Old 11-28-2012, 06:02 PM   #1667
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Yup. 1 day . Anyways, I'm not here to shatter anyone's delusions. I agreed with a fellow forum member. As I said, I want this kit. If you think this is scrutiny go find my posts about the BRZ back in May and June.
I appreciate your opinion and you standing up for what you believe in.
Originally Posted by deucethemoose View Post
1200 mile drive to SEMA =/= street? (technically 2400 miles, as he had to come home afterwards...)
An entire day beating the shit out of it on a track by multiple people and recorded for your viewing pleasure =/= track?
What exactly are you looking for? Lets not beat around the bush here. If you were to post a specific question or request I am sure you will get the answer you're looking for from Paul. He has been nothing but forthcoming and aboveboard here.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 11-28-2012, 06:13 PM   #1668
AVOturboworld
Let's start here:
http://www.nrhsperformance.com/tech_power.shtml
That is to get one area cleared out - all dyno's read flywheel torque, by measuring whp. However, in the dyno sticky in the engine section, all the dyno's don't work the same way. Japan is using a dynapack, and the dynapack works by bolting up to the hubs and simulating load. Due to that, they read, on average, 9-10% higher than a Mustang dyno.
And because it's reading hub, it's calculating the figures differently in the software. For instance, it's seeing 800ft/lb's of torque at the hub in the particular gear selected at the particular rpm. Then it's calculating back from that.
The particular issue is that the "compressed" dyno chart it's making by forcing the torque chart over the whp (calculation) chart is changing the curves. I'll get them to use the split view. But it's still not going to look like a dyno chart from the roller dynos.
And in regards to testing the kit, we tested it for 8 weeks in Japan before we did the American road test and tune. And the drive to SEMA takes 2 days down, 2 days back. We weren't driving at 100mph both ways (talk about math...) and we were reflashing (frequently) which involved a lot of stops.
Old 11-28-2012, 07:39 PM   #1669
buditjoenawan
Drives: Very very slowly
Paul,
I disagree with you and NHRS as to the definition of a dyno:
http://en.wikipedia.org/wiki/Dynamometer
ps. It was great chatting with you.
buditjoenawan is offline   Reply With Quote
Old 11-28-2012, 09:02 PM   #1670
AVOturboworld
First, this is my mistake, but Japan posted the graph to show where they reached the max duty cycle on the stock injectors finally. Well, 90% duty cycle at 6.5psi to be exact, which is the furthest they will go and consider it safe. So it was basically incidental that they reached to those figures and power.
Due to the questions here, I went back and talked with them about it, and reached an understanding of what's going on with the power figures. As a side note here, as many people know that Japan doesn't use hp or bhp at the crank, they use PS at the crank for their power figures, which reads a little higher than our hp. Our Japan office is also a Subaru Dealer, and as a courtesy to their customers, dyno's the cars stock for them to verify the power output matches the manufacturer claims. Initially they didn't, but after talking with Dynapack Japan, they ended up with a 1.14 conversion factor for the torque to match up with the manufacturer's data. That isn't applied to the whp figure, though (since the dynapack is using that to generate the flywheel torque), which is why the numbers don't add up.
For instance, at 250whp/6000 rpm, it's showing about 250ft/lbs of torque. As noted, the math doesn't add up. Multiply 250 x 5252 and divide by 6000, and you end up around 218ft/lbs. However, multiply that by 1.14, and you end up with the 249ft/lbs of torque figure on the graph. So the math was wrong, and also slightly right.
To wrap it up, their whp figures are accurate, it's their torque figures that are high. But if you use the dyno as it's intended, a before/after measurement, it's still doing both accurately, it's just that we have a higher start point for the torque (and end point). From now on, whenever they do any testing, they'll run the dyno without the correction figure on the torque output so that there is no confusion on that end.
But for now, the stock power to stage, um, 1.875.
Stage 1 power to stage 1.875.
Old 11-28-2012, 10:59 PM   #1671
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Paul, thank you for having them correct that, it'll be a LOT less misleading that way.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 11:04 PM   #1672
BRZranger
AVO turbo installed / dynoed before SEMA
BRZranger is offline   Reply With Quote
Old 11-28-2012, 11:13 PM   #1673
nonicname
Drives: it has 4 wheels and a motor
this works better:
[ame="http://www.youtube.com/watch?v=315BAOsePsk"]Drift-Office : AVO TurboWorld 6MT FRS Turbo Kit ~ Stage 1 - YouTube[/ame]
nonicname is offline   Reply With Quote
Old 11-29-2012, 12:22 AM   #1674
ft_sjo
Drives: GT86
So a 14% fudge factor just to meet the advertised power? So are you saying the dyno is inaccurate or the manufacturer is inflating power figures.. Or perhaps the test method is simply invalid?
Old 11-29-2012, 12:53 AM   #1675
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
There is another Dyno graph posted up on the BRZ Sports Car Club Facebook page by AVO Japan, the figures and units are different but it seems to work with the math
ahaghshenas is offline   Reply With Quote
Old 11-29-2012, 01:22 AM   #1676
sierra
Drives: Skoda Yeti DSG diesel 4x4
I sent a pm but no reply so trying the same message here?
I have a Nameless axle back and downpipe with hi flow cat ready for my GTS86 due about Xmas. You mentioned the St 2 tune was the addition of the over pipe and down pipe with HF cat, I assume 2 parts as stock?
That means you must be making 2 versions of the overpipe to suit both LH and RH drive.
Could I purchase a RHD overpipe from you in Australia?
sierra is offline   Reply With Quote
Old 11-29-2012, 06:32 AM   #1677
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
My understanding is the 14% fudge factor is to bring the stock numbers back to flywheel numbers. Manufacturer does not advertise Wheel numbers, but Flywheel numbers, so that 14% accounts for the difference between Flywheel power and wheel power.
Old 11-29-2012, 06:36 AM   #1678
Sportsguy83
Drives: Limited BRZ
I'd say looking at the fact that they already developed an overpipe for USA (confirming your thoughts that it will be two parts like stock), I would say yes, they will develop one for RHD. (It probably is the same for LHD and RHD).
Old 11-29-2012, 06:51 AM   #1679
sierra
The steering column makes the route for the RHD slightly different apparently?
The OEM effort looks like a strangled turd because it can fit both but to get a decent 2.5" mandrel effort each one has to be different. That's my understanding anyway.
AVO are releasing the kit in both countries soon so i'm assuming they made an overpipe for each application?
I could have had the Nameless downpipe with HF cat 'and' the over pipe for another $100 but they knew it wouldn't fit. I know it wont be $100!
Old 11-29-2012, 06:54 AM   #1680
Sportsguy83
Drives: Limited BRZ
Oh I agree with you 100%, that's why Nameless made it different. I am just guessing AVO would be ready to sell this in their land
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
