| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Drives: 2012 honda civic ex
you don't need to! if ya just run through the gears quickly,and settle into 6th
you will be fine!.just make sure your revs are high enough so as to NOT lug the engine,as mentioned! this applies to every manual i have ever driven,and the frs/brz is no exception. |
#30 | |
#31 |
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Once I hit the 1k mile mark I forsee my mileage jumping quite a bit too. The break in takes soooo long! Will probably be done this week though as I'll start my 40 mile a day commuting!
#32 |
I see your mileage going down. Since you will be able to take it above 4k. The car to me didn't feel broken in until around 5k.
Sent from my flux capacitor using Taptalk |
#33 |
Drives: DGM BRZ Limited
I avg 26.5 on last tank. The computer shows 28.4 right now, because of a little freeway trip I did today. Drifting hurts gas mileage pretty bad. But I am pretty impressed with the mileage I have gotten so far.
#34 | |
Drives: BRZ Limited arrived on 9/1/2012
#35 |
Drives: really slow...
I use divide my trip miles by the number gallons of I put in. Reset then repeat...
With the stock Prius Primacy tires I easily average between 30/34miles city/hwy. My "street" set is averaging significantly lower after upgrading to 245/18 Hankook Evo V12 tires. The change in compound, increased width, and tread pattern cost me a few mpgs. I'm now averaging around 26/28mpg city/hwy. It would be worse if I installed stickier and wider tires on here. You can also rule out increased wheel weight. My current 18" wheel combo is lighter than stock. I had the chance to reconfirm this at my last track event. I drove to and from the track in the Prius tires which got me back up to 34mpg. Also, on the track, at near redline every time, I was averaging 25mpg!!!!!!!!!!!!!!! Shocker. I'm 6AT btw! |
#36 |
Drives: 13LTDWRBBRZ6MT
Drive a purpose built car with a purpose! I'm with you on this, I feel like I'm not doing the car justice if its not being pushed.
"Subaru is the Japanese name for the Pleiades star cluster, which in turn inspires the Subaru logo and alludes to the six companies that merged to create FHI."
| The Following User Says Thank You to BoxeRZ For This Useful Post: | 86BRZ (12-03-2012) |
#37 |
Chief
Drives: 2013 DGM BRZ Premium 6MT
Interesting for me, my mileage has hardly changed since before and after the break-in. Normally fluctuates between 26-28 MPG and that's with me getting on it from time to time. And as others have said, when I'm cruising (over 40 MPH), I'm in 6th gear.
#38 |
Drives: 2015 WRB WRX Premium
27 mpg 75% city 25% hwy driving. Not bad considering my last car (subaru legacy) got only 21 mpg on average.
I love this car. |
#40 |
I'll be able to take it above 4k, but I'll also be able to maintain a steady speed again. That's whats really going to save me some gas. Right now I'm all over the range.
#41 |
Codename: Stitch
26.4 MPG over 2500 miles. Mileage went up as high as 28 during the first 1000 because I was keeping under 4k rpms. Took a big dip to 24.x when I broke through and started revving it, and now it's up and down dependent on how much I'm flooring it. Not too bad, I see it as an improvement over the 24 MPG avg I was getting from commuting in my Lexus.
BTW I use an app for iPhone called Gas Manager, pretty neat analysis functions and charts/graphs etc. Free on App store. And the car computer's mpg is optimistic by over 1 MPG compared to real math.
#42 |
Drives: Attitude
| Why isn't the fuel economy better? | White Shadow | Scion FR-S / Toyota 86 GT86 General Forum | 495 | 10-28-2019 08:21 AM |
| Canadian fuel economy different rating | Oilers99 | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 10-04-2012 08:16 AM |
| Optimistic fuel economy? | nubbster927 | BRZ First-Gen (2012+) — General Topics | 15 | 07-05-2012 08:50 PM |
| Subaru shows courage to cut horsepower for fuel economy | [es vi: eks] | Engine, Exhaust, Transmission | 11 | 05-01-2011 02:02 PM |
| Fuel Economy | Lexicon101 | Engine, Exhaust, Transmission | 38 | 02-22-2010 03:50 PM |
