Old 12-03-2012, 01:18 PM   #1
WRXcellent
Drives: 2013 BRZ Limited WRB & 2002 WRX WRB
Exclamation Recall # WQC39 - ECM Reprogramming for Coolant Thermostat
I just logged into my.subaru and happened to see the following recall listed for my BRZ. Has anyone taken their car in for this update?
Service Program WQC-39
Engine Control Module Reprogramming
Vehicles Registered in the States of
CA, CT, MA, MD, ME, NJ, NY, OR, PA, RI, VT, WA
Dear Subaru Owner:
We would like to thank you for your selection of a Subaru vehicle. At Subaru, we take pride in our products and are committed to your continued satisfaction.
Subaru has developed a modification to the Engine Control Module software logic to improve the monitoring parameters within the On-Board Diagnostic (OBDll) system for the engine coolant thermostat. This correction ensures that should there be an abnormal condition (i.e., the engine coolant does not reach or maintain the proper operating temperature), the “check engine light” will illuminate. The proper illumination of the “check engine light” is needed to alert you that corrective action may be required.
This software change has no effect on fuel economy or vehicle performance
WRXcellent is offline   Reply With Quote
The Following User Says Thank You to WRXcellent For This Useful Post:
Imrac (05-21-2015)
Old 12-03-2012, 01:26 PM   #2
cnk
Drives: '13 DGM BRZ Limited
I just checked and there is nothing listed for my car. Maybe it's only for a specific VIN range.
Old 12-03-2012, 01:49 PM   #3
dsgerbc
Drives: BRZ(sold), STI
That's weird, maybe your dealer did it already.
This is a Subaru-wide recall in certain states. Not a BRZ-specific thing.
Old 12-03-2012, 01:56 PM   #4
cnk
My car has not been back to the dealer since I picked it up in Sept. which is why I was stating it could be a specific VIN range that is affected.
Old 12-03-2012, 02:00 PM   #5
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
It's there for me, vin 00920
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 12-03-2012, 02:02 PM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Any word of this for the FRS?
Old 12-03-2012, 03:28 PM   #7
developer
Drives: BRZ Limited
I just created and checked MySubaru page and I don't show this either. My BRZ is registered in Oregon and my vin is in the 3400 range. Subaru might be rolling this recall out slowly so as to not overwhelm dealers. It would be nice to get the latest ECU flash and see if it evens out my occasional wonky idle.
developer is offline   Reply With Quote
Old 12-03-2012, 04:45 PM   #8
mhigham
Its just a logic check on how quickly the engine is warming up. Cold weather affects, of course, how long it takes the engine to warm up.
If you drive smartly and don't let your car idle, this is probably an non-issue.
mhigham is offline   Reply With Quote
Old 12-03-2012, 04:52 PM   #9
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
Seems to have nothing to do with idle CEL issue.
jacjac3 is offline   Reply With Quote
Old 12-03-2012, 04:58 PM   #10
Sigh-on-Rice
Waited 5 years for this
Sigh-on-Rice's Avatar
Drives: '18 MX-5 Club
I don't understand. Are you saying it is better if we don't idle to warm up the engine?
Old 12-03-2012, 05:12 PM   #11
cnk
I never idle to warm up the engine because you're only warming up the engine and not the trans. You're better off starting the car and taking it easy for the first few miles until the engine and trans are up to temp.
Old 12-03-2012, 06:23 PM   #12
Razz
Razz's Avatar
Drives: Fast
Corporations do secret things.
Like not issuing a TSB or recall. Instead they tell all dealerships to reflash the ECM to fix the idle condition when they come in for the mandatory Thermostat fix.
Some even go so far as to call it a flash for the thermostat when in fact it is really for the idle, especially if they make a minor change to the Thermostat setting, they can can the patch anything they like.
You really never know what a corporation will do.
Just hope the is a patch fr the idle problem along with the Thermostat setting.
Anyhow, from what I understand you still need the VVT components to be replaced and the flash is only a bandaid.
Razz is offline   Reply With Quote
Old 12-03-2012, 06:37 PM   #13
OrbitalEllipses
Drives: Attitude
Yes. The car warm up much faster in 3 minutes of calm driving than it will in 10 minutes of idling.
I have this under Recalls in MySubaru. VIN 02883, located in MD.
MannyO (12-05-2012)
Old 12-03-2012, 06:37 PM   #14
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Hmm wonder why it's just these states. I wonder if there is more going on with this update that is not being shared with us. I see some strict states when it comes to emissions listed there.
Maybe we don't pass an OBD II with one cat if we change our exhaust system.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 09:15 AM
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 04:46 PM
Blue Coolant Boosted2.0 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 108 07-12-2016 06:13 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
European fuel/coolant gauge face arbnpx Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:23 AM
