#1667 | |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Yup. 1 day . Anyways, I'm not here to shatter anyone's delusions. I agreed with a fellow forum member. As I said, I want this kit. If you think this is scrutiny go find my posts about the BRZ back in May and June.
I appreciate your opinion and you standing up for what you believe in. Quote:
#1668 |
Let's start here:
http://www.nrhsperformance.com/tech_power.shtml That is to get one area cleared out - all dyno's read flywheel torque, by measuring whp. However, in the dyno sticky in the engine section, all the dyno's don't work the same way. Japan is using a dynapack, and the dynapack works by bolting up to the hubs and simulating load. Due to that, they read, on average, 9-10% higher than a Mustang dyno. And because it's reading hub, it's calculating the figures differently in the software. For instance, it's seeing 800ft/lb's of torque at the hub in the particular gear selected at the particular rpm. Then it's calculating back from that. The particular issue is that the "compressed" dyno chart it's making by forcing the torque chart over the whp (calculation) chart is changing the curves. I'll get them to use the split view. But it's still not going to look like a dyno chart from the roller dynos. And in regards to testing the kit, we tested it for 8 weeks in Japan before we did the American road test and tune. And the drive to SEMA takes 2 days down, 2 days back. We weren't driving at 100mph both ways (talk about math...) and we were reflashing (frequently) which involved a lot of stops. |
#1669 |
Drives: Very very slowly
Paul,
I disagree with you and NHRS as to the definition of a dyno: http://en.wikipedia.org/wiki/Dynamometer ps. It was great chatting with you.
#1670 |
First, this is my mistake, but Japan posted the graph to show where they reached the max duty cycle on the stock injectors finally. Well, 90% duty cycle at 6.5psi to be exact, which is the furthest they will go and consider it safe. So it was basically incidental that they reached to those figures and power.
Due to the questions here, I went back and talked with them about it, and reached an understanding of what's going on with the power figures. As a side note here, as many people know that Japan doesn't use hp or bhp at the crank, they use PS at the crank for their power figures, which reads a little higher than our hp. Our Japan office is also a Subaru Dealer, and as a courtesy to their customers, dyno's the cars stock for them to verify the power output matches the manufacturer claims. Initially they didn't, but after talking with Dynapack Japan, they ended up with a 1.14 conversion factor for the torque to match up with the manufacturer's data. That isn't applied to the whp figure, though (since the dynapack is using that to generate the flywheel torque), which is why the numbers don't add up. For instance, at 250whp/6000 rpm, it's showing about 250ft/lbs of torque. As noted, the math doesn't add up. Multiply 250 x 5252 and divide by 6000, and you end up around 218ft/lbs. However, multiply that by 1.14, and you end up with the 249ft/lbs of torque figure on the graph. So the math was wrong, and also slightly right. To wrap it up, their whp figures are accurate, it's their torque figures that are high. But if you use the dyno as it's intended, a before/after measurement, it's still doing both accurately, it's just that we have a higher start point for the torque (and end point). From now on, whenever they do any testing, they'll run the dyno without the correction figure on the torque output so that there is no confusion on that end. But for now, the stock power to stage, um, 1.875. ![]() Stage 1 power to stage 1.875.
#1671 |
Site Moderator
Drives: Stuff
Paul, thank you for having them correct that, it'll be a LOT less misleading that way.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#1672 |
#1673 |
Drives: it has 4 wheels and a motor
this works better:
[ame="http://www.youtube.com/watch?v=315BAOsePsk"]Drift-Office : AVO TurboWorld 6MT FRS Turbo Kit ~ Stage 1 - YouTube[/ame] |
#1674 |
Drives: GT86
So a 14% fudge factor just to meet the advertised power? So are you saying the dyno is inaccurate or the manufacturer is inflating power figures.. Or perhaps the test method is simply invalid?
#1675 |
Drives: Subaru BRZ
There is another Dyno graph posted up on the BRZ Sports Car Club Facebook page by AVO Japan, the figures and units are different but it seems to work with the math
#1676 |
Drives: Skoda Yeti DSG diesel 4x4
I sent a pm but no reply so trying the same message here?
I have a Nameless axle back and downpipe with hi flow cat ready for my GTS86 due about Xmas. You mentioned the St 2 tune was the addition of the over pipe and down pipe with HF cat, I assume 2 parts as stock? That means you must be making 2 versions of the overpipe to suit both LH and RH drive. Could I purchase a RHD overpipe from you in Australia? |
#1677 |
I Love custom Turbo kits
Drives: Limited BRZ
My understanding is the 14% fudge factor is to bring the stock numbers back to flywheel numbers. Manufacturer does not advertise Wheel numbers, but Flywheel numbers, so that 14% accounts for the difference between Flywheel power and wheel power.
#1678 | |
Drives: Limited BRZ
#1679 | |
The OEM effort looks like a strangled turd because it can fit both but to get a decent 2.5" mandrel effort each one has to be different. That's my understanding anyway. AVO are releasing the kit in both countries soon so i'm assuming they made an overpipe for each application? I could have had the Nameless downpipe with HF cat 'and' the over pipe for another $100 but they knew it wouldn't fit. I know it wont be $100! |
#1680 | |
Drives: Limited BRZ
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| FT-86 SpeedFactory - Firestorm Red - Build Thread | FT-86 SpeedFactory | Member's Car Journals | 38 | 02-26-2015 02:42 PM |
| JoeBoxer FR-S build thread | JoeBoxer | Member's Car Journals | 112 | 04-08-2013 01:19 AM |
| Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
| Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
