Old 12-20-2012, 12:48 AM   #43
nix
nix's Avatar
Drives: AVO BRZ
What would you (Dave) and others suggest for a BBK upgrade as close to possible oem NVH, with dust boots and ebrake etc. but with a decent upgrade from say a ferodo 2500 pad and fluid swap on the stock calipers?
nix is offline
Old 12-20-2012, 12:48 AM   #44
Hanakuso
If you research the CP8250/8350 (that the Essex Comp kits use) you will find out the pads are identical to the Wilwood Superlite. I wouldn't be surprised if the pad selection is around the same as OEM pad size
Hanakuso is offline
Old 12-20-2012, 12:51 AM   #45
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Hanakuso View Post
This. If you research the CP8250/8350 you will find out the pads are identical to the Wilwood Superlite. I wouldn't be surprised if the pad selection is around the same as OEM pad size
If not better - AND CHEAPER!
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 12-20-2012, 12:54 AM   #46
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'd run the smaller StopTech or smaller Stillen kit up front. In the back I'd honestly just leave it alone, but run a matching pad as the front and then change compounds based on experience and preference.
Unless you want 14" rotors, then the AP Formula kit, StopTech large kit or Stillen large kit. IMO that's overkill though. I've driven big setups like that.. on 500hp, 3,800lb built cars on r comps and they are more than enough brake even then.
It's worth noting I couldn't care less about the appearance of my brakes though
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
The Following User Says Thank You to Dave-ROR For This Useful Post:
nix (12-20-2012)
Old 12-20-2012, 01:07 AM   #47
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I am well and truly on the fence on this as well, and a bit of a brakes noob. I was going to do a ~$2k STI brembo + Dba rotor build, but starting to lean towards a more dedicated bbk upgrade.
But my requirements as with all my mods are... long durability and performance without sacrificing ride quality in this case, noise and dust.
I'll be seeing mostly quick, ~50km spurts of canyon/hill style runs most weeks with track days every month or so. I am not racing it though so can do a few laps and peel off for brakes to cool...
Lots of reading ahead of me I think.
The Essex Sprint kit will drop 10lbs of unsprung mass per corner and provide much improved braking ability over stock system while costing the same. Always drop unsprung mass when you can if you want to improve handling/performance with the most efficiency. That the Sprint system provides such a good capable brake system while dropping 20lbs of unsprung mass makes it extremely hard to ignore. Choosing the same braking ability with another system that has an increased unsprung mass just makes no sense...
I still have stock brake system, but dropping 4+lbs of unsprung mass a corner with my wheel tire combo resulted in a very noticeable difference in suspension performance daily driving. I'll say it again, drop unsprung mass wherever you can if you care about performance and increasing the cars agility and planted feeling, especially daily driving. The suspension is much more compliant to the road surface and quicker in response with less mass to control. I look at any increase in mass, especially unsprung, as the wrong direction to go and a degrade in ride quality...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline
The Following User Says Thank You to Vracer111 For This Useful Post:
nix (12-20-2012)
Old 12-20-2012, 03:48 AM   #48
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
http://www.project-mu.com.au/en/
Give them a call for the 4 pot front kit, they are in Australia also so that may help you. I have had some delays getting my pricing on these but I would check pricing at least.
JoeBoxer is offline
Old 12-20-2012, 04:23 AM   #49
OrbitalEllipses
Drives: Attitude
Stay away from 2 piece rotors. The big boy BBKs are the most streetable but 14" discs are stupid. You want thermal mass? A street oriented BBK will get you the fronts and people say you don't need the rears; for that price you can get OEM Brembos at all four corners for lots of thermal mass with around the same size rotor as a normally sized BBK (13" ish). Alternatively it's possible to use Legacy GT front calipers and rotors for a pretty cheap increase in thermal mass, but they're sliders so pedal feel won't be like a BBK. Either the Legacy or Brembo setup will be enough thermal mass given the weight of this car; they were made for cars 500lbs heavier. And if you go the Brembo route I have rotors to sell you!
I wish my car wasn't my year round car; I'd drop money on the Essex sprint kit in a heartbeat.
OrbitalEllipses is offline
Old 12-20-2012, 05:03 AM   #50
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
My thoughts are that one wants the smallest (read lightest) brakes that will do the job. According to pcasso87 and Dave-ROR the Essex Sprint kit is up to the task with a 10 pound per wheel weight saving. That is my pick.
Captain Snooze is offline
Old 12-20-2012, 05:45 AM   #51
BRAWL
Drives: Toyota 86 GTS Velocity Orange
How daily driver friendly is the Sprint kit though? I like the look of them and that they drop the unsprung weight, but if they need servicing more regularly they might not be suitable. Thoughts?
BRAWL is offline
Old 12-20-2012, 06:18 AM   #52
Supermassive
Supermassive's Avatar
Ok after reading most of the brake threads on here, I have to say I'm still kinda unsure as to what I should be looking at for my application. I plan on running my car as a DD, with the occasional track day thrown in. I am about to install my turbo kit, and aiming for around 350-400 whp so I am hesitant to go with 4 pot calipers and smaller disks, sure I don't expect that during DDing that 4 pots would have much of a challenge hauling this car down from normal street driving speeds...I'm more worried about hauling down from 120+ mph and not feeling the brakes get heat soaked and fade. I will be running brake ducts sometime in the near future as well.
I am asking for a real unbiased opinion here because I am treading into unknown territory with this car...I used to track bikes but that was always just as simple as braided lines and race pads...here, I'm looking at full brake systems, calipers, pads, rotors, etc. and it's all kinda overwhelming because i have no frame of reference since I haven't tracked my own car ever.
Also before someone says i need to drive the stock FR-S on a track, to learn how to drive around a track, before throwing a ton of power at the thing. I know my limits, and did Skip Barber's racing school...but that was in 2000 so I may be rusty but the principles are still rattling around in my brain from tracking the bike.
Supermassive is offline
Old 12-20-2012, 06:25 AM   #53
Captain Snooze
Drives: Red Herring
Pad choice would be the main criteria for daily driving. If you are tracking the car then of course they will require more frequent attention.
From http://www.essexparts.com/brake-caliper-strips.html
"Calipers that regularly run at up to 392°F - Re-seal every other event. Calipers that run intermittenly from 392°F to 428°F - Re-seal as soon as possible."
BRAWL (12-20-2012)
Old 12-20-2012, 06:28 AM   #54
JoeBoxer
JoeBoxer's Avatar
Originally Posted by Supermassive View Post
I am asking for a real unbiased opinion here because I am treading into unknown territory with this car...I used to track bikes but that was always just as simple as braided lines and race pads...here, I'm looking at full brake systems, calipers, pads, rotors, etc. and it's all kinda overwhelming because i have no frame of reference since i haven't tracked a car ever.
I have been modding cars for years myself and have never tracked or did anything but a simple rotor/pad upgrade. I'm not an expert on bbk's at all but I would be concerned with going with a 6 piston front without doing a rear kit also. The Essex sprint systems don't seem very dd friendly regarding noise and no boots. The formula kit is nice but wish it was a 4 piston closer to sprint pricing. The larger stoptech kit sounds like a good option for you, I may have a set coming in real soon.
JoeBoxer is offline
Old 12-20-2012, 06:45 AM   #55
Supermassive
I keep hearing good things about the Essex Sprint kit, and now am intrigued, it may be enough for my car and honestly as a dd my car already is not ideal with my KW's on Vorshlags, it's stiffer than a porn star on viagra, not to mention the 6 puck stage 4 clutch going in...I guess dd is a loose term for my build.
Old 12-20-2012, 06:52 AM   #56
JoeBoxer
JoeBoxer's Avatar
Haha, I'm partial to the project mu that is on Evasive's car but am waiting on my credit app to be completed with mackin but I'll see if my rep will give me the pricing for it.
JoeBoxer is offline
GMOOKHER pictures of the BRZ @Firebird raceway gmookher BRZ Photos, Videos, Wallpapers, Gallery Forum 19 11-09-2012 12:49 PM
StopTech Introduces Big Brake Kits for 2013 Scion FR-S! At Vivid Racing vividracing Brakes, Suspension, Chassis 2 09-18-2012 03:19 PM
GMOOKHER pictures of the BRZ gmookher Cosmetic Modification (Interior/Exterior/Lighting) 8 09-02-2012 07:06 PM
Help me decide Decoy68 Other Vehicles & General Automotive Discussions 0 06-18-2012 09:29 PM
