Old 12-10-2012, 10:18 PM   #1
ill roller
Drives: BRZ/E30/IS300/LS400
Risky Devil BRZ - Daily / Drift car
Picked this bad boy up two weeks ago after about a 4 month wait... Absolutely love the car, but can't stand driving anything stock. I picked up the wheels the day after I bought the car, and the coilovers about a week later...
Stock:
Here's a little install/review of the Stance Super Sport coilovers I put on:
http://www.ft86club.com/forums/showthread.php?t=23994
And here's a few quick shots I took after the coilover install:
BRZ Preview by AJ Gillett, on Flickr
I still need to mess with tire sizing, probably lower it a bit more, and get an alignment, but I think it came together pretty awesome for not much money/work... More to come!
RISKY DEVIL // ILL PHOTOGRAHY
ill roller is offline
The Following 4 Users Say Thank You to ill roller For This Useful Post:
Maik L (12-11-2012), microbionic (12-11-2012), nix (12-10-2012), OmegaKnight (12-11-2012)
Old 12-10-2012, 10:19 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
What wheels are those ??
I-Tapatalk
mashal is offline
Old 12-10-2012, 10:20 PM   #3
ill roller
Work XT7
Old 12-10-2012, 10:44 PM   #4
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Risky devil doing it right in Chicago as always. Keep it up!
TylerLieberman is offline
Old 12-10-2012, 10:46 PM   #5
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I think it's low enough already, maybe too low depending on your daily drives. I think your camber is excessive in the rear and some adjustable rear lower control arms would be a good investment. After lowering mine and dialing out the excess rear camber with LCAs the car became oversteery again like stock with wider wheels and sticky tires.
ATL BRZ is offline
Old 12-10-2012, 10:53 PM   #6
Timtamtt
Timtamtt's Avatar
Wheel specs? And how much are those coilovers? Looking good so far!
Timtamtt is offline
Old 12-10-2012, 10:56 PM   #7
ill roller
I think it's too high... I don't think the camber is excessive... And I'm taking the 255/35's off the rear in favor of crappy 225/40's.
I may get the rear lower control arms to make the wheels more flush, or I may just space the rears.
18x9.5 +38. Coilovers are about $1300 retail.
Old 12-10-2012, 11:08 PM   #8
Timtamtt
Timtamtt's Avatar
Get 40 sidewalls 225 so stretch and moar camber. Like -7 degrees. Hellaflush haha. That'll be somewhat like my setup till I can afford some rpf1s hahaha then I'll go function > form
Timtamtt is offline
Old 12-10-2012, 11:14 PM   #9
ebphoto
Drives: FR-S, NA8, S13
spray tint tails?
..think more stretch and less camber would make the wheels look sickk.
ebphoto is offline
Old 12-10-2012, 11:15 PM   #10
ill roller
The front has 225/40/18, I think I'm going to put those in back and get 225/35/18's for the front. I won't be adding any camber... This is not a function>form setup, the car will be driven hard and tracked.
Originally Posted by ebphoto View Post
spray tint tails?
Yeah, painted... Still not sure on whether i'll be straightening camber or spacing, but smaller rear tires are happening for sure.
Old 12-10-2012, 11:18 PM   #11
EarlQHan
Drives: Subarus
i hate you
EarlQHan is offline
Old 12-10-2012, 11:21 PM   #12
ill roller
Originally Posted by EarlQHan View Post
i hate you
EARL! Love you!
Old 12-10-2012, 11:37 PM   #13
nix
nix's Avatar
Drives: AVO BRZ
Looks good mang. Any rubbing on the front?
nix is offline
Old 12-10-2012, 11:39 PM   #14
ATL BRZ
ATL BRZ's Avatar
Well I'll be interested to see how it performs on a road course with even less ride height than that, less suspension travel and that much rear camber with stretched tires. This car tends to understeer at the limit when it's much lower and stiffer without R compounds, even then it requires lots of driving skill to really get the most out of it. Check this thread out: http://www.ft86club.com/forums/showthread.php?t=10643
Specifically, regarding camber:
"One thing we noticed is that the car has a fairly low roll center and if the car is lowered much at all the lower control arms will point upward with the roll center quickly ending up below ground. This will do two things that are not so great; the car will have a large roll couple and a strong tendency to roll which must be countered with stiff springs and/or swaybar. However the FR-S does have a very low center of gravity due to the low slung boxer engine so perhaps this may still be tolerable.
Next due to the angularity of the lower arm when lowered, the front suspension will lose negative camber under roll which will reduce grip and even lead to understeer in a low car unless a lot of static negative camber is dialed in or roll is greatly reduced with stiff suspension. Big negative camber hurts braking traction and causes the car to be road crown sensitive and tramline on cracks and grooves. Being too stiff hurts mechanical grip. Whiteline if you are reading this, this car really needs your long shank ball joints and tie rod ends to correct the roll center. Make some right away please. Maybe your Subaru kit might fit. The best solution before the aftermarket responds might be to not lower the car more than 1.5” or so."
-Mike Kojima http://www.motoiq.com/magazine_artic...cion-fr-s.aspx
What's a roll center?
Fairly good reference article
http://www.onedirt.com/tech-stories/...r-roll-center/
I like the red tails against the red paint.
ATL BRZ is offline
The Devil made me do it SVThis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 11-25-2012 04:08 PM
Daily Use Or Weekender JLMtm Scion FR-S / Toyota 86 GT86 General Forum 64 11-01-2012 01:29 PM
8000K HIDs...too risky in Cali? KGFRS86 Southern California 12 10-14-2012 10:44 PM
Thank Allah, God, Devil, witches, Tom Cruise or whom ever you worship Sojhinn BRZ First-Gen (2012+) — General Topics 20 07-26-2012 01:06 PM
Ken Gushi Teaches Joey Logano How To Drift FR-S and GReddy Racing Drift FR-S Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 07-05-2012 04:06 PM
