDGUY HID kits and LED lighing! $95 kits SHIPPED! We won't be beat! Lisa@TrueStreetIndustries Exterior Parts - Lighting 129 01-18-2013 09:57 PM
E85+boost subatoy Forced Induction 5 11-06-2012 12:55 PM
Price of Boost Synack Engine, Exhaust, Transmission 37 07-03-2012 06:39 AM
Protecting plastic door threshold BMWDavid Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 06-19-2012 10:04 PM
