AVOturboworld
Old 12-18-2012, 06:10 PM   #1919
AVOturboworld
Actually, they are quite a bit tougher than the hoses above. Those above are good, but not wire reinforced. The wire reinforced are a step above that, they are very, very tough. You can stand on one (and I'm no lightweight) and they won't collapse.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
Sportsguy83 (12-18-2012), Unleashed (12-18-2012)
Old 12-18-2012, 06:17 PM   #1920
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Awesome! this kit truly is amazing
Unleashed is offline   Reply With Quote
Old 12-18-2012, 06:34 PM   #1921
Mechazawa
Drives: FR-S, 6MT, White
Don't take this the wrong way because overall I think the silicone tubes are a great choice and I would be proud to have them on my car, but your "hot pipe" will dissipate heat under the hood sort of a pre intercooler. Aluminum would do this better and be lighter. It's a negligible difference though.
Sent from my SPH-L900 using Tapatalk 2
Mechazawa is offline   Reply With Quote
Old 12-18-2012, 06:51 PM   #1922
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Any info on the high flow intake system for the turbo kit?
Tansey86 is offline   Reply With Quote
Old 12-18-2012, 09:21 PM   #1923
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Originally Posted by Tansey86 View Post
Is that the case even if you start running higher PSI and power? I mean 5 psi and 250rwhp yeah but with a bigger turbo and somewhere around 20 psi is that tubing still as rigid?
If you've seen this stuff, you wouldn't be asking.
Drift-Office is offline   Reply With Quote
Old 12-18-2012, 09:30 PM   #1924
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Originally Posted by GTB/ZR-1 View Post
Nice setup...
How long before you guys have upgrades for ~350whp+ on e85 w/ free-flowing exhaust system?
Thx
GTB/ZR-1 is offline   Reply With Quote
Old 12-18-2012, 10:10 PM   #1925
Tansey86
Tansey86's Avatar
I wish I have haha. Id love to see the car setup in person.
Old 12-19-2012, 12:52 PM   #1926
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
What changes would have to be done to run 10psi? Other than larger injectors? I saw that the kit comes with a manual actuator that moderates boost between 5-7psi. What are the extra costs?
TyperRspec789 is offline   Reply With Quote
Old 12-19-2012, 01:03 PM   #1927
nix
nix's Avatar
Drives: AVO BRZ
Just search a bit man all your questions have been answered a few times.
Only 1 page ago Paul said there's no official details on stage 2. But if you wanted to do it yourself -
Injectors, MAP sensor, either a wastegate spring upgrade or an EBC. You could use a standalone boost controller, or use an acutator with ECUtek boost control.
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
Sportsguy83 (12-19-2012)
Old 12-20-2012, 01:14 AM   #1928
AVOturboworld
Update - santa's little elves, or at least AVO's, have been busy working on some updates to the turbo kit.
This is what it will look like with the full ceramic coating. That's exhaust manifold, turbocharger hotside, and the turbo discharge pipe.
Sharp-eyed forum members will note that there are additional differences between this and the initial kit photos, such as the one on my car. We *have* been busy, using feedback from the racetrack testing (road course, not drag) to make some improvements.
1. The oil reservoir tank has been redesigned to a flat tank, with the oil breather line moved to the front. This was to improve fitment and increase capacity of the tank. In the case of the breather line we found that due to the acceleration of the turbo kit (seriously) it was having some oil go up the line under hard launching/acceleration.
2. The exhaust manifold piping was redesigned for a more compact fit and even shorter piping, to improve the fitment under the engine tray and to increase response even more.
3. Hard to see, but an additional bracket for mounting the turbo was added.
And to answer the question yet to be asked, but I know it will be, yes, these are changes that will show up on the initial batch of kits shipping in January.
The Following 11 Users Say Thank You to AVOturboworld For This Useful Post:
Alienate (12-20-2012), civicdrivr (12-20-2012), Drift-Office (12-20-2012), GC GTS Aero Kit (12-20-2012), Jeff86 (12-20-2012), nix (12-20-2012), NoFear99 (12-21-2012), RYU (12-31-2012), so26 (12-20-2012), Sportsguy83 (12-20-2012), TyperRspec789 (12-20-2012)
Old 12-20-2012, 01:31 AM   #1929
RKC
Drives: Scion FR-S
Will it fit automatic trannys now?
RKC is offline   Reply With Quote
Old 12-20-2012, 01:35 AM   #1930
AVOturboworld
It fit automatic trannies before, so yes. Our reason for not "releasing" the kit for the automatics doesn't have to do with fitment issues, but for general testing reasons.
Old 12-20-2012, 01:44 AM   #1931
nix
nix's Avatar
Drives: AVO BRZ
Very nice! The reservoir looks like it is much better engineered. Do you have a bigger pic by any chance?
Old 12-20-2012, 01:48 AM   #1932
AVOturboworld
No, that's the largest they sent me. I probably won't have better pics till I take them myself.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
