NASA SpecE30 Racer
The keys to the swap are to move the bleeders on the front calipers from the bottom to the top. This involves removing an allen head bolt and swapping it for the bleeders from the bottom. The other key is getting the DBA rotors that are dual drilled for 5x100 and 5x114. The only hard part is cutting off the rear dust shield as it won't work with the new larger rotors and it doesn't unbolt like it does in the front. I used a set of tin snips as I couldn't get my cut off wheel in there at a good angle. The brake lines are setup for the OEM calipers, but you can easily find a good angle to tighten them down to the caliper. The dimensions of the rear hat are correct for the BRZ parking brake, so that works perfectly as well. My wheels are 18x8 +42 and there is plenty of clearance in the rear, but not much clearance in the front.
2008-2012 STI Front and Rear Calipers 2008-2012 STI DBA 4000 Series T3 Rotors 2008-2012 STI Hawk HPS Pads BRZ Goodridge G-Stop Braided Stainless Steel Brakeline Kit ATE Super Blue Racing Brake Fluid ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Always welcome any comments or questions.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following 30 Users Say Thank You to King Tut For This Useful Post: | ATL BRZ (12-03-2012), azian_advanced (08-19-2013), Bristecom (12-04-2012), chanomatik (12-02-2014), Cross (04-15-2015), disgruntld (01-15-2013), diss7 (08-24-2013), GTB/ZR-1 (12-03-2012), Guff (01-12-2013), humanshield (05-23-2013), Jay2420 (06-10-2014), Jesse (12-29-2012), LeeMaster (12-03-2012), mou (04-22-2013), nix (12-04-2012), normancw (04-29-2013), Ornelas66 (04-14-2015), P@ul (04-25-2014), PRORICAN (12-04-2012), R2RO (05-23-2018), Raven86Project (09-27-2018), slava (10-28-2014), Spartan65 (04-29-2013), StRacngtC06 (05-07-2014), Superhatch (12-03-2012), Surok (12-17-2012), TouchMyHonda (03-26-2013), Wes (12-03-2012), xkalelx (12-31-2014), zohare (01-12-2013) |
#2 |
Will the fronts clear 17" wheels? Looks good!
#3 |
Curious cat.
Drives: 86 GT base M/T - Red
Great work!
![]() Some install pics would be nice. Also, how do they feel compared to the stock brakes? Have you given them a good pounding yet?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
#4 |
NASA SpecE30 Racer
I haven't given them a good pounding. Pedal feel is good, and I would definitely swap to some more aggressive pads at the track. I meant to take pics during the install, but once my hands get dirty then that plan normally goes out the window. I can probably pull the wheels and take some more pics and take pics of the removed dust shields.
- King Tut
#5 |
NASA SpecE30 Racer
I think it would be close. Looks like a little less than an inch of clearance from the top of the caliper to the barrel of the wheel.
- King Tut
#6 |
Site Moderator
Drives: Stuff
Looks good
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#7 |
Drives: K24 Swapped FRS
Looks hawt!
where'd you get the calipers/rotors? I'm thinking of getting this done to my BRZ once it arrives. Thanks |
#8 |
Drives: '13 BRZ in WRB--let's mod!!!
Fantastic!
Well done! |
#9 |
Very cool.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm.. |
#10 |
NASA SpecE30 Racer
I got the four calipers used off a member on NASIOC for $1400 (definitely better deals out there, but this was the only set of 08-12s I could find for sale used), rotors/pads from a vendor on NASIOC for $700, and the brake lines were about $100 from Tire Rack. I had the ATE fluid as I use it for my SpecE30. I definitely feel it was worth the $2200 investment. I also looked at all the Subaru parts stores online, and the best deal I could find for the calipers brand new was $2200 if you want to go that route. I figured the $800 savings was worth going used.
- King Tut
| The Following User Says Thank You to King Tut For This Useful Post: | chanomatik (12-02-2014) |
#11 |
Drives: Attitude
Tip for the rear dust shield: drill out the spot welds. That's what I did when I changed my WRX rears from stock to the "H6" upgrade.
#12 |
NASA SpecE30 Racer
I didn't remember seeing any spot welds to drill out. I will have to take a closer look.
- King Tut
#13 |
Drives: Attitude
Blarg. They may have changed that with the whole rear suspension. I'd check 3GWRX.com or NASIOC to see what the Impreza rear spindle assembly looks like as ours should be identical to that chassis model. I drilled out the spot welds on my GD chassis WRX, but that may have changed.
#14 |
Nicely done. I liked the stock brakes on my old STI, I can only imagine how good they'd be on a lighter car like the BRZ.
| Tags |
| brakes, caliper, sti, swap |
| STI front brakes on BRZ (confirm) | michael317 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 123 | 05-23-2016 12:41 PM |
| GTS Front Brakes + Rotors + Pads | GC GTS Aero Kit | Australia Classifieds | 2 | 11-16-2012 05:20 AM |
| R35 Brembo Brakes - Full set | 2013GTRNate | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 10-06-2012 10:08 AM |
