Old 12-15-2012, 04:14 AM   #1
corvino26
corvino26's Avatar
Drives: 2013 Scion FR-S 6MT Raven
What is the best intake for FR-S?
I have been looking into the agency power intake for my FR-s BUT it has just came to my attention that it seems most intakes cause a cel and cause the frs to run lean. I would like to know what u guys think would be the best intake to buy without having to get a tune. Also keep in mind I intend on also purchasing a cat back and cat delete pipe. Thanks for any and all thoughts.
corvino26 is offline   Reply With Quote
The Following User Says Thank You to corvino26 For This Useful Post:
sosick (10-07-2013)
Old 12-15-2012, 04:15 AM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
save your money.
use a drop in filter instead
86_ZN6 is offline   Reply With Quote
The Following 7 Users Say Thank You to 86_ZN6 For This Useful Post:
corvino26 (12-16-2014), Mike86 (12-17-2012), Mikepage (12-16-2012), raul (10-08-2013), SkAsphalt (12-17-2012), soulever (10-09-2013), suaveflooder (12-21-2013)
Old 12-15-2012, 04:59 AM   #3
number1Tango
Drives: Silver FRS
Originally Posted by 86_ZN6 View Post
save your money.
x2
number1Tango is offline   Reply With Quote
Old 12-15-2012, 07:26 AM   #4
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
For mine i'm going to install an Injen Cold- Air and probably the TRD exhaust later on.
L3P47 is offline   Reply With Quote
Old 12-15-2012, 08:30 AM   #5
mashal
DADA
mashal's Avatar
Drives: 2013
Afe intake hasn't caused any cel with the fa20club tune
-AKA
mashal is offline   Reply With Quote
Old 12-15-2012, 09:55 AM   #6
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
save your money.
Which drop in filter is best, Perrin or K&N?
briang0901 is offline   Reply With Quote
Old 12-15-2012, 10:15 AM   #7
SLOPPYDRFT26
Drives: 07CivicSI
not k&n. you want a dry filter. oiled filters screw with the maf sensor
SLOPPYDRFT26 is offline   Reply With Quote
Old 12-15-2012, 11:04 AM   #8
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Make sure whichever intake you get you unplug the negative battery line to reset the ECU. The ECU should then be able to adjust to the increased air flow.
Darryljr11 is offline   Reply With Quote
Old 12-15-2012, 11:05 AM   #9
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Only if over-oiled. I have the aFE oiled drop-in and I have no issues.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
The Following User Says Thank You to ngabdala For This Useful Post:
Foobar (12-16-2012)
Old 12-15-2012, 11:12 AM   #10
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
I have the injen and it has been awesome for me but other people have had issues with them. I normally work on old muscle cars and I know an exhaust with no negative pressure can cause them to run rich and an intake can cause them to run lean so it is finding a balance and adjusting the carb. Not sure if the same applies to this car being fuel injected but I had an exhaust on mine before the intake.
Sent from my SGH-T989 using Tapatalk 2
Old 12-15-2012, 11:17 AM   #11
L3P47
L3P47's Avatar
I'm looking at getting the Injen intake for my FR-S. What kind of adjustments without an aftermarket exhaust do you recommend?
Old 12-15-2012, 01:16 PM   #12
2forme
Injen doesn't make a cold air.
Old 12-15-2012, 01:19 PM   #13
L3P47
L3P47's Avatar
Check again.
Old 12-15-2012, 03:40 PM   #14
wrmathis
Drives: no car :(
Check again.
i think he's refering to that they do make an intake. just not a cold air one. it pulls air from the hot engine compartment so calling it a cold air intake is wrong
wrmathis is offline   Reply With Quote
Best intake? Maps316 Engine, Exhaust, Transmission 34 05-12-2014 04:15 PM
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
Looking for HKS Intake Spartan65 Engine, Exhaust, Transmission 2 09-12-2012 11:40 PM
