Old 11-05-2012, 10:30 AM   #71
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
Originally Posted by CrazyWookiee View Post
I ordered these to stick on top. They are a tad bigger, but I think there's some room to cut around.
http://www.ebay.ca/itm/4X-56mm-Toyot...item2a20f7e507
These are 1mm bigger than stock, the JDM are 48MM
http://www.ebay.ca/itm/321005462366?...#ht_500wt_1180
Spartan65 is offline   Reply With Quote
Old 11-05-2012, 10:59 AM   #72
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Originally Posted by pjb86 View Post
Can someone who has changed their emblems give us a detailed desription of removing the old ones without damaging the paint?
There is a wonderful DIY Section where members post instructionals and a great search feature on these forums.
For debadging, DarrenDriven wrote a great post with lots of pictures here:
http://www.ft86club.com/forums/showthread.php?t=7296
You may also be interested in painting your badge before putting it back on using plastidip. You may also be interested in putting the 86 logo instead.
Books is offline   Reply With Quote
Old 11-08-2012, 09:17 AM   #73
Spartan65
Spartan65's Avatar
Well I changed to the Toy T, in my rush I chipped the front paint, so I went down to Signs of Santa Fe and got some black reflective vinyl, when the light hits it at night it's bright white.
Old 11-08-2012, 11:18 PM   #74
Spartan65
Spartan65's Avatar
My wheel emblems came in also. 25.00 with freight total.
Spartan65's DROID RAZR
Old 11-12-2012, 01:41 PM   #75
Turbo Den
Drives: FRS, IS300, 911sc
I used the fish wire technique with hair dryer heating it first. Some glue was so strong that a some paint came off as I sew through the glue with fishing wire. Just a word of caution to other people.
Turbo Den is offline   Reply With Quote
Old 11-12-2012, 01:45 PM   #76
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I think those of us in South Florida have an advantage with all the heat and humidity, it seems to loosen these things pretty well.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 11-13-2012, 07:34 PM   #77
Turbo Den
after failure in with front badge using fishing wires... i used steam for the rear. WORKS easily and no scratches at all. HIGHLY recommend steaming to remove the badges.
Old 12-17-2012, 10:46 AM   #78
Mac1235
Mac1235's Avatar
Have we confirmed whether the badges ordered from Toyota from the Corolla and the Avalon come with the adhesive already on them? Do I have to provide my own adhesive or are they peel and stick ready?
Thanks in advance.
Mac1235 is offline   Reply With Quote
Old 12-17-2012, 10:59 AM   #79
Mac1235
Mac1235's Avatar
I think everyone needs to visit the DIY section. You must 100% use a source of heat to get these emblems off, the glue they use has a very low melting point and when heated it is very easy to pry off with absolutly zero damage to the car. If there is residue left, there is no need to use any chemicals, use more heat and a clean pair of gloves and it will just roll off the paint with a very light rub.
Old 12-17-2012, 12:13 PM   #80
tonystewart
New ones have adhesive
The Following User Says Thank You to tonystewart For This Useful Post:
Mac1235 (12-17-2012)
Old 12-17-2012, 12:27 PM   #81
Mac1235
Mac1235's Avatar
Thanks! I will be ordering these shortly. Yeah if anyone finds a fit for the wheel caps it would be a great Christmas present to the forums!
Old 12-17-2012, 01:12 PM   #82
tbox
tbox's Avatar
Drives: GT86
The wheel caps are 48mm in diameter. Here's a whole thread on wheel cap alternatives:
http://www.ft86club.com/forums/showthread.php?t=23723
Merry Christmas
tbox is offline   Reply With Quote
Old 12-17-2012, 01:28 PM   #83
DSMDave25
DSMDave25's Avatar
Drives: ZN6
Has anyone looked into the toyota nameplate badge that is positioned on the rear left side on the gt86's.
After looking at extensive pictures etc i know that really doesn't help hah but I found that the 03s and on camrys nameplate badge on the back is very similar if not the same as the gt86.
Pn# 75447-AA020 for those that want to take a look.
I ordered one so ill let you guys know how it looks when it arrives!
DSMDave25 is offline   Reply With Quote
Old 12-17-2012, 06:40 PM   #84
mdf4uk
Drives: 13 Firestorm FRS MT & 09 DGM WRX
Here are my new badges, used carbon fiber vinyl behind them.
mdf4uk is offline   Reply With Quote
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
Swap your Scion key emblem for a Toyota Synack Scion FR-S / Toyota 86 GT86 General Forum 6 08-03-2012 05:58 PM
Plastidip emblem??? jarviz Cosmetic Modification (Interior/Exterior/Lighting) 20 08-02-2012 03:21 PM
Toyota Emblem replacement jarviz Cosmetic Modification (Interior/Exterior/Lighting) 3 07-26-2012 11:12 AM
Non USDM BRZ oil weight BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-21-2012 02:55 PM
