Old 12-02-2012, 04:35 PM   #85
koyv90
Rocket Bunny FRS
Drives: 2013 Rocket Bunny FRS
Originally Posted by doggy View Post
Done Looking pretty bg in pics cuz of the light color - but in reality its super compact. No interference with Curtain airbag, fixing will be done with doubleside 3M, 60 or 52mm gauges availible Will post once its done in texture / color.
this looks like the best option. IS there any way that it can match in with the dash though? colour wise.
koyv90 is offline   Reply With Quote
The Following User Says Thank You to koyv90 For This Useful Post:
ngabdala (12-02-2012)
Old 12-02-2012, 05:58 PM   #86
doggy
doggy's Avatar
Drives: Scion FRS Firestorm MT
Yes, it will be black (like dash) and have a texture like dash. Tomorow im posting pics of Center pod already in color And later this week there will be pics of single pod installed also.Keep and eye
doggy is offline   Reply With Quote
Old 12-03-2012, 12:13 AM   #87
msa
Drives: 2010 Genesis Sedan 4.6L
Originally Posted by flatline View Post
I am no auto engineer, but color me curious about how this interacts with an SRS airbag going off.
No problem. The airbag functions as a curtain, so it'll shoot down. When deployed, the pillars don't completely separate off the metal frame of the car. As long as there is slack in the wiring and tubing for the gauges and the gauges are snug, you won't see a one go anywhere. The pillar actually comes away from the car itself maybe an inch or two. I'll try to upload images of the clip to help with this image.
msa is offline   Reply With Quote
The Following User Says Thank You to msa For This Useful Post:
Scavanger (09-10-2014)
Old 12-04-2012, 04:25 PM   #88
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
What do you think of this one? We're making this one custom for a turbo install in house. Obviously this is not a finished product. It will require some cutting behind to fit some of the deeper gauges but overall we love the fit. I'm going to do a second pod on the left side with the gauge controls relocated to the trunk release panel where the leveling headlight control would usually be. I'll post pics up once complete as well.
-Mike
PrimeMotoring is offline   Reply With Quote
The Following 4 Users Say Thank You to PrimeMotoring For This Useful Post:
dompower (12-27-2012), eddieflyinv (08-25-2014), Scavanger (09-10-2014), TIE Pilot (12-04-2012)
Old 12-04-2012, 04:32 PM   #89
PrimeMotoring
Heres a pic with sandable primer which actually matches the stock color not too bad.
cto424 (12-04-2012), Kakawate (03-19-2014), Scavanger (09-10-2014), TIE Pilot (12-04-2012)
Old 12-04-2012, 05:02 PM   #90
TIE Pilot
TIE Pilot's Avatar
Drives: TIE interceptor; BRZ13
I think they will look really good. Smart thinking here.
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." Jeremy Clarkson
TIE Pilot is offline   Reply With Quote
Old 12-10-2012, 12:00 PM   #91
msa
Originally Posted by 2forme View Post
Funny you ask; it's an interesting feature. After the airbag goes off, you immediately gain the ability to read gauges from your forehead . Imagine: Boost, Oil Temp, Oil Pressure all readily available while brushing your teeth in the bathroom!
I'm kinda curious about this as well.
Ok. I have some photos of the clips setup.
The first picture is of the clip attached to the pillar. The second is the picture of the clip separated. As you can see, when the airbag goes off, the pillar itself doesn't fully detach from the car. (FYI: The part of the clip that attaches to the vehicle is a real pain to get off.) It will only push out the length of this green clip. I hope that will alleviate any anxiety you guys have of our pillars. (Again, we mold our pods into factory pillars so, all airbag functions are retained. We just received 10 pillar sets in from Scion, so we will begin production soon.)
Old 12-10-2012, 12:04 PM   #92
gmookher
I need something for my BRZ!
Old 12-10-2012, 04:33 PM   #93
doggy
doggy's Avatar
Here we go... Finally managed to make decent pictures.. As i dont have my gauges yet - had to improvise - and use cheap'o looking china-shiz brang gauges - so they are not the best looking ones- sorry
Heres a better looking Defi gauge that i had, with black bezel... Looks 10x better....
Im gonna be experimenting with som eside vents - so will post pics of the pod with vents pretty soon too
The Following 3 Users Say Thank You to doggy For This Useful Post:
C130NAV (05-26-2014), calis5nest (12-15-2012), Loki2x (01-01-2013)
Old 12-10-2012, 07:48 PM   #94
Lammie
Lammie's Avatar
Drives: Subaru BRZ
That looks AWESOME! Depending on these side vents, I'll be needing a quote for shipping to Canada
Lammie is offline   Reply With Quote
Old 12-12-2012, 02:36 AM   #95
msa
We will hopefully have a pillar from a BRZ soon so we can be 100% sure it's the exact same as the FRS.
Old 12-12-2012, 06:15 AM   #96
Xis86
Drives: Whiteout FR-S 6MT
Anyway of having them a slight tilt to the driver?
Xis86 is offline   Reply With Quote
The Following User Says Thank You to Xis86 For This Useful Post:
Hardrock4445 (01-31-2013)
Old 12-12-2012, 06:19 AM   #97
doggy
doggy's Avatar
Why? Gauges are CLEARLY visible, even the last one is totaly visible - and having them tilted to driver would just mean ODD unequal looking shape of the pod... This would not look anyway near good -and there would be none to less better then having them flat... When i was building it - i overlooked almost all the placment issues - and honestly - simple flat is the way to go. I know its hard to get the full view in the photo - but once you are sitting in the seat - its enouth of just one glance without turning your head to see all the gauges clearly...
Old 12-12-2012, 01:57 PM   #98
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
From what ive seen i like the pillar one and maybe the one on the right side of dash. I think a good one would be right on top of the ac vents like how some people have it in the sti, that looks cleanest
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 06:46 PM
LHD 3-meter gauge-pod? TuxedoCartman Cosmetic Modification (Interior/Exterior/Lighting) 27 02-11-2015 07:19 PM
Gas Gauge Issue Jruex22 Scion FR-S / Toyota 86 GT86 General Forum 12 04-04-2013 11:28 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
Gauge Sweep? himbo BRZ First-Gen (2012+) — General Topics 17 12-12-2011 12:39 PM
