#15 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
How log do you need to leave the battery disconnected to reset the ecu anyhow?
#16 | |
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Here in Europe I see around 450 km(280 miles) if cruising on highway and about 320 km (200 miles) when on B road (14 liter/100km). Did you swap for for a Boxer diesel 2.0 engine
#17 |
I was under the impression that the MPG calculation was based off the injector duty and not the airflow.... The injector duty is calculated from the airflow reading and load (amongst a few other things). So it would be calculated AFTER the airflow was already analyzed and not during...
#18 | |
Drives: car
Changing anything related to the MAF or the fuel system actually skews a ton of stuff. It's not something to take lightly. The ECU is smart enough that you as a driver usually won't notice it but on a lot of platforms an intake mod is a huge deal. A lot of people remember putting an ebay cold air intake on some 90s Civic without a MAF sensor. So they don't realize how an intake change has so many implications on a modern vehicle. |
| The Following User Says Thank You to arghx7 For This Useful Post: | Rayme (12-04-2012) |
#19 | |
On a very rudimentary level, say you have two identical cars traveling the same speed with the only difference being MAF reading. Car A with a richer MAF reading is going to get less MPG than Car B with a leaner MAF reading. My point is, the MPG reading doesn't skew with the MAF, it's a reflection of the MAF skew. It's not like it's going to read 45 MPG when your car is running richer or vice versa. It's just a function of the parameters it sees, which includes the MAF sensor amongst other things. But it directly correlates to the amount of fuel being used. |
#20 | |
The Answer
Drives: Mazda 2
#21 | |
Tells it like it is
Drives: SS1LE | F150 Diesel | Civic | S3
You'll be waiting a while for that. The idea is to put more air in the car, volume makes that easiest. A stock tube size cone filter wouldn't add much power if any. Just throw a panel filter in there if you feel that way. Honestly ANY mods should be done with a tune added for them... however I'm waiting a bit for a re-flash til I have a few other things installed.
-Seven || youtube.com/turnsevenvideo
![]() 2012 C6 Grand Sport 4LT 2015 Mazda 3i-T/Tech |
#22 |
How heavy is your foot?? I've hit over 600km's a couple times on mine, with almost all highway driving. I average almost 500km's with mixed city/highway (mostly city) later, with the colder temps and snow tires on.
#23 | |
| Injen, Takeda, and Greddy Intakes!!! | FBPARTS | Engine, Exhaust, Bolt-Ons | 5 | 11-08-2012 03:03 PM |
| INJEN INTAKES FOR FRS & BRZ IN STOCK! LOW PRICES! | genometuning | Engine, Exhaust, Bolt-Ons | 3 | 09-07-2012 04:04 PM |
| Injen Intakes in stock! | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 2 | 08-26-2012 02:29 AM |
| Types of intakes | lbroskee | Engine, Exhaust, Transmission | 6 | 08-25-2012 12:22 PM |
