AVOturboworld
Old 11-16-2012, 05:40 PM   #1541
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
*fuel
I am sure you guys know this but octane at the pump is MINIMUM. That means that the 91 octane can be.....93. It just can't be 89 or 87. Also I can be at same brand gas station..different parts of the city and one will have 91 with ethanol(10%) or will have 91 without...or 92.
Just saying.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 11-16-2012, 07:14 PM   #1542
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by dsmx17 View Post
Its the blockage that obstructs airflow (from the turbine) that in turn muffles sound, so again speed does not matter for sound in a turbo application.
not trying to be a ****, just found it amusing.
I thought the exhaust was quieter after a turbo because of the energy that's been removed to drive it?
3 forms of energy come out of the tail pipe. Heat, sound and pressure.
The turbine uses the energy from the pressure and absorbs a lot of heat, so it would seem logical that the sound at the tail pipe would reflect those losses.
sierra is offline   Reply With Quote
Old 11-16-2012, 07:41 PM   #1543
nonicname
Drives: it has 4 wheels and a motor
the second you change headers the exhaust gets louder, plus I believe AVO's car on the vid has a muffler.
nonicname is offline   Reply With Quote
Old 11-16-2012, 10:02 PM   #1544
driver01
Drives: brz 13
@AVOturboworld From the pictures I see that the Air fuel ratio sensor is placed on the downpipe, right after the turbo. Will there be an extra bung welded for the people who want to run an additional wideband for an air fuel ratio gauge? I would hate to have to drill into my ceramic coated downpipe to weld a bung for an additional sensor. Or is drilling and welding on a ceramic coated pipe ok?
driver01 is offline   Reply With Quote
Old 11-17-2012, 12:57 AM   #1545
Mrqb22
Drives: 2013 FR-S Whiteout
AVO world do you guys recommend doing the head gaskets with ARP hardware to go along with it at the time your doing install. I am just wondering if that is smart thing to do rather than blow a head gasket and over heat the engine after spending all that money and trn arond blow head gasket and have to start all over again
2013 Whiteout
2013 XB black pearl.
Mrqb22 is offline   Reply With Quote
Old 11-17-2012, 01:30 AM   #1546
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
As long as your kit is properly installed, it is not expected you will blow a head gasket with stage 1 (ANYTHING is possible, I am just saying it's a very remote possibility).
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
gmookher (11-17-2012), ngabdala (11-17-2012)
Old 11-17-2012, 09:24 AM   #1547
dsmx17
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
The turbine blades act as baffles.
dsmx17 is offline   Reply With Quote
Old 11-17-2012, 09:29 AM   #1548
dsmx17
4g63>rotards
That's mostly correct, it depends on the design. Typically, tube headers will increase sound (marginally) do to the resonance of tubular piping VS cast manifolds.
Same logic behind a straight exhaust being louder than a factory style exhaust with more bends, less obstructions for sound to be redirected and as a byproduct lose volume (typically)
**Edit forgot to mention, not all "headers" are made from tubular designs, aftermarket cast manifolds and log style also taken into consideration.
*Side note, I am really fucking bored at work today. I have decided working mandatory saturdays every 5 weeks is employment rape, just dont get dinner first.
Old 11-17-2012, 04:15 PM   #1549
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
MAP SENSOR
Where is located the MAP sensor on our car ?
Anybody have a picture to show us where it is.
Which one of those 3 differents models our car use ( see pictures below ) :
If we change the map sensor for a 2 or 3 BAR and use an electronic boost controller to raise the boost from 5-6 to 7-8 psi, Does the ECU will try to correct the AFR according to that ?
Can we change the boost level via the ECU with ECUTEK instead to use an electronics boost controller ?
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 11-17-2012, 04:30 PM   #1550
Unleashed
Unleashed's Avatar
Drives: 13' WRX
If we change the map sensor for a 2 or 3 BAR and use an electronic boost controller to raise the boost from 5-6 to 7-8 psi, will the ECU correct the AFR according to that ?
In regards to the ECUTEK boost control, it has been confirmed you can change the boost level with the ECU via ECUTEK.
Unleashed is offline   Reply With Quote
The Following User Says Thank You to Unleashed For This Useful Post:
cobrabyte (11-17-2012)
Old 11-17-2012, 05:40 PM   #1551
NoFear99
NoFear99's Avatar
This is a good news.
I prefer to set the boost level needed into the ecu and avoid the boost controller fees and installation.
But now that we know that both ECUTEK and EBC can do the job ; Is there one better than the other to keep AFR safe on the spot ?
For example : If Avo's base map with 5psi has been set to be at 12AFR at WOT, by raising the boost myself with 2 extra psi will change the AFR a bit to maybe 12.5 - 12.7 instead.
Is that correct ?
Old 11-18-2012, 02:15 AM   #1552
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
When will you start development for stage 2/3 - kit/upgrades, if you havent already?
ahaghshenas is offline   Reply With Quote
Old 11-18-2012, 03:59 AM   #1553
GC GTS Aero Kit
Australian and Proud !!!!
GC GTS Aero Kit's Avatar
Drives: 2012 Toyota 86 GTS Aero Kit
Have AVO made an oil cooler kit? HKS and GReddy kits are a bit pricey at $1000US would be much more inclined to fit if a kit around the $500 mark was available
BONKRS for life
GC GTS Aero Kit is offline   Reply With Quote
Old 11-18-2012, 01:31 PM   #1554
AVOturboworld
We are working on the further stages, but our priority is the stage 1 for manuals and automatics.
I believe they are working on an oil cooler idea in Japan, but I've not heard details yet, nor pricing.
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
