View Poll Results: Motul gear 300 or Redline MT90 for transmission & Differential?
Motul gear 300 193 71.75%
Redline MT90 76 28.25%
Voters: 269. You may not vote on this poll
Old 11-19-2012, 09:35 PM   #43
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Originally Posted by Nardi330 View Post
if you have good knowledge about oil and stuff as you implied, maybe you can supply us with factual information to show that Redline 75w90NS is or isn't the correct oil for our LSD?
Oh so you put in in the diff. It's primarily manual transmission oil. Although it can be used in clutch type LSD for maximum lock up. It all makes sense now. You should have used this 75w-90 GL5 >> http://www.redlineoil.com/product.aspx?pid=133&pcid=4
You didn't research your product properly before purchasing it now did you. Also the factory spec is 75w-85 GL5, but there's no harm running 75w-90
SXE10 is offline   Reply With Quote
Old 11-19-2012, 09:54 PM   #44
Nardi330
Nardi330's Avatar
Drives: 86
i did. both are gear oil, both are GL5, both can be used for transaxle.
http://www.redlineoil.com/product.aspx?pid=47&pcid=7
the difference, according to Redline is fiction modifier. 75w90 has it but 75w90NS doesn't. Our LSD isn't a clutch type so doesn't need fiction modifler and so NS was selected.
also 75w90 is not safe for gearbox but 75w90NS is. both can be used for diff.
regardless my diff doesn't like the 75w90NS and i'm happy with Motul Gear 300.
Nardi330 is offline   Reply With Quote
The Following User Says Thank You to Nardi330 For This Useful Post:
victorb (04-08-2013)
Old 11-20-2012, 10:26 PM   #45
SXE10
SXE10's Avatar
Wink
There's more difference to these oils than just friction modifier, thats why your diff didn't like it. As they say a little bit of knowledge can be a dangerous thing...
You should run MT-90 GL4 in the gearbox not NS which is GL5. Also NS is not suitable for a Torsen LSD (you've proved that). Here's the service schedule for future reference >> http://www.ft86club.com/forums/showthread.php?t=15172
The Following User Says Thank You to SXE10 For This Useful Post:
Strife26 (05-15-2017)
Old 11-20-2012, 10:48 PM   #46
Nardi330
Nardi330's Avatar
Drives: 86
I ran MT90 in the gear box. i think i have stated this many times already.....
the Redline website didn't say anything about NS not suitable for torsen. if it did there is no way i would have bought it. in fact Redline didn't say anything about torsen suitability for 75w90 and 75w90NS.
i guess i learnt the hard way but someone has to do it.
thanks for the service schedule.
Old 11-20-2012, 11:03 PM   #47
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Actually NS or non-NS should not make a difference in the rear diffy of a torsen unit. Mechanical rear diffys REQUIRE the NS additives, but should not effect a viscous or torsen rear diffy. It is a GL-5 which is what the rear diffy calls for.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
Nardi330 (11-20-2012)
Old 11-20-2012, 11:40 PM   #48
Nardi330
Nardi330's Avatar
Drives: 86
-Mike Paisan
thanks Mike. this is what i think too.....
Old 11-22-2012, 07:25 PM   #49
Daless2
I see many have posted recommendations on differential gear oil but I find this rather confusing.
According to the Toyota/Scion Service manual, Toyota recommends
LT 75W-85 GL-5 (or equivalent) for Non Limited Slip Differentials
And
LX 75W-85 GL-5 (or equivalent) for Limited Slip Differentials
Both of this are synthetic gear oils, both have the same weight, yet they are different, as indicated by the Non-LSD (LT) vs. with LSD (LX).
I do realize there are no friction plates in the rear end, but there is certainly something different between the two gear oils Toyota recommends.
Does anyone “know” what those differences are?
Doesn’t make sense to me to change out gear oil and replace with aftermarket oil for “Non- LSD” if it does not have the properties Toyota recommends in the “With-LSD” installed in the car.
Your thoughts would be appreciated.
Daless2 is offline   Reply With Quote
Old 12-04-2012, 11:05 PM   #50
SXE10
SXE10's Avatar
I'd say LX & LT are just Toyota USA specs. They're not API or SAE as far as I'm aware. The same oil is used in other Toyota vehicles with plate type LSD, so I'd say LX has friction modifier in it & LT doesn't.
The NZ/AU service schedule makes no mention of LX or LT. Just use a GL5 designed for an LSD & you'll be right.
*EDIT*
Found some basic spec on "TOYOTA GENUINE DIFFERENTIAL GEAR OIL LT 75W-85"
Part number 08885-02506
76 cSt @ 40
°c
11.5 cSt @ 100
°c
They're a Torsen LSD so don't require friction modifiers.
Old 12-04-2012, 11:45 PM   #51
gmookher
Whatever you do , do NOT use a GL5 in the transmission
It calls for a GL3 which has been superceded by GL4
however it does not work the same way b/w GL4 and GL5
GL5 is fine in the diff
forget SAE spec. consider the actual oil used and its viscosity
Old 12-15-2012, 11:22 PM   #52
Amadeus
Amadeus's Avatar
Drives: White MT FR-S
Is there any harm running the Motul GEAR 300 75W-90 LS even though we don't need the friction modifiers in the torsen differential? Is the non LS Motul GEAR 300 75W-90 better for our diff or does it not matter at all which version we use?
Amadeus is offline   Reply With Quote
Old 12-16-2012, 12:42 PM   #53
AZP Installs
In the rear diff either one works. In the trans you don't want to LS modifier.
-Mike Paisan
Amadeus (12-16-2012)
Old 12-28-2012, 04:17 PM   #54
fenixv8
fenixv8's Avatar
Drives: 1991 Acura NSX, 2013 Scion FRS
So can I use this is the Tranny and Diff or just the DIff?
http://www.motul.com/ca/en-US/produc...%5Brange%5D=25
fenixv8 is offline   Reply With Quote
Old 12-28-2012, 05:36 PM   #55
Hanakuso
I believe the Motul 300 75W90 can be used in both. The Motul 300 75W90 LS can only be used in the LSD.
Hanakuso is offline   Reply With Quote
The Following User Says Thank You to Hanakuso For This Useful Post:
AZP Installs (12-28-2012)
Old 12-28-2012, 05:40 PM   #56
AZP Installs
+1 That is correct.
-Mike Paisan
redline kendalldwhite Scion FR-S / Toyota 86 GT86 General Forum 5 08-26-2012 03:12 PM
Reaching redline. erom Engine, Exhaust, Transmission 27 07-23-2012 07:46 PM
Fr-s vs. Saturn Sky Redline - would your rather Gabriel FR-S / BRZ vs.... 7 06-07-2012 01:57 AM
Engine 7500rpm redline KiingDavid Engine, Exhaust, Transmission 20 03-13-2011 08:04 PM
