AVOturboworld
Old 12-18-2012, 03:39 AM   #1905
AVOturboworld
That's at the factory end, still needs to get to my end.
Old 12-18-2012, 03:54 AM   #1906
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Originally Posted by vubaru View Post
Aw
Can't blame me for getting excited...
I will drop to my knees and bow down before your car after you've installed this kit.
JackSmiley is offline   Reply With Quote
The Following User Says Thank You to JackSmiley For This Useful Post:
vubaru (12-18-2012)
Old 12-18-2012, 04:05 AM   #1907
JackSmiley
JackSmiley's Avatar
Aw
Old 12-18-2012, 04:33 AM   #1908
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
need
moar
details
MSTiFK8R is offline   Reply With Quote
Old 12-18-2012, 10:22 AM   #1909
JackSmiley
JackSmiley's Avatar
Gonna be awhile before that happens
When the kit is in I'm going to make a mad dash for my buddy's shop. I hope he's not busy...
Its gonna be the first turbo brz in the bay area, im pretty sure he'll squeeze you in his busy schedule.
Old 12-18-2012, 01:20 PM   #1910
drifter
Drives: truck and old car
but who will be the first to post their results and give a full, detailed review??
we can't wait!!
drifter is offline   Reply With Quote
Old 12-18-2012, 01:55 PM   #1911
JackSmiley
JackSmiley's Avatar
we can't wait!!
Hella excited for the results too! But i would wanna see it up close for me to be convinced to pick up the kit.
Old 12-18-2012, 02:05 PM   #1912
laxfogo
Drives: DGM Limited BRZ
How should suspension and everything else be tuned for this kit?
laxfogo is offline   Reply With Quote
Old 12-18-2012, 03:00 PM   #1913
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
One thing that doesn't rub me right for this kit is the silicone, I feel like I would have more peace of mind with steel that wont expand contract and possibly collapse on me.
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
frsvr4 (12-20-2012)
Old 12-18-2012, 03:32 PM   #1914
djdnz
1337
Drives: 2013 BRZ WRB S/C
I like the idea of the silicon tubing actually, less possibility for squeaks
djdnz is offline   Reply With Quote
Old 12-18-2012, 03:32 PM   #1915
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by AVOturboworld View Post
Depending on who you talk to, anything that isn't electric or runs on unicorn farts isn't efficient enough.
I think there's a certain assumption that because we are not going to charge 6-8k, it's going to be some cheapo kit. That's certainly not the case - it's just that there's several factors here, such as economy of scale. We are not planning on selling 5-10 kits a year, we are instead planning to make most of the parts on our factory lines in larger amounts. This brings costs down quite a bit. We are not picking wire-reinforced silicone for the piping because it's cheap - it's not, when you are getting it moulded to specific shapes - we are doing it because it works best for this application. Wire reinforced silicone is *tough*, you could stand on it.
See above.
Old 12-18-2012, 04:42 PM   #1916
Tansey86
Tansey86's Avatar
See above.
Is that the case even if you start running higher PSI and power? I mean 5 psi and 250rwhp yeah but with a bigger turbo and somewhere around 20 psi is that tubing still as rigid?
Old 12-18-2012, 04:46 PM   #1917
Unleashed
Unleashed's Avatar
Drives: 13' WRX
If these silicone hoses are of the same caliber as others (EVO brand) which I'm sure they are, then they will handle 50 psi
EVO ProClimb/Cross 1100T Silicone Boost Hoses with T Bolt Clamps
Product Description
Product Details
The EVOPS Reinforced Silicone Charge tubes are a great addition to a stock 1100T and a must for higher than stock boost levels or turbo upgrades. Our hoses are twice as thick as the factory hoses and have been tested to over 50 PSI. The included T Bolt Clamps have the clamping power to keep the hoses on - even under extreme boost. Because there are only two hoses and four clamps, we minimize the margin for error and number of failure points. Aluminum charge tubes typically have many more connection points to fail, plus will absorb under hood heat causing higher intake temperatures. All of this plus they look great too!
Will not absorb under hood heat like aluminum
Have been tested to over 50 PSI
Will not pop off like the factory hoses and clamps
A must for high boost applications
Look cool too
Unleashed is offline   Reply With Quote
The Following 3 Users Say Thank You to Unleashed For This Useful Post:
Alienate (12-18-2012), Sportsguy83 (12-18-2012), Tansey86 (12-18-2012)
Old 12-18-2012, 05:09 PM   #1918
Tansey86
Tansey86's Avatar
Thanks, that's some peace of mind for everyone.
Unleashed (12-18-2012)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
