Old 11-29-2012, 05:54 AM   #1
venom8776
venom8776's Avatar
Drives: 2013 Subaru BR-Z
Smile Dealership is charging me $1725 to replace my OEM clutch for BR-Z
Hey guys, the dealership nearest to me is charging me $1725 to replace my OEM clutch and flywheel (as a kit) for BR-Z. Should I pay for it or go somewhere else? They have the replacement OEM clutch from Japan.
FYI: The current clutch right now is completely burnt out.
Any suggestions or advice?
Thanks!
(new subaru br-z owner as of august 2012)
venom8776 is offline   Reply With Quote
Old 11-29-2012, 06:10 AM   #2
DelayedBRZ
Drives: GBS BRZ, Auto Limited
Why are you paying?
Since you've only had the car since August, why are you paying to have the OEM clutch replaced? Seems if anything went wrong the warranty should take care of parts failure at this point?
DelayedBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to DelayedBRZ For This Useful Post:
suaveflooder (02-02-2014), venom8776 (01-17-2013)
Old 11-29-2012, 06:15 AM   #3
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
If you're replacing the clutch, why not just get a better clutch since you've already burnt out the OEM one.
Side note: How did you burn out the clutch already? I have a beater civic with over 220K miles still on the original clutch
ihaskrayon is offline   Reply With Quote
The Following 2 Users Say Thank You to ihaskrayon For This Useful Post:
venom8776 (01-17-2013), _F-R-S_ (12-24-2012)
Old 11-29-2012, 07:23 AM   #4
Jason952
Should be covered, find a better dealer, call sub usa
Jason952 is offline   Reply With Quote
The Following User Says Thank You to Jason952 For This Useful Post:
Old 11-29-2012, 07:49 AM   #5
brufleth
Drives: 2007 WRX
That seems high. I think it was about $1800 for me to get my clutch replaced on the WRX and they have to take half the car apart to do that. From what I've seen/heard it should be easier to replace the BRZ clutch. Might be worth shopping around.
Also, like others have said, if you already burned up the stock clutch it might be worth getting a better one. I believe Clutchmaster has a kit for the BRZ. I don't know much about clutches though.
brufleth is offline   Reply With Quote
The Following User Says Thank You to brufleth For This Useful Post:
Old 11-29-2012, 08:08 AM   #6
Lammie
Lammie's Avatar
Drives: Subaru BRZ
I though clutches were considered a wear and tear part so it's not covered by warranty.
Lammie is offline   Reply With Quote
The Following User Says Thank You to Lammie For This Useful Post:
Old 11-29-2012, 08:17 AM   #7
Burrcold
Drives: Subaru BRZ Limited
It is a wear and tear item, but you really must have been hard on it to burn it out in 4 months! In that case, they're not going to allow it as a warranty item.
Did you just learn to drive manual? Or were you dumping the clutch every run?
The Following 2 Users Say Thank You to Burrcold For This Useful Post:
jbsali (02-02-2014), venom8776 (01-17-2013)
Old 11-29-2012, 08:18 AM   #8
ayau
Drives: Some rust bucket
How are you already replacing your clutch on a 4 month old car?
The Following 2 Users Say Thank You to ayau For This Useful Post:
hmong337 (02-02-2014), venom8776 (01-17-2013)
Old 11-29-2012, 08:37 AM   #9
Justin.b
Drives: 13 Hot Lava, 01 Miata, 09 Outback
How much for this poor BRZ to upgrade it's driver?
Honestly, have someone teach you how to drive a standard. You're riding the clutch. There's no other way to burn the clutch out this soon.... unless you made it to 60k miles already, and even then it's still on the early side.
-Justin
Justin.b is offline   Reply With Quote
The Following 7 Users Say Thank You to Justin.b For This Useful Post:
Fallen hero (12-28-2012), flippy (11-30-2012), jabbajaw99 (12-02-2012), jbsali (02-02-2014), ngabdala (11-29-2012), tripjammer (02-06-2014), venom8776 (01-17-2013)
Old 11-29-2012, 09:51 AM   #10
swift996
swift996's Avatar
Wow. I'm looking forward to seeing how well these clutches hold up over time and with forced induction. I remember I had a 92 Prelude back in the day with 280k miles (snapped a timing belt) but still original clutch.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
Old 11-29-2012, 09:58 AM   #11
Jayde
Jayde's Avatar
I hope the OP didn't learn to drive stick on that car...
Then again, I learned to drive stick on my old car that already had 159k on it. Don't know if it was the original clutch, but it lasted me 5 1/2 years and 30+k miles and was still fine when I let it go.
Jayde is offline   Reply With Quote
The Following User Says Thank You to Jayde For This Useful Post:
Old 11-29-2012, 10:01 AM   #12
Justin.b
He obviously has learned on this car. If he had experience with clutches he'd be quite upset at the OEM one checking out in 4 months.
This guy could possibly be changing his clutch before his first oil change.
-Justin
The Following 5 Users Say Thank You to Justin.b For This Useful Post:
b.e (11-29-2012), jbsali (02-02-2014), LeeMaster (11-29-2012), TheGuyWithTheFireStorm (11-29-2012), venom8776 (01-17-2013)
Old 11-29-2012, 10:14 AM   #13
jmaryt
Drives: 2012 honda civic ex
-Justin
this is true! if you partially engage the clutch while '"riding" it,
you WILL burn it up! the only mechanical wear item on the clutch
that would require replacing over time is the 'throw-out" bearing,and even this part should realistically go way over 100,000 miles before giving it up! keep your foot OFF the clutch,and they will last a very long time!..just sayin'
jmaryt is offline   Reply With Quote
The Following 2 Users Say Thank You to jmaryt For This Useful Post:
Mikepage (11-29-2012), venom8776 (01-17-2013)
Old 11-29-2012, 10:17 AM   #14
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So you are saying you didn't change the timing belt for 280K miles??
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
ngabdala (11-29-2012), TouchMyHonda (12-01-2012), venom8776 (01-17-2013)
clutch, dealership, flywheel, oem, repair
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 01:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 11:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 01:06 PM
adding a second usb port for charging? Reason Electronics | Audio | NAV | Infotainment 5 07-11-2012 08:47 AM
Dealers Charging Markup - List Spd229 Southeast 1 05-08-2012 02:22 PM
