Old 11-30-2012, 06:57 PM   #15
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
MODS PLEASE STICKY THIS!!
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 11-30-2012, 07:34 PM   #16
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
BTW Essex Sprint needs at least a 10MM spacer to clear the OEM wheel.
Will sticky this for now, if it doesn't get updated more often there's not much reason to leave it as a sticky though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-30-2012, 07:40 PM   #17
Hanakuso
Are you sure? I was almost certain 7-8mm would be good enough.
Hanakuso is offline   Reply With Quote
Old 11-30-2012, 08:05 PM   #18
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You need some space for the expansion of the calipers and other components as they get hot. With a 10mm spacer it appears to have maybe 2mm of clearance.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-11-2012, 12:18 AM   #19
RavenFR-S
I have a request.
Will someone do these patterns, please?
Brembo GT Front 345x28mm (Use for Front and back)
http://www.carid.com/images/brembo/p...-1b1.8002a.pdf
Brembo GT 2-Piston Rear 316x20mm
http://www.carid.com/images/brembo/p...-1b1.7017a.pdf
RavenFR-S is offline   Reply With Quote
Old 01-09-2013, 03:49 PM   #20
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Some confirmed wheel fitments without spacers on our Essex Sprint and Endurance Systems:
Sprint
Enkie RPF1 17x8 45
Wedsport TC105n 17x9 35
Mach V Motorsports "Awesome" wheel 17x9 42
Work Ultimates 18x8.5 47
Sparco (designed by OZ) Assetto Gara 17x7.5 48
Endurance
Enkie RPF1 17x8 45
BBS CH-R 18x8 38
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
shaunsweeney (12-19-2013)
Old 01-31-2013, 09:03 AM   #21
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Just tried a few templates on my Rays CE28 18x7.5 47 offset wheels
The following were ok.
Essex AP Sprint , Essex AP Endurance, AP 4 pot formula bbk and interestingly the endurance had more caliper space than the sprint on these wheels.
The following didn't fit
AP 6 pot formula bbk ( calipers caught on spoke )
4 pot AP FBBK
Sprint
Endurance
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 01-31-2013, 10:02 AM   #22
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You can add my WedsSport TC105N 18x8 +42 and 08-12 OEM Subaru STI Brembo brakes.
SkAsphalt (11-28-2013)
Old 02-04-2013, 11:40 AM   #23
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Hi guys, need advice on whether the essex sprint bbk will clear Work kiwami 18x7.5 +38?
Fizz is offline   Reply With Quote
Old 02-20-2013, 03:13 PM   #24
stockysnail
Just the tip
stockysnail's Avatar
Can anyone chime in and say they have used the OEM wheels with the Sprint Kit with 10mm spacer or whatever they are using? I read that if I run a spacer larger than 5mm that I will need new/longer lug bolts. Is that also true? I'd rather not spend extra $ on new wheels if I don't need to. I run the OEM wheels with winter tires and 18" Neuspeed RS10 with RE11s so I'd rather not buy more wheels.
Old 02-20-2013, 03:33 PM   #25
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I would suggest longer studs for sure. They are pretty cheap and easy to install or you could go with a 15mm spacer that includes them on the spacer itself, then it's real quick.
They need 10mm spacers. I haven't driven the car with them but I use an OEM wheel/tire as my spare tire so I carry the 10mm spacers just for that. I am running ARP extended studs in my car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-01-2013, 08:07 PM   #26
Delsy
Delsy's Avatar
Drives: Gt86
Hi, I installed 18 x 8.5 w/ 45 offset, would brembo 4 & 6 piston BBK will fit? Thanks
Delsy is offline   Reply With Quote
Old 03-01-2013, 08:22 PM   #27
Gambit
Gambit's Avatar
Drives: Subaru
Ask for an installation cutout diagram that you can test fit to the wheel in order to check clearance
Gambit is offline   Reply With Quote
Old 03-13-2013, 01:36 AM   #28
mike@vossen
Drives: GS F-sport | LS F-Sport
I wish there were pics installed with wheels to see.
mike@vossen is offline   Reply With Quote
big brake kit, brembo, essex, stoptech, template
Dyno Database E92M3Guy Engine, Exhaust, Transmission 33 04-17-2013 11:20 AM
The *Official* BRZ Pre-Ordered Database Thread Zaku BRZ First-Gen (2012+) — General Topics 727 03-17-2013 08:29 AM
We should start a dealer BRZ order database eikond BRZ First-Gen (2012+) — General Topics 13 03-01-2012 01:56 PM
