#1821 |
Drives: Flat grey Toyota 86
This kit has to have both a waste gate and a blow off valve. The waste gate in this case is an internal waste gate because its part of the turbo assembly, the waste gate is required to control max boost level by bleeding off exhaust gases around the turbo. A blow off valve is required to bleed/blow off the compressed intake charge when the throttle body closes, this is not optional. Now there is recirculating BOV's and vent to atmosphere BOV's and correct me if I'm wrong but a Bosch recirculating BOV does come with the stage 1 kit and recirculates the bleed/blown off compressed intake charge into the silicone opening shown here.
#1822 |
Drives: AVO BRZ
A BOV isn't mandatory at all for low boost turbo setups but it's a good idea.
I got some bad news today from AVO ... confirmation of the factory delay pushing the first run to mid January. There will be a couple of preview kits going out this month to each continent though so we should still see some nice builds and magazine articles etc before Christmas.
#1823 |
Drives: AVO BRZ
It depends who and where you get the kit from. In AU the base kit comes with just the hardware, then the ecutek map, bov, air filter and catback exhaust are all add-ons. I can't speak for US but I'm pretty sure Paul has answered this already.
#1824 |
Is the port in the picture just going to be plugged then along with the port on the underside of the pipe that connects to the TB?
I would not call this an option if what you say is true its an additional cost over the base kit which would be incomplete without it. |
#1825 |
It would be nice if their website had an itemized list of what's in the kit.
#1826 |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
It used to. I noticed the itemization wasn't there when I put down my deposit.
I went with the ceramic coating upcharge and BOV.
#1827 |
Nice choices
#1828 |
Now with Boost!
Drives: 2013 SWP BRZ Ltd.
Also went with the ceramic coating and BOV
![]() Bummer about the production delays. |
| The Following User Says Thank You to vubaru For This Useful Post: | ngabdala (12-05-2012) |
#1829 |
Drives: BRZ WRB
I'd love to have ceramic coating of the whole manifold\turbo\overpipe combo
I just hate heat wraps - ugly looking and oil&mud- absorbent = fire risky & smelly OMG look what brake cool ducting you gotta have to cope with THAT MUCH POWA... yikes... I wonder why it's not listed in the kit description...)
#1830 | |
Drives: BRZ DGM
#1831 | |
Drives: FR-S Firestorm
Its a cheap plastic bypass valve. ( Type on google images : Bosh BPV ) It is exactly the same part that usually comes on a factory turbocharged car like I use to have on my stock RX-7 TT and also on the genesis coupe 2.0T. The air coming out from that valve is pushed back into the intake system and it is almost impossible to hear it. If you unplug this valve, the air will be release into the atmosphere like an aftermarket BOV but the sound it will make will not be really nice to hear...
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow - 2007 Honda CBR 600RR - 2002 Bombardier Legend 800SE Website : http://nofear99.monchar.com |
#1832 | |
I Love custom Turbo kits
Drives: Limited BRZ
A BPV is different than a BOV. The kit includes a BPV but no BOV. BOV is optional.
#1833 |
BOV and BPV are the same thing, they serve exactly the same function. The only difference is where the compressed intake charge is routed.
| The Following User Says Thank You to Lawnik For This Useful Post: | t0dd (12-06-2012) |
#1834 | |
You just need to put a plug at the place where the BPV was connected to send the air back into the intake system.
| The Following User Says Thank You to NoFear99 For This Useful Post: | Sportsguy83 (12-06-2012) |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
