CANADA Canada
Old 11-24-2012, 06:38 PM   #155
whtchocla7e
Drives: 2013 FR-S Hot Lava
Anyone here have the 16" steelies from Tirerack?
Are they hubcentric? Any problems fitting on our cars or good to go?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 11-25-2012, 03:53 AM   #156
Lithandril
Drives: Asphalt fr-s 6mt
Originally Posted by Enemies View Post
Yeah, I didn't think of doing that for the FR-S, but I did ask for the BRZ and while the BRZ was listed in their book the data in those fields were missing.
the data is missing because they dont carry it in store, but should still have a part #, i do remember that the frs is listed but they dont carry it in store nor do they do special orders
Lithandril is offline   Reply With Quote
Old 11-25-2012, 03:46 PM   #157
Enemies
Drives: '13 SWP Sport-Tech (Limited)
This PDF was listed earlier in the thread. It was updated some time this November.
http://www.costco.ca/wcsstore/Costco.../100018256.pdf
Enemies is offline   Reply With Quote
Old 11-25-2012, 05:50 PM   #158
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
So X40867 is the part # you need in a 16".
Slick is offline   Reply With Quote
Old 11-26-2012, 05:19 AM   #159
Enemies
Already ordered them weeks ago. X40867T's. Just over $100 with Taxes for the 4 of them. No cost to ship. Not bad considering all 4 weighed like 100 pounds.
With wheels, tires, installation, everything, cost me under $1000 for Michelin X-Ice Xi3's. Everything from/done at Costco.
The Following User Says Thank You to Enemies For This Useful Post:
spikey_dogg (11-26-2012)
Old 11-26-2012, 03:43 PM   #160
thorlius
Canadian
Drives: Frieda: Firestorm/MT (11/28/2012)
I got the X40867s and the dealership is telling me the 205/55/16 tires I also bought won't mount on the rims. The same tires mount on their other 16" rims without issue apparently.
Just a heads up. I am returning the rims.
thorlius is offline   Reply With Quote
Old 11-26-2012, 07:54 PM   #161
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Did they bother to tell you whey wouldn't mount on the rims?
smbrm is offline   Reply With Quote
Old 11-26-2012, 09:10 PM   #162
thorlius
Canadian
My sales guy explained it vaguely and honestly I didn't really understand what he meant. I don't have a clue how you get the rubber around the steel but they mentioned hitting the max PSI before they might damage/blow out the tire... Apparently one of the steelies was "scuffed" in the attempt and was sent to the body shop to be repaired. My guess is that it was actually somehow size related and it was bent/mangled somehow. They said if Costco won't take it back (unlikely) then they'll buy the damaged one off me.
They are apparently going to give me 16" alloys for $70 each instead (less than $30/wheel upgrade cost after I return the steelies), and I'll be done with the hassle for a good few years.
Old 11-26-2012, 09:31 PM   #163
Burrcold
Drives: Subaru BRZ Limited
Sounds like they just wanted you to buy their rims instead. Call up any actual tire shop and they'll tell you that they fit no problem.
Old 11-26-2012, 10:15 PM   #164
smbrm
smbrm's Avatar
Either that or they screwed it up some how? I believe you are not supposed to go above 40 psi to seat the bead. If the bead wouldn't seat properly then that may have caused an issue, however the question is what caused the bead not to want to seat?
Old 11-26-2012, 10:19 PM   #165
DR 86
DR 86's Avatar
Mounted 205/55/16s on 16" hub centric steelies no problem.
DR 86 is offline   Reply With Quote
Old 11-26-2012, 10:25 PM   #166
Burrcold
Same here.
Old 11-26-2012, 10:41 PM   #167
thorlius
Canadian
Either that or they screwed it up some how? I believe you are not supposed to go about 40 psi to seat the bead. If the bead wouldn't seat properly then that may have caused an issue, however the question is what caused the bead not to want to seat?
That's what he said. They were at 40psi and no dice, didn't want to go higher.
I am pretty sure they are being honest - they told me about the scuff and that it was sent to their body shop, and said they'd buy the one off me if I couldn't return it.
Old 11-26-2012, 11:42 PM   #168
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Yes I bought the 16" from tirerack and installed last weekend (right before it snowed in the adirondacks, perfect timing) and they installed no problem.
Rossman is offline   Reply With Quote
The Following User Says Thank You to Rossman For This Useful Post:
whtchocla7e (11-28-2012)
FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires Chuynh207 Wheels and Tires 3 11-06-2012 02:19 PM
snow tires debs0712 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2012 01:58 PM
what tires will you be using this winter for snow? denverizzles Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 08-02-2012 12:20 AM
How effective are snow tires? theredtape Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 06-18-2012 08:49 PM
Snow tires? smbrm CANADA 12 05-27-2012 02:20 AM
