Old 11-21-2012, 02:51 PM   #1
Brzer
Drives: BRZ, 2011 Outback 3.6R
MT fluid change experience
I know that there have been a lot of posts about MT fluids but after reading all of them as well as posts on Bobistheoilguy, I decided to go with GM part #12346190. It is a fully synthetic Gl-4 made with with PAO's and esters and no pseudo-synthetic GroupIII oil and variably described as a 75w-90 and 75w-85 with KV40 and 100 values of 75 and 11.5 cSt. In the Chevrolet 2010 vehicle product car manual it is described as a 75w-90, so no warranty issues using it. It is expensive. Retails for 26.36 a quart. I got it at dealer cost for 16.53. Shifts are now very smooth with just the right engagement feel and no second gear notchiness! Highly recommended. See link for warranty proof of Gl-4 and 75w-90. The second option is the one to download.
http://printfu.org/gm+oil+12346190
Brzer is offline   Reply With Quote
Old 11-23-2012, 06:21 PM   #2
Brzer
Update after driving in weather in the 30s, mild second gear notchiness briefly. Still much better than OEM. May try Pentosin next time but not until my warranty is up. I don't want a claim denial.
The Following User Says Thank You to Brzer For This Useful Post:
ft86Fan (11-23-2012)
Old 11-23-2012, 10:29 PM   #3
gmookher
What makes you think running pentosin will be a claim denial?
Old 11-24-2012, 12:06 AM   #4
Brzer
It is a 75w-80 and the manual calls for a 75w-90. I am not concerned that it wouldn't be a good choice, but if I where to have bad luck with my transmission, Subaru could use this as a way to deny warranty.
Old 11-24-2012, 12:43 AM   #5
Dezoris
Dezoris's Avatar
Given the dealer techs cant even tighten lug nuts right, last thing I would worry about is them sending trans fluid to a lab to test oil weight.
The Following 6 Users Say Thank You to Dezoris For This Useful Post:
1strwdcar (12-11-2012), AZP Installs (11-25-2012), bimmerboy (12-11-2012), russv (12-14-2012), SkAsphalt (01-24-2013), Superhatch (11-24-2012)
Old 12-11-2012, 10:28 AM   #6
Bluetib
Subaru product specialist
Bluetib's Avatar
Drives: BRZ Sportech
Pentosin MTF2 is definitely working perfectly for
my BRZ transmission, smooth like butter without
compromise.
Car is almost at 8000 clicks and temperatures since
flush 2 weeks ago are 20 to 50F.
Bluetib is offline   Reply With Quote
The Following User Says Thank You to Bluetib For This Useful Post:
gmookher (12-11-2012)
Old 12-11-2012, 10:56 AM   #7
CaptainSlow
CaptainSlow's Avatar
Is this something that can be easily done by an average at-home garage tinkerer (with basic tools), or should it be done by a transmission shop? How many quarts are required? I think this will be one of the first things I do once I get my FR-S in the spring!
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 12-11-2012, 11:00 AM   #8
DarkSunrise
DarkSunrise's Avatar
Looks similar to my old STI. If you can do an oil change, should be no problem.
Old 12-11-2012, 11:33 AM   #9
gmookher
compromise.
Pento is superior to the GM stuff btw..you get what you pay for. DO a search there are threads on this site relating to pentosin
easy to do for home wrench, depending on your skill level, if you can change engine oil and get the car up safely you can do this too
Old 12-11-2012, 11:41 AM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It's very easy.
4 jack stands, a jack, a couple of tools, crush washers (or reuse, I prefer to replace), fluid pump (unless using gear 300 in the trans), and some tools.
There's a DIY in the DIY subforum.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
CaptainSlow (12-11-2012)
Old 12-11-2012, 11:43 AM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
He's using pentosin mtf2 now I believe...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 11:59 AM   #12
1strwdcar
Drives: 2013 scion frs Whiteout
Truth most fluid hits the shop floor
1strwdcar is offline   Reply With Quote
Old 12-11-2012, 12:13 PM   #13
gmookher
use a big shop type fluid syringe, its cleaner than most screw on pumps.
Old 12-11-2012, 12:18 PM   #14
CaptainSlow
Where can you get one of those? I've looked for something just like that before with no luck
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
1st Oil Change Experience, Observations & a Surprise Black Tire Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 100 09-14-2015 09:23 PM
What Differential fluid is in your BRZ/FRS? ft86Fan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 11-12-2012 08:57 PM
Track Day Brake Fluid Skorov AUSTRALIA 2 11-11-2012 07:10 PM
500 Mile - Complete fluid change Touge Factory Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 42 11-07-2012 04:10 PM
