Old 12-05-2012, 01:02 PM   #1
Superhatch
AIM4APX
Superhatch's Avatar
Drives: 2013 WRB BRZ Limited
BRZ jammed window issue/blinking auto light?
[ame="http://www.youtube.com/watch?v=OivSqN-IwSQ&list=UL"]BRZ window jammed - YouTube[/ame]
This morning is was about 21*F outside (rained 2 days ago and was 61*F) and when I opened my door the windows rolled down, as usual, but did not roll back up and then the 'auto' lights started flashing. They stayed flashing for my entire drive to work. I'm going to check them again at lunch time and I see some potential mention in the manual on page 72:
■When the power window does not close normally
If the jam protection function is operating abnormally and a window cannot
be closed, close all the doors perform the following operations using the
power window switch on the relevant door.
Vehicles without a keyless access with push button start system:
After stopping the vehicle, the engine switch is turned to the “ON”
position.
Vehicles with a keyless access with push button start system: After
stopping the vehicle, the push-button ignition switch is turned to
“ON” mode.
Hold the power window switch in the one-touch closing position two
consecutive times.
once again and continue holding for 1 second or more after the window
closes completely.
If you push the power window switch to the opening position while the windowis moving, start again from the beginning. If the window continues to
close but then re-open slightly even after performing the above procedure
correctly, we recommend that you have your SUBARU dealer.
Has this happened to anyone before?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
Superhatch is offline   Reply With Quote
The Following 3 Users Say Thank You to Superhatch For This Useful Post:
atomicalex (02-01-2019), NYCsubaruBRZ (02-04-2014), unvevo (11-25-2014)
Old 12-05-2012, 01:15 PM   #2
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
The auto roll down tends to scare me at freezing temps. I haven't had an issue yet but there has been ice on my window and you can hear the ice cracking because of the auto roll. I can't imagine this is good for the motors.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 12-11-2012, 10:50 PM   #3
JSUB
JSUB's Avatar
Drives: 2026 BRZ tS coming
Just happened to me. It's cold (-7 Celcius) and driver window seemed frozen and didn't want to go down. Both "Auto" light switch started flashing and window barely moves up or down (it's gladly kinda stuck in the closed position). Tried the owners manual "fix" listed above but no luck...
Any advice besides calling the dealer guys?
JSUB is offline   Reply With Quote
Old 12-12-2012, 12:12 AM   #4
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
On the FR-S anyway when I had it happen, I roll it down partway, and then roll it up and hold up until you hear a click, about a half second after it stops. Should reset it all.
Please use search next time, I did a search for "window" in the issues section you posted in, and found these two very applicable threads:
http://www.ft86club.com/forums/showt...ghlight=window
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna
5AD Spoiler
205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only)
Rally Armor mudflaps in black with red logos
RazorHawk is offline   Reply With Quote
The Following User Says Thank You to RazorHawk For This Useful Post:
JSUB (12-12-2012)
Old 12-12-2012, 08:35 AM   #5
whtchocla7e
Drives: 2013 FR-S Hot Lava
Same issue here this morning. Damn it!
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 12-12-2012, 08:43 AM   #6
CaptainSlow
CaptainSlow's Avatar
So, is there any way to just disable this feature?
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 12-12-2012, 02:19 PM   #7
jesperswe
Drives: GT86
Happens every cold morning here I'll have to reset them everytime and it works again. I'll roll the windows all the way down, then all the way up and hold the button for 10 seconds and they reset.
jesperswe is offline   Reply With Quote
The Following User Says Thank You to jesperswe For This Useful Post:
Drift&Drag (03-04-2014)
Old 12-12-2012, 02:41 PM   #8
empower-auto
Kouki-Monster
empower-auto's Avatar
If you get a remote start installed and let the car / interior warm up a little before getting in, you will not have this issue nearly as often / at all.
it's been -13F to -22F and colder here lately .. when I run the car for a bit before getting in I haven't had any issues.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 12-12-2012, 04:36 PM   #9
grodenglaive
Drives: asphalt FR-S
Holy cold! Not so bad here, but my passenger side won't open today (probably frozen) and now the auto-up/down stopped working on the driver's side, though the window operates smoothly when you hold the button.
grodenglaive is offline   Reply With Quote
Old 12-13-2012, 01:41 PM   #10
Superhatch
AIM4APX
Superhatch's Avatar
I posted from my phone via tapatalk, and the search didn't pick anything up. I went to those other threads for a solution though. They are filled with all the info you will need. Fwiw, this has happened twice since this incident and the roll down and back up has worked both times.
Old 02-22-2013, 11:33 AM   #11
Furinax
Drives: Accord 2007
The manual instructions make no sense to me...
My FR-S has been having this problem recently so I googled and ended up here. My driver's side control for the passenger side doesn't work, but the passenger's side power controls work fine. The passenger side (and driver's side) has been sliding down. I wonder if this will break one day?
Anyway, good to know you can reset the blinking light. I will try that when I get back in my car.
Furinax is offline   Reply With Quote
Old 02-22-2013, 11:54 AM   #12
BRZerk
Some guy in a white car
BRZerk's Avatar
Drives: 2013 SWP BRZ Limited
just put the window down, then back up and hold the switch. its not really that complicated.
2013 Subaru BRZ Limited 6MT - Satin White Pearl
BRZerk is offline   Reply With Quote
Old 02-22-2013, 03:15 PM   #13
NOHOME
Drives: RAVEN
Yes. There is a thread on it by one smarter than me. It is also quite simple.
Scion wont endorse it, so remember to disable the disable if and when you take the car in for warranty work on the windows.
When I bought the car, I had to wonder how stupid a designer/engineer you had to be to integrate that feature into a car, but that was when I thought that failure meant you could not open the door.That this not the case, door opens fine in the full up position.
Now that I have driven the car in winter and found out what happens when it stays down and you don't notice, I wonder how stupid a car company would have to be not to do any winter testing. You could never convince me that they did.
NOHOME is offline   Reply With Quote
Old 02-23-2013, 03:20 AM   #14
jermyzy
Drives: 2013 WRB BRZ Sport-Tech 6MT
What exactly is the point of the window rolling down and back up every time you open the door anyways?
jermyzy is offline   Reply With Quote
What is that blinking dash light when the car is off? JayNutter Scion FR-S / Toyota 86 GT86 General Forum 7 02-03-2014 11:59 AM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 06:32 AM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 01:32 AM
Issue with Simple Shut Window Feature Jayp Issues | Warranty | Recalls / TSB 5 07-27-2012 12:18 AM
How to remove third brake light (to tint back window) 96z2 Cosmetic Modification (Interior/Exterior/Lighting) 10 06-07-2012 05:14 AM
