Old 11-17-2012, 02:54 AM   #29
jstans84
Drives: Scion FR-S
Pandora sounds perfectly fine via bluetooth with my HTC EVO LTE. All the other music I play I run through Winamp Pro and it sounds great as well.
jstans84 is offline   Reply With Quote
Old 11-28-2012, 02:51 PM   #30
bdbx18
Drives: Present MDX, Civic Hybrid, BRZ
Originally Posted by luscious View Post
Sooooooooo....
I flashed my GS3 back to stock, installed Power Amp and tried it...
Instant success! Sounds awesome.
I dont know what it is about CM10 and AOKP Jellybean that caused it..but this did the trick. Now i have to get to the bottom of this so i can run mods again.
On the latest CM10 nightly build, bluetooth bass was fixed. The previous fix was to make a call, hang up and then full fidelity was restored.
bdbx18 is offline   Reply With Quote
Old 11-29-2012, 01:11 AM   #31
DarkReign
DarkReign's Avatar
Drives: Raven FR-Sg, Mazda Rx7 FD
My Galaxy S3 sounds amaizing through pandora. Jelli and music loaded on the phone. Way better than my old Iphone 4. I am running the pioneer avh4400 though. Not using any other apps from the phone. The stock HU isnt really up to the task when it comes to this. Swap it out when youre ready and let the music move you.
DarkReign is offline   Reply With Quote
Old 11-29-2012, 10:48 AM   #32
I've used the Amazon Cloud Player and SiriusXM through my Droid X over BT to the standard FR-S headunit. The sound is great, only issue is I have to do the "adjust the volume immediately after selecting BT" trick mentioned above.
Old 11-29-2012, 01:00 PM   #33
apexaddict
For people who are wondering, this is a ROM issue. I don't understand the cause of it, but I do know that for whatever reason, using certain music apps with AOSP-based ROMs (like CM10 or AOKP) gives you no volume control on the normal, non-Bespoke head unit. I normally use Spotify, so I've tested it with a number of phones:
T-Mobile GS2 on CM10 - no volume control, only shows "BTA" on the head unit
Galaxy Nexus on stock 4.0, 4.1, or 4.2 - volume control works, will display "STREAMING AUDIO" under "BTA" when BT audio is selected
Galaxy Nexus on CM10, AOKP, SlimROM, LiquidSmooth, Paranoid Android and Bugless Beast - no volume control, only shows "BTA"
VZW GS3 on stock or modified stock ROMs, ICS and JB - volume control works, MIGHT display "STREAMING AUDIO", sometimes it doesn't but volume can still be changed
VZW GS3 on CM10 - no volume control, only shows "BTA"
Nexus 4 on stock 4.2 - volume control works, shows "STREAMING AUDIO", but the phone likes to unpair itself every time I start the car.
I've also tried a couple of these with Rhapsody and Rdio and the head unit responses are the same or similar. In fact, Rhapsody will actually show the artist and song for a split second when it starts playing, then it disappears. Google Music seems to work across the board.
So basically if you want to use any of the decent streaming music apps and want volume control, you'll have to use a stock or stock-based ROM. I don't know if this is the same case for pre-ICS phones/ROMs, though.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 11-29-2012, 01:43 PM   #34
Originally Posted by apexaddict View Post
...So basically if you want to use any of the decent streaming music apps and want volume control, you'll have to use a stock or stock-based ROM. I don't know if this is the same case for pre-ICS phones/ROMs, though.
My VZW Droid X is stock Gingerbread 2.3.4 (has to be stock for BYOD reasons). I get the BTA, volume knob doesn't work except for about 5 seconds (which is OK). Buttons (pause, tracks, etc) work in some apps, not in others, hit or miss.
Old 11-29-2012, 02:49 PM   #35
midnightfrolic
Drives: Scion FRS A/T raven
I do not have a S3. I use an s2 and iphone5. I used bluetooth on both and i cannot tell a difference in audio quality. i used the usb on the iphone and still no better/worse. Maybe because scion fixed something with the audio with my car batch?
I will try with hp touchpad webos and rooted dualboot CM9 ICS, when i get a chance, to hear any difference. I sadly do not have access to any other phones to test, but will be on the lookout if any coworkers get any other phones.
midnightfrolic is offline   Reply With Quote
Old 11-29-2012, 06:44 PM   #36
luscious
luscious's Avatar
Drives: 2013 FR-S Argento MT
I just tested a HTC One X+ with the bluetooth, and it sounds great!!
Meanwhile, the forums over ate XDA-Developers in the HTC One X+ Q&A section is alive with people uset over very poor quality sound over bluetooth with it!
luscious is offline   Reply With Quote
Old 11-29-2012, 11:48 PM   #37
midnightfrolic
tested my hp touchpad with both webos and CM9 ICS rooted. both sound great. Webos sounds the best out of all my bluetooth devices. The phones sometimes has serious stutter issues when connected via bluetooth. Not sure why. It is unbearably worse than radio static.
Old 11-30-2012, 08:54 AM   #38
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I'm running Xenon HD on my G Nexus and I have very limited issues. Takes a minute to automatically connect when I start the car and sometimes song info won't show up. But sound quality is always good. Try out that ROM. Should be available on XDA.
Bg8780 is offline   Reply With Quote
Old 01-17-2013, 05:21 PM   #39
luscious
luscious's Avatar
Thread necro FTW..
The stock FR-S UBB port......does this thing only work with iPhones? I get a "USB Error" when I plug any other android phone into it.
Old 01-17-2013, 05:33 PM   #40
2forme
Thread necro FTW..
The stock FR-S UB port......does this thing only work with iPhones? I get a "USB Error" when I plug any other android phone into it.
Did you set the android USB connection to "disk drive" or the like? That tells android to allow file system access to the SD card (or internal storage).
Old 01-17-2013, 07:05 PM   #41
luscious
luscious's Avatar
done that! no dice........the only settings are have are MTP and PTP. Neither of them work.
Old 01-17-2013, 07:39 PM   #42
RMStringer
RMStringer's Avatar
Drives: Scion FR-s Pearl White 6 Speed
Send a message via ICQ to RMStringer Send a message via Yahoo to RMStringer
I run the Galaxy SIII and when i use Bluetooth it works great! ID3 info shows up great as well. Just running stock and using stock player work. If i use GoneMAD no ID3 shows up.
RMStringer is offline   Reply With Quote
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 05:14 PM
Bespoke Android Cheddar Electronics | Audio | NAV | Infotainment 5 11-07-2012 09:16 AM
Defi Android App illmatic Engine, Exhaust, Transmission 4 08-27-2012 01:00 PM
Here's one for you spec geeks... faz1 Scion FR-S / Toyota 86 GT86 General Forum 1 06-27-2012 07:11 PM
Android vs iOS vs BB os...which is best? Raiden Off-Topic Lounge [WARNING: NO POLITICS] 19 02-02-2011 11:37 PM
