Old 12-14-2012, 05:19 PM   #15
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by fatoni View Post
i get the feeling that 300 na hp is more expensive and less reliable than 300 fi hp.
I think it might be pretty reliable (if the rods don't fatigue) but it'll be more finicky. With a significant increase oil pump might need to go, water pump will be spinning too fast, and the short rods will place a lot of stress on the cylinder walls.
The heads and the direct injection are designed together for low end, if this involves more modification than replacing some components (aka, changing the ports) the low rpm behavior could really suffer. If it's just lighter valves, stiffer springs, bigger cams, shouldn't be too big of a deal. The cam phasing has a pretty wide range to deal with fat cams (if you add like 60 degrees duration on the intake though the idle is probably going to suck no matter what magic Toyota says direct injection can do with EGR, but if it's more modest like 30 degrees maybe not).
Power peak at 9000rpm and E85 could hit 300hp.
The Following 2 Users Say Thank You to serialk11r For This Useful Post:
FA5 (02-09-2013), TouchMyHonda (12-15-2012)
Old 12-14-2012, 07:36 PM   #16
Blue86
Drives: Sonic Blue 86GT Manual
would be a shitload of fun despite my expectations of the costs involved
Blue86 is offline   Reply With Quote
Old 12-14-2012, 07:41 PM   #17
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
Im pretty sure its gona cost way more to do the n/a high hp road, than to go with a simple bolt-on tc/sc kit...
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 12-14-2012, 07:49 PM   #18
mashal
DADA
mashal's Avatar
Drives: 2013
He didn't just say 300 Hp NA !!!
I-Tapatalk
mashal is offline   Reply With Quote
Old 12-14-2012, 07:50 PM   #19
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Nothing is more fun that high revving, large NA Hp. You can't comparing it to boost.
TouchMyHonda is offline   Reply With Quote
The Following User Says Thank You to TouchMyHonda For This Useful Post:
eljefe (12-27-2012)
Old 12-14-2012, 08:06 PM   #20
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
if i can get 250+ whp N/A with a mild build, way worth it
Jesse is offline   Reply With Quote
The Following User Says Thank You to Jesse For This Useful Post:
czar07 (12-14-2012)
Old 12-14-2012, 09:02 PM   #21
NJA
Drives: Supercharged Saturn ION
good stuff, now you just need a solid cam option
NJA is offline   Reply With Quote
The Following User Says Thank You to NJA For This Useful Post:
TouchMyHonda (12-14-2012)
Old 12-14-2012, 11:25 PM   #22
Hachiroku
Administrator
Hachiroku's Avatar
Drives: Boxster 986
Thread cleaned up. Please keep it on topic and stay away from the NA vs. FI arguments.
Hachiroku is offline   Reply With Quote
The Following 4 Users Say Thank You to Hachiroku For This Useful Post:
czar07 (12-15-2012), Guff (12-15-2012), OrbitalEllipses (12-14-2012), Sportsguy83 (12-15-2012)
Old 12-14-2012, 11:44 PM   #23
subatoy
subatoy's Avatar
Drives: subatoy
wrong! more revs mean less torque. crew that!
subatoy is offline   Reply With Quote
Old 12-14-2012, 11:50 PM   #24
OrbitalEllipses
Drives: Attitude
The market's been mum on this as far as I've seen. Of course you get a custom regrind, but an off the shelf variety of options would be cool.
Old 12-14-2012, 11:59 PM   #25
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Ive heard Tomei and Perrin are both coming out with cams, excited to see how they help this car. And how these cars will sound with them most of all.
Tansey86 is offline   Reply With Quote
Old 12-15-2012, 12:22 AM   #26
Captain Insano
250+ Hp NA on this car would be spectacular.
Captain Insano is offline   Reply With Quote
Old 12-15-2012, 02:51 AM   #27
TouchMyHonda
Vtec Jesus
I hope Jun makes some cams. I love my Jun 3 cut cams.
Old 12-15-2012, 05:43 AM   #28
OrbitalEllipses
Drives: Attitude
Perrin has never made cams for a Subaru...Jun, Tomei, even HKS I could see. I'm hoping for something more along the lines of Kelford, GSC, maybe Cosworth.
Clutch Delay Valve? ashtray Engine, Exhaust, Transmission 72 11-18-2015 12:10 PM
Knock/valve slap/crick noise under accel yomny Issues | Warranty | Recalls / TSB 47 01-07-2013 08:53 PM
Valve Train Adjustments @Art_Mighty Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 09-24-2012 09:10 PM
Valve Timing/Computer miss paula Issues | Warranty | Recalls / TSB 3 09-20-2012 03:27 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
